Hi guys,
I just wanted to find out what kind of fuel usage your getting out of the non turbo's. I used to own a non turbo R33 about 5 years ago and after owning 4 turbo Skylines I was thinking of going back to a non turbo R34. My non turbo days were so long ago that I can't remeber if it actually used less petrol than the turbo's.
https://www.sau.com.au/forums/topic/147763-non-turbo-fuel-economy/
Hi guys,
it would use less fuel - but u will be missing out on performance
my girlfriend gets around 350 - 400km on a full tank? is there something wrong there? its a 97 gts-t.
(well it used to be turbo but she had to get the turbo removed - government restrictions.. but its going back on real soon!)
that sounds about rightish for a low compression na...
mine used to get 500+ easily... lately around 470, but its running rich and going into the mechanic soon.
Off boost at a cruising speed, a turbo car will generally be more fuel efficient than a NA car. OEMs tend to gear turbo cars to use that extra midrange torque.
Keep it off boost, and it'll be doing a lower RPM for that speed.
Of course, once you get up on boost its a different story.
mate, of course they do.
my best is 657Km's from 58L before the AAC valve decided to not play the game anymore.
Through this year the fuel light would come on between 510-520Kms and I would get between 110-120Kms (with the light on) before I would even look to fill up.
Your probably wondering how I have such high numbers? It's highway to work and back everyday and my car is still stock, well for the moment it is
Just don't bring the thing on boost!
My turbo R33 with exhaust, FMIC, a couple of other small things, will do 460km, and used 54litres,
Mind you, there was MANY a time I hit redline pushing 12PSi down it's throat, but alot of cruising off boost also.
Keep it under vacuum, use the natural "pull" of the motor, and it'll cruise efficiently, generally, when the car goes to "take off" after a couple of seconds, roll off the throttle slightly, or upshift. I keep mine below 2500 RPM for fuel economy. Otherwise, give it aboot full!
If worried on fuel economy, buy a 1990 Barina/Swift, drive it daily, get a hypo liner for the weekend warrior work.
I do about 13.5L/100k, the first time I filled up after my sparkies change.. i'm like 14.7L/100k.. no idea why.. I'll keep checking =)
it translate to about roughly 380km to 50L of petrol
maybe I should change my O2 sensor as well? wonder how much it'll cost..
cheers
o2 sensor will set you back $120ish for a direct replacement NTK one.
and about $50 (roughly) for a falcon el one, which you have to splice some wires etc.
i just replaced mine last month and sorted out an o2 sensor earth grounding issue... will update with proper km per L figures soon
Make sure you do an O2 sensor diagnostic on your ECU first. I originally thought that my O2 sensor was a dud (poor economy), but after testing it i found it to be fine.
any hints on how to do it? =)
cheers
http://www.skylinesdownunder.com/forums/sh...light=ecu+codes
Theres some info if you sift through that thread. I found I could more accurately monitor my O2 sensor using my new consult cable (gives voltages) but this should still give you an indication if your o2 sensor is porked.
    • I mean it's probably likely that people overestimate their skills in dialling in a setup and noticing the changes. I had SK shocks and springs, and added heavier springs and got them revalved by Sydney Shocks to suit based upon what I told them I wanted the car to handle like. I got back a completely different feeling set of shocks, which probably (?) feel great on track but holy hell are they rough on tram tracks and the like. Truth be told I doubt I'd be any faster or slower with either setup, or camber/castor combination. I also had whiteline eccentric castor bushes up front of my R34. I removed them and put in poly non-adjustable ones to soothe my OCD (nobody ever set the castor the same side to side, and it'd be near impossible to do) and be happy the wheel is centered in the well now for clearance reasons. Yes I wanted it to move 1mm 'back' :p I've effectively set my castor back to stock, negating all the benefits of that which is supposedly massive. I can't tell any difference steering the car.
    • You reckon? I have to disagree. Notwithstanding that at some point we may all be forced to do this to our cars if we want to keep driving them, there is absolutely nothing about an electric-converted-previously-IC-car that is ever good. EVs that are built by OEMs on platforms that were originally IC already suck, let alone the shitty outcomes that result from doing it as a retro to something that was actually built as an IC car. This is because the platform really needs to be designed to house the battery in a useful place (ie, down as low as possible) and the motors are properly located relative to the wheels that they have to drive. Converted platforms already suck at this. But when you try to shove sufficient battery capacity into a previously IC car, you can't put it down on/in the floor, because that space doesn't exist. You can't find enough space where the fuel tank used to be (if it is an inboard fuel tank) and you don't want to hang it out behind the rear axle line if you had a rear fuel tank. And there's not enough space in the tunnel if you still want to use it for anything remotely like what it was originally used for. The engine bay is too big for a motor, and you'd really prefer that the motor for the rear wheels wasn't in the front engine bay anyway. And there's not enough room where the diff was for a proper man-sized E motor. And then.... there is the complete lack of soul and emotion that is provided by EVs. There are some cracking restomods out there. Like the Alfaholics GTA thingo. But it is petrol powered. Look at the alternative EV version of a GTA restomod by Totem. it is jaw droppingly beautiful. But by all reports is is objectively awful to drive, despite having 600 HP or something, simply because there is nothing there. It sounds like a sewing machine or a leaf blower. It should scream and wail and make the hairs on your neck stand up. Oh, and it's 1500 bloody kg in a car that was <900kg when new. GTRs are heavy enough as it is without pushing them up to 2tonnes worth of pork.
    • https://www.dezeen.com/2025/01/06/nissan-electric-r32-skyline-gt-r-godzilla-sports-car/   I reckon this is pretty cool. Lots of other Resto mods have turned to ev power.
    • hahaha @joshuaho96 the most action it gets is when I have to drive from West to SE VIC to meet the fam. Even then, it;s on highway cruising speeds
    • don't know anyone in this thread, but i just found it, read the entire thing in a few hours, realized greg is still posting progress, and just have to say, this is awesome. it looks awesome. 100% right about the Uras kit making it a pain to get on hoists...have the same kit on my 34 and it takes six 2x4s and race ramps to do it without taking parts off. this reminds me exactly of this thread. https://grassrootsmotorsports.com/forum/build-projects-and-project-cars/r63-amg-the-unicorn-of-my-destruction/110824/page8/
