1. GARRETT GCG HIFLOW TURBO WITH 90MM DUMP PIPE, 5000KLM OLD, BOLT ON RB25 $1500 - SOLD PENDING PAYMENT
2. RDA SLOTTED ROTORS FRONT AND REAR BRAND NEW IN BOX $370- SOLD
3. BRAND NEW Z32 AFM WITH TOMEI PLUG $250 - SOLD
4. BRAND NEW WALBRO GSS-342 500HP PUMP $150 -SOLD
5. BRAND NEW BOSCH 040 PUMP WITH BRACKET READY TO BOLT STARIGHT IN $190 - SOLD
6. USED POWER FC WITH HAND CONTROLLER TO SUIT R33 SERIES 1 $800 - SOLD
7. USED ALUMINIUM AIR GUIDE $50 SOLD
8. NEW D1 QUICK RELEASE STEERING WHEEL KIT $50 SOLD PENDING PAYMENT
9. BRAND NEW SET OF 6 NGK IRIDIUM BKR5EIX-11 SPARK PLUGS $60 - SOLD
10. BRAND NEW GENUINE NISSAN TIMING BELT $65
11. BRAND NEW L.E.D TAIL LIGHTS $250
12. BRAND NEW C STYLE SHORT SHIFTER $60 (THIS IS A COPY, NOT GENIUNE ITEM) SOLD PENDING PAYMENT
13. BRAND NEW HID CSOMOS BLUE WHITE H1 HEADLIGHTS $20
14. BRAND NEW AEROSPEED ADJUSTABLE EXH CAM GEAR $70
IF INTERESTED PM ME. WILL SHIP TO ANYWHERE IN AUS AT BUYERS EXPENSE.
OR PICK UP AVAILABLE AT BOTANY IN SYDNEY
Edited by robbo33
https://www.sau.com.au/forums/topic/147711-r33-gtst-performance-parts/
Thanks Robbo (free bump)
Change your description and i think you'll get more bites.
It looks as if you've only got standard parts from the general listing page.
Add 'GCG turbo' and watch the questions come in.
Thanks again.
Birnie
9. BRAND NEW SET OF 6 NGK IRIDIUM BKR5EIX-11 SPARK PLUGS $70
10. BRAND NEW GENUINE NISSAN TIMING BELT $70
Pics of the above to [email protected] please!
How much for shipping to 5049 SA?
Cheers!
Just to help the seller - I have one of the C's Style Short Shifters. Even though its a copy, they are excellent, shorten the throw by a heap and feel absolutely fantastic.
I paid $85 delivered for mine, this one is a bargain.
:P
what are the plugs suited for? a boosted 33? i need new ones but i got a slightly different part number that has been recogmended to yours
    • I just got to work and skimmed through 61508 and 61511. I was surprised the CSA adopted both, but neither are enforced. To recap what I read, it states that in a perfect world, they should be segregated but they acknowledge that this is not industry standard and clearly mention that they allow mixing of safety and non-safety. 61511 also mentions software segregation like AB does in their safety PLC's.   Now if only I could go back to control, let alone safety over comms. In my current line of work, we're only allowed monitoring and basic control over comms. Everything critical must still be hard wired as much as possible.
    • I've unfortunately never been as they're on the complete other side of the continent and another country that isn't currently letting us in as easily as they use to. I even heard their stop signs over there actually say "Stop" instead of "Arret". If I decided to trek the 48h drive, I wouldn't know when or where to stop haha. Whenever I order parts from UP Garage, I order from Japan as it's cheaper. Same with GKTech... oddly enough, it's cheaper shipped from Australia then it is the US.  UP Garage Japan operates their US leg though, unlike Tomei. If Tomei JPN had the power to close down Tomei USA, I'm sure it would be done in a day. They're two completely separate entities. Tomei JPN messed up somewhere originally agreeing to its creation and got sacked big time.
    • I asked someone about this and he told me about the Audi 1.8T engine. But I think it would be difficult to swap
    • I don't know that machine specifically, but I'd personally go for something with a little more kick than 130amp. Around up to 180 would be good. At the 6mm range, you're really pushing the machine hard and don't have a long period you can run for with out needing to give it a rest. Lots of MIG machines come with a regulator and hose. A lot will come with a starter roll of wire too, but it isn't too expensive to buy. I'd recommend NOT buying a massive roll too, as you don't want it sitting around FOREVER in the machine between uses and potentially going to shit. For thin sheet metal, get a roll of 0.6mm if you're doing over 3mm and above, switch over to 0.8mm wire. Even by 2mm you'd probably really want to switch. As for gas battle, it's all swap and go style now. You'll pay a bottle deposit, and then X amount to swap for a full one. I think it's like $200 or $300 for a D Size bottle upfront as "deposit", and like $110 to $150 per swap. My D size CO2/argon bottle lasts a fair bit of welding on the MIG. And I run an E size bottle on the TIG. For DIY MIG, stick with a D size bottle. If you really start to get into a LOT of welding and doing it really regularly, then upgrade. If you're like most DIY car guys, one D bottle will last you 2 or 3 years easily. I think I've been on my current bottle about 5 years. It is starting to get low, but I've been smashing it a lot more the last 6 months.
    • SR20s came with cars like the Bluebird and Primera, but the RB20 never came. The ones in Turkey were either brought in specially or from abroad. That's why RBs aren't as common as SRs. And if a part breaks or I need to replace it when doing maintenance, it's harder to find parts for RBs.
