Whats the layout?
3 letter 3 number?
Yeah.
The $400 ones, I'm not paying 2g's for a plate - lol
You can have:
3 letters / 2 numbers
2 numbers / 3 letters
3 letters / 3 numbers
3 numbers / 3 letters
Edited by R33MidnightRacer
https://www.sau.com.au/forums/topic/147627-new-plate-ideas/#findComment-2755253
I've tried to many like that Brent.
I've tired almost everything ..lol
SXC-033
HOT-033
QIK-033
QIC-033
MRR33
Umm..heaps of others too, just gets harder and harder to come up with a good pplate cause they're all taken.
https://www.sau.com.au/forums/topic/147627-new-plate-ideas/#findComment-2755255
wpn.033
yld.33
wkd.033
cmy.33
aar.33
theres heaps mate u just need to be creative and mix and match
Hehe, I know there are so many you can come up with, mix and match etc ..but sadly all the ones you posted have been taken, just checked them all on PPQ.
https://www.sau.com.au/forums/topic/147627-new-plate-ideas/#findComment-2755263
give me the link for the site and i will look up some plates for you.
if theres 1 i find i will post it up,
reason im bored and theres nothing else for me too do but sleep and its way too early for that ;)
lol - fair enough.
The website is http://www.ppq.com.au.
Go to "Create A Plate" at the top of the page, and then use "Personalised Plates 3x2" and "Personalised Plates 3x3" as they're the ones from $395. Other ones are much more sadly.
https://www.sau.com.au/forums/topic/147627-new-plate-ideas/#findComment-2755267
    • 1. Factory knock sensors for now, honestly the RB26 OEM knock sensors seem ok as they're flat response instead of resonant type but they appear to be internally grounded to the block. If I do replace the sensor it would just be to get ones that are not internally grounded so a differential input can be used to reject common mode noise. Definitely plan on fixing this as a part of the tuning process. 2. Never deliberately induced knock, though I guess I could try that experiment if I really wanted to. 3. All of this is basically on a stock engine + ECU, only modification is HKS GTIII-SS turbos and a Nismo plenum. Currently I run it with the wastegate solenoid unplugged so it won't try to raise boost past wastegate pressure.
    • After being peer-pressured into paying $100 for the MW remakes, got BO6 on XBox Game Pass. I think that's worth it.
    • That's a given!  Bit hard to powdercoat it properly without removing them! 😁
    • No detail on compressor or turbine sizes, which doesn't help with housing size selection with that kit. However, from SR20DET mucking about and money torching perspective, a GTX2860R Gen 2 w/ 0.64 (46mm inducer) will do ~260kW on E85 about 1.5bar of boost. All in before 3000pm, which cause a gearbox to shatter. Now imagine the same turbo, on a modern motor with an extra 0.5L of displacement, and heaps of cam timing adjustability (not an on/off affair like the Nissan shit boxes). If this was my car (which I would never own or consider buying, ever!), I would go for a nice twin scroll setup, and a G30-660. Gates plumbed back, no silly shit. Lean on the cam timing, big displacement to create a flat-ish torque curve.
