Paul;
My comment about the F-CON being used in the top GTRs in the world was in response to a previous comment that needed justification. I totally agree that it has zero relevance to this case.
"any ecu can make a car go fast, its how well its tuned and of course additional features it has"
Little bit contradictory...
True any ECU can be made to tune a car so it's fast... but as you just said: how well it's tuned and the features. Can't tune a ECU well when it just doesn't have the features nor does it have the tunability.
SAFCII is good; but not for the power you're talking about 250rwkw? Don't think so...
Finally, back on the E-Manage topic:
If you do some research you will find that many SAU people have had major problems with just the INSTALLATION of the E-Manage let alone using it. 666DAN will be able to back me up on this. You simply cannot just plug it in an make it work. I think there was a lot of DIY involved in order to make it work stably.
MAP capabilities? Using the Profec B? Hmmm.... and just take a look at N I B's comment.
F-CON, hasn't skipped a beat~
why do you think the safc cant get to 250rwkw? all it does it bend the afm signal. sure its a comprimise but all of the solutions are comprimises.
i dont see why a particular ecu would be limited to a power level, its just ign and inj values. i see no reason why the safc could not get a customer to 250rwkw. it will be a more tedious to do the initial tune as youll get to a point where it will advance the timing too much and induce detonation, but you should be able to get 250rwkw.
SAFC is a signal bender only with all fuel tuning changes have an affect on timing with no means to sort this problem.If you lean out an SAFC it tells the ECU its under less load so it moves the ECU into a lower load zone delivering less fuel but also more timing often leading to detonation.
SAFCs place in the food chain is basic modded cars only.
As far as I know SAFC is a fuel controller only (+/- 16 points) along a preset RPM range.
Problems:
1) No ignition changes
2) No compensation for bigger injectors (stock ECUs won't even work with bigger injectors)
3) What N I B said...
of course the safc wont work with bigger injectors
the user doesnt need to change injectors
it will move the ign timing around as the afm signal it bent
as the load is moved around, so to are the ign/inj load points
yeah Paul is correct from my exp.
I have run them had not real issues...
max'n out injectors is mod/tune dependant - mine were 95% at 260rwkw...with an EMANAGE...but thats with a better fuel pump...not std fuel pressure.
The emange will run to 280 cos I have done it...But I got a much better tune form the PFC.
I have also ran the emanage and the SAFC in my FTO...low power app with EXACTLY the same dyno after....
Every1 else has posted pros and cons...
Get a PFC or Haltech as suggested.
With the emanage blue... the options all add up, e.g. the software (unless your tuner already has it), the injector harness, etc. You should check out the emanage ultimate if you're looking at going this road.
  • 2 months later...
The Ultimate seem like a good buy with all the harness and support tool provided. Anyway it is nice to be able to fiddle with the software and tuning by yourself, but tuning it wrong is high which let to my friend blowing up his engine on the same day he dyno then when home to alter the setting himself. Most piggy back & ECU should be tune on the dyno then leave it once it's done. I will probably go for an FCon SZ or a 2nd FCON Vpro depending on availability plus i have a tuner who drives a GTT with Vpro too. We are always chasing for power, so buy something that do not limit ur goal for many year to come since the ECU is the brain for everything.
    • Welcome back mate ,I also joined in the early 2000's , since then I have been in and out a few times depending if I had a skyline in the garage.  I have the another one now , so signed up and back with the SAU team.
    • I used "different strokes for different folks" quite pointedly as honestly, there is no wrong when it comes to choosing what you like.  I always day dreamed about flappy paddles with fast shifts in a sporty RWD Turbo and to me the sound and feel of it cutting through gears in a steady stream is exciting, engaging, and keeps the car better balanced - I *also* like h-patterns, but I find them more engaging and fun in a nice hoonable peaky NA thing.  Type-R Integra/old school NA rotary, things that are raw and need all the rpm where picking the gear and getting it sky high is part of the engagement of the whole thing despite the fact that they probably need closer ratios and faster shifts even more than a 3l turbo thing haha
    • If I wasn't allowed or really had the desire to visit China it would probably fit in my carry on, but I have no desire, Japan would be nice during Cherry Blossom time though I might need to chat to Jackie about that, that should actually be an easy conversation though as she is currently talking about another cruise, cruise ship to Japan, a week in Japan to see the sights, then cruise home I may even be able to find those OEM NC Recaro seats over there that I cannot find here 馃
    • What do you mean?  In between the two I shared?  They're the same boost   This will be insane.   A mate has a GTSt with a 9:1 RB30/25 with Tomei 256 cams and a Borg S362SX-E that is already a beast from the basement but has a stock 5 speed and will probably get a ZF8 one day.  After the G35 900 RB26 setup I'd be lying if the topic of "Wtf would a divided G35 be like on this thing?" idea hadn't come up - you'd definitely want a wide boost control range setup with it, as even with the less responsive and potent S361 we're having to ramp boost in from very low levels in the early gears.
    • ZF8 is faster, wider ratio spread, better in every way. I do not dispute this. But I have brain damage and I want the feeling of shifting gears. To me the extra work is fun, but I daily an automatic and in the US like 90+% of cars are automatic so a manual transmission is an "exotic" experience. If I want an automatic I've driven an F80 M3 with DCT more than a few times and it's incredibly capable but it's emotionally vacant to me.
