Hello,
I needed a new (used) car and came across this ad:
R33
(Yes, I'm in the UK)
I liked the car, because this one is not modified and has not any embarrassing mods or spoilers.
The price is 12,500 AUD.
Though the price sounded a bit steep to me I had a look at the car.
Had A Look At The Car
In reality it didn't look that gorgeous anymore, but I still liked it.
I did some checks on the car, and followed an advice I got to verify the year:
The year of manufacture can be found by looking at the front seatbelts, near the floor mounting point. There is a fabric tag with the seatbelt specifications and the year of manufacture sewn onto the webbing.
So I checked the tag and it said 1993! ;)
I pointed this out to the seller, and he said that the seatbelt might have been replaced ..
I think that's quite a far fetched story, but are there any things apart from the tag to tell the year?
I checked many Skyline pictures, and all with the year 95 seem to have an airbag.
There's a number on the firewall where the engine sits and it says:
ECR33-002864
If this is some kind of serial number, it sounds pretty low to me and would support the 1993 tag year.
Hmmmmm .....
Is there any check I can do on the number?
I still like the car, and the engine made a good impression on me.
I'm a complete beginner with Skylines and any help is highly appreciated.
Thanks for the help!
Greetings from London!
https://www.sau.com.au/forums/topic/147634-how-to-tell-the-year-of-a-r33/
Car is a '93 or '94 model ;)
- Seat belts are manufactured by another business, so they can be done in advance.
- The engine has the coil igniter modual, on the top, at the rear (near the firewall), which only came out in '93 or '94 cars.
- Has the S1 rear spoiler
- No airbag
"The price is 12,500 AUD.
Though the price sounded a bit steep to me"
Hi,
I would have thought $12500 for an R33 with 69000km on the clock, was little on the too good to be true end of the scale if anything...
Damien
Edited by ShylineR33
Hi,
Damien
No, it represents the upper limit for such a car in the UK and I'd only pay the amount for a 95 in mint condition.
As for the milage you should consider if such a low milage is realistic for an 11 year old car.
The car in the link (true 95) below is at 13,000 AUD and also at the top range of prices.
Besides note that this is not a GTR!
GTRs is what people want, so the price is higher.
Cheers
Edited by Torques
- No airbag
:D
Thanks, I agree ... the seat belt could be made in advance ... but 2 years?
So much harder evidence seems to be the spoiler / airbag / coils.
What does S1 mean? And when came the 'new' spoiler exactly?
Can I do any research regarding the number on the firewall?
If you look at this one, it seems to be a true 95 model and I'd pay the price for it.
True 95
True 95
that one looks like a S1.5 - S1 front with S2 wing and the clear skyline boot garnish
the higher wing came on the S2 models, and on the S1.5 models
S1 is series 1 - info can be found here
S1.5 is series 1.5 - info can be found here , this is basically a S1 with the S2 wing and engine.
S2 is series 2 - info can be found here
more info on model differences can be found here
it is mainly cosmetic changes and standard options, there is other things like the coil igniter module as noted above
you can post the VIN number (number on firewall) in these threads and someone with the Nissan FAST program will check it out for you
http://www.skylinesaustralia.com/forums/in...howtopic=133729
http://www.skylinesaustralia.com/forums/in...howtopic=128496
yeah it looks like a 93 - rear spoiler and steering wheel - but thats how i look at it
what is it bout the steering wheel that differentiates the models? just curious
EDIT: ok realised for myself. its the airbag right?
Edited by Basti
Good morning from the UK!
Wow ... I woke up this morning and was wondering whether there is any reply at all.
:P
Thank you so much for all the information, this is just great!
I knew from the start that the car didn't feel like a 95 model, but the seller was asking the 1995 price for it.
He stressed many times that this is a 95 model...
As for the airbag I read in a wiki that all 96 models have the airbag as standard.
I think with the VIN number I really can nail the seller down on the year.
(Unless he argues that this has been replaced as well)
Cheers!
    • Well, in 2007 he must have been charging about $1800 an hour. He only looked at the car for 5 minutes. And another 4 to write the report wrong, and another minute to correct it. Mind you, this was for a car that was: Stock engine, fmic (hole in drivers guard), all alloy intake and custom air box, 3 inch turbo back exhaust, lowered, and a set of 17" Advans (255/40/17 rear and 235/45/17 front). It was nothing crazy. The blue slipper wanted the "hole in the guard" engineered. But that was because he got the shits that I wouldn't "relocate the battery from the boot, back to the factory position in the engine bay"... In an R33 GTST...     Also for emissions, E85, and don't go wild on timing. It's amazing how the closer you get ignition timing towards max torque, the last couple of degrees really throw NOx counts right up. And for the huge increase in emissions, it's only a small increase in torque.
    • He'll be looking down and swearing about "the damn apprentice" for trying to convince Duncan to use percussive maintenance... 😛
    • I swear at my GKTech ones every time I have to take them apart and replace a spherical. But I wouldn't swap them for anything else. They absolutely slay every other option, at least in terms of how they actually work. You sure you don't want to live with bearings? I mean, they don't have "ball bearings". They are rod ends and sphericals throughout. Tough as nuts, even though I have found more than one way to wear them out.
    • From when I was looking at getting the 86 engineered for the turbo, the joint said to put in a few euro 5 or 6 cats, then tune the car on a nice clean E85 tune When I was looking at a turbo for the MX5, it was basically the same thing, a couple of cats and a nice clean tune Although, it will depend on the year of the Jeep IRT emmisions standards required, and what mods are done, especially if it has a newer engine installed that requires a higher Euro
    • Yeah - but it's not actually that easy. There are limits for HC, CO, NOx and particulates. Particulates shouldn't be a concern in any petrol engine unless trying to comply to the very latest Euro standard. But getting a tune right so that all the others stay within limits AT THE SAME TIME is not a trivial exercise. You couldn't possibly get it right by just guessing at the tuner's dyno, unless he had a 4 gas analyser up the pipe, which is not often the case these days. It used to be. Every decent shop that did "tune ups" (as opposed to tuning) would have a 4 gas analsyer. Perhaps there's still quite a few of them around these days. But most "tuners" are only watching O2 and power readings.
