So the high pressure bucket thingo is still illegal. At stage 2 at home you can use a bucket or high pressure cleaner and a hose only for rinsing. So its legal until 1st Jan.
So the guy at Bunnings lied to me :D
  • Replies 59
really is retarded - cos all thse numbers are making people confused.....i voted for liberal cos of their policy on trying to conserve water by using desalination plants and what not....
whats stage freaking 9 gonna be? cant use toilet paper anymore?
No you recycle your shit to get water out... :ninja:
Anyone remember "Tank Girl?" They stuck that can into another person and extracted the water out (killing the person the process).
yeah, i could think of a few people i would want to do that to.....bracks :ninja:
Spend a little on good quality surface protectants/waxes...
Once applied it takes as little as $1-$2 at carlovers.. high pressure soap.. high pressure rinse.. spot free rinse
Perfectly clean.. as long as you dont let the dirt build up on your car..
Works for me..
Thats a good idea, but where do you was your car before you wax if?? Your still going to have to wash it at home then wax it straight way
Well we arent in stage 3 yet... you can still use a High Pressure at home.. or if you like... go to carlovers and wash.. come home.. wipe over with microfibre to remove any dust that may have landed on your car in the short drive home... Start waxing.. or you can take your wax with you if its one that can be applied in the sun
If you want a quick easy polish/protectant.. Turtle Wax ICE seems to do the job.. Nice and easy to apply and remove.. Shines like a mofo and hides swirls, Can be used on taillights, rubbers, headlights and also clear coat safe.. can be used in DIRECT SUNLIGHT!
Ive got a whole garage full of various products for detailing.. Do family/friends cars as well.. I enjoy making a car shine like it should :laugh:
Meguairs NXT seems good too.. and Mothers 3 step system... (more for a car thats had no loving in a while)
Edited by MotoMan
Working for a part of Melbourne Water I can tell you that they have started the planning stages for a $380 million dollar desalination plant in Victoria.
The BS bracks was carrying on about during the elections about industry, especially powerstations using recycled water instead of fresh water with the installation of a new pipeline so that millions of fresh water would be saved, the planning for that hasent even started!!
I work at 1 of the water treatment plants and we had recycled water which is called 2W water that we could put in portable water tanks and then take home to water the garden etc. Some silly f*ker recently drank some of the water and got sick so they have not restricted the public taking any away.
I got a 2500L rainwater tank at my new place with a electric pump that the toilet uses when theres water in the tank, which I am gonna rewire with a hose so I can use it as a pressure cleaner also for washing my car.
There is always one who has to drink it! :laugh:
big no no, swirl city... even if it's light dust. Just take wax to the car wash. Simple.
    • Thanks for sharing this, and BTW if your headlights are in good condition they are worth thousands....you might want to consider replacing them with brand new LED ones like this (https://www.nengun.com/78works/full-led-headlights-r32-skyline) and making enough profit to buy a house in Sydney
    • I'm not sure what sort of shops are nearby, but I'd expect any reasonable exhaust shop could put a cat in it that will not restrict the power that engine makes. Otherwise, if you want to remove it, short lengths that replace the cat are readily available online, search for "de-cat pipes" or "test pipes"
    • Howdy friends, So another weird one today, I was looking into replacing some broken clips holding the front grille for the R32 GTR (part number 01553-03831), and noticed the brackets which are supposed to hold the grille in place were also missing 😑. I do recall seeing this issue many years ago, but didn't fix it at the time. A quick look on eBay and I was able to find the genuine brackets, along with all the screws which suited the headlights (part numbers 26042-08U05,26092-08U05). Happy days!....  Once they arrived however there was an extra nut in the packaging which implied that there should also be a bolt or a stud, and sure enough, after a bit of searching I found this thread from 2013, and @Ants clearly shows a stud should be present. Reading around a bit more, it's possible the headlights on my car are the "povo pack" headlights as mentioned by @funkymonkey in this thread way back in 2008. This could explain why the studs are missing on my set of headlights. Looking at the headlight diagram I wasn't able to see a suitable part number for the stud itself. The headlight did indeed have a recess that looked like it would accept a stud, but interestingly no thread or anything obvious how the stud would be affixed to the headlight, I suspect it may have been glued in, press fit, or melted into the plastic at the factory. Another member may be able to clarify if they happen to have a genuine set of N1 headlamps. The only thing we have to work with within the recess is a keyway which likely is there to prevent the stud from rotating within the recess. In any case, back to 3D printing, I put together a model which acts like a pug with a friction fit inside this recess, making use of the keyway so it doesn't rotate while tightening a bolt. Printing in TPU will allow it to slightly swell making a nice snug fit without cracking the part. I've designed the adaptor it to accept an 20 mm M6 bolt (stainless with a cap head in my case), as opposed to the standard M5 stud and I made use of the standard galvanised split washer that came with the genuine brackets from Nissan. Once the bolt and screws were all in place, giving the bracket a gentle shake gave the classic "shaking the car" feeling, very solid, which gives me confidence this is going to be able to hold on much better than the janky solution which seems to have been here for the past decade or so. Overall I'm really pleased with how this turned out and maybe there are more people out there running these headlights without a centre stud at all! Link to the freely available model on Printables: Click here Regards, Sean
    • Hey everyone, This is my first post apart of the introduction. I tried searching a bit on the forum but couldn't really get a straight answer. I got the car to my mechanic as I felt it being weak. It seems that it was missing on two cylinders due to the injectors. I had all my injectors clean and the car runs much better. The mechanic also confirmed my suspicions that the cat is clogged and needs to be tackled asap. The cat rattles a bit and the hot exhaust warning frequently lights up when driving after getting the injectors clean. In my introduction I was asked about what modification I might be interested in and mentioned a cat delete. From what I was told, this is not really beneficial on the RB20DE and there are more cons than pros.  Could perhaps anyone give some suggestions on what the best course of action would be since the current cat is toast and needs to be removed/replaced anyway? I can also sometimes smell a strong smell of fuel, but I'm not sure if this is related.
    • Hope the cans went down well at least
