Hi all,
After purchasing my R33 about 2 months ago now.I have followed some modification guides to get more from my car.And im wondering what to do next.
Im not after huge power,just a nice consistant and reliable figure.
So far mods include: 3inch exhaust
3inch split dump pipe
Apexi pod filter(with alloy pod box)
tube and fin intercooler kit(will be fitted soon)
cushion button clutch kit(fitted next week)
And im running a constant 9psi
Im thinking of getting better spark plugs and a walbro fuel pump.Ofcoarse id like to get a power fc.But ive been looking at the apexi SAFC2.
All input appreciated.
CHEERS
Dave
https://www.sau.com.au/forums/topic/147675-what-is-next/
if youre happy with the power output of the standard turbo then go with the SAFC and provided your coils are good, youd be getting close to 300hp on 12psi and for many people, thats enough for the occassional squirt.
gap your plugs to .8 from memory and your fuel pump should be good enough all though its always nice to know youve got a safety net in regards to flow should you replace it. Especially as theyre over 10 years old now.
Youve got all the other supporting mods there such as FMIC, cooler and clutch.
Whats controlling your boost? Those $22 spring bleed valves on this site would be ok for your application
https://www.sau.com.au/forums/topic/147675-what-is-next/#findComment-2755794
I have the little pocket rocket tubotech manual boost controller.Bloody awesome little product. :(
https://www.sau.com.au/forums/topic/147675-what-is-next/#findComment-2755796
Have you read the sticky thread?
There are some great links to past threads which will give you lots of ideas.
http://www.skylinesaustralia.com/forums/in...showtopic=66556
cheers
Cool.Thanks mate very interesting stuff.Seeing as the power fc is now phased out i might purchase the SAFC2.
Id like to hear from people who have the same mods i have and has bought a SAFC2.I guess if its tuned right i would expect smoother power delivery and ofcoarse an increase in KW.
Where would i be able to purchase one at a good price?
Edited by NYTSKY
https://www.sau.com.au/forums/topic/147675-what-is-next/#findComment-2755884
Hey mate,
1. A Bosch 040 500hp intank is perfect
& will set you back $205 delievered
Australia Wide off Ebay.
2. Obviously, a stand alone ECU is much better
than an SAFC. Nevertheles, its still an upgrade.
My old set-up:
3" front pipe
4" HKS Dragger cat-back
Apexi SAFC-2
Apexi LM Intercooler
HKS Mushroom filter.
HKS EBC GEN3
It made 193rwkw on 10psi (stock boost)
198.9rwkw on 12psi
211.2rwkw on 14psi
I have a PFC now with a GT3071R.
I am selling the SAFC2, pm if interested.
Hope this helps,
Cheers,
Bill
https://www.sau.com.au/forums/topic/147675-what-is-next/#findComment-2755914
Hey mate,
My old set-up:
3" front pipe
Apexi SAFC-2
HKS EBC GEN3
198.9rwkw on 12psi
211.2rwkw on 14psi
Hope this helps,
Cheers,
Bill
PM sent
https://www.sau.com.au/forums/topic/147675-what-is-next/#findComment-2755988
Does the SAFC2 eliminate things like misfires and such?
It will get rid of r & r with proper tuning by not allowing the AFM to see the full 5.1V i think it is
Misfires will be due to your plug gap and/or coilpack condition.
https://www.sau.com.au/forums/topic/147675-what-is-next/#findComment-2756186
Mine was tuned!
R/R mode would still occur during
cold night drag meets.
https://www.sau.com.au/forums/topic/147675-what-is-next/#findComment-2756279
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 😃
    • You're just describing how type certification works. Personally I would be shocked to discover that catalytic converter is not in the stock mounting position. Is there a bracket on the transfer case holding the catalytic converter and front pipe together? If so, it should be in stock position.
    • You talking about the ones in the photo above? I guess that could make sense. Fixed (but flexible) line from the point up above down to the hubcap thingo, with a rotating air seal thingo. Then fixed (but also still likely flexible) line from the "other side" of the transfer in the hub cap thingo up to the valve stem on the rim. A horrible cludge, but something that could be done. I'd bet on the Unimog version being fed through from the back, as part of the axle assembly, without the need for the vulnerable lines out to the sides. It's amazing what you can do when you have an idea that is not quite impossible. Nearly impossible, but not quite.
