[group] ****nokia N91**** [buy]
Details: I’m organizing a Group Buy with a supplier on for the NOKIA N91 at an unbelievable price. All units come sealed with a receipt and 12 months Australia wide warranty.
Nokia N91
Music Player
•Intelligently designed music player - optimized for music listening
•Dedicated playback keys and volume control
•Enhanced on the go playlist management - edit playlists, add new music
•Meta data for tracks can be viewed and modified directly on your N91
•Enhanced music features: mixer, 5-band equalizer, loudness, music DRC (Dynamic Range Compression)
•See what is playing when the Nokia N91 is in the idle state
•Answer calls while listening to music and music pauses and then resumes again when the call is ended
•Smart integration with music services (easy access to music shop)
•Music user profile or sim-less operation allows for uninterrupted listening
•Transfer any multimedia content from PC to your Nokia N91*
•Download unprotected** new music over the air to your Nokia N91
Audio formats (decoding)
•MP3, AAC, AAC+, eAAC+, Real, WAV, WMA, M4A, AMR-WB, True Tones, AMR-NB
Hi-Fi Quality Sound
•Use the Nokia Music Headset HS-28 with remote control or use your own high quality headphone and connect directly to the 3.5mm audio jack on the Nokia N91
•Connect the Nokia N91 to external speakers via the CA-63U stereo audio jack
Record Music
•Make your own recording using voice record application
Visual Radio
•Flick on Visual Radio mode*. Add a rich new dimension to your radio listening. It's a snap to switch and a whole new experience when you do.
Digital Rights Management
•For protection/digital rights management for music files: Open Mobile Alliance (OMA) DRM 2.0 and Windows Media (WM) DRM 10 for portable devices
Operating frequency
•GSM/GPRS EDGE 900/1800/1900MHz + WCDMA 2100 *
•Data transfer: WCDMA up to speed 384 kbps, EGPRS/GPRS (class B/multislot 10) up to 236.8 kbps
Dimensions
•Weight: 164 g
•Length: 113.1 mm
•Width (max): 55.2 mm
•Thickness (max): 22 mm
Display and User Interface
•Color display (176 x 208, 262k color)
•S60 software on Symbian OS
•Automatic brightness control for display and keypad
•Music keys: Play/Pause, Forward, Back, Stop. Switch easily between music player and last used application with dedicated key.
•Keys: Two configurable soft keys, Send & End, 5-way configurable navigation key, keys for S60 (Menu, Edit, Clear), ITU-T (number/text) keypad, Volume (up & down), Power, Device lock switch
Memory
•Up to 4GB of internal dynamic memory for music content, multimedia messages, ringing tones, images, video clips, and applications
Imaging and Video formats
•Video playback: 3GPP H.263, MPEG4, RealVideo
•Image viewers: JPEG, EXIF, GIF, BMP, PNG
•Download and play multimedia files (video and music)
•Stream media files from compatible media portals
•Full-screen video playback on the phone to view downloaded, streamed or recorded video clips in larger size
Camera
•2 Megapixel
•Still Image resolutions: default 1600x1200, 640x480
•Still Images file format: JPEG, YUV, RGB
•Capture formats: H.263, MPEG-4 (video), AMR-NB, AAC (audio)
•Advanced camera modes: still, burst, video and options for night, brightness adjustment, image quality, and self-timer.
•Digital zoom 20x stepless
Connectivity
•3G - Near broadband speeds for faster and more responsive downloads.
• WLAN 802.11b/g *
•USB 2.0 full speed interface with mass storage profile (USB mini)
•Nokia PC Suite
Browsing
•XHTML browser
•Improved Web compatibility with support for HTML 4.01, including support for elements such as image maps, background images, and frames
•Support for a subset of JavaScript 1.5, which includes the most commonly used functions found on the Internet
•File upload over HTTP using standard HTML forms
•Small screen rendering option including a faster page-up/page-down scrolling style
•Full-screen mode, download progress bar, and adaptive history list
•3GPP video streaming
•OMA DRM 2.0 including forward lock for content protection, combined delivery and separate delivery
•Wallet: convenient online use and storage of your numbers and passwords
Messaging
•Convenient email client
•Compatible with Nokia Wireless Keyboard (sold separately)
•Multimedia messaging: combine image, video, text, and audio clip and send as MMS to a compatible phone or PC
•Automatic resizing of your high resolution images to fit MMS (max. 300 KB attachment size depending on the network)
•Text messaging: supports concatenated SMS, picture messaging, SMS distribution list
•Predictive text input: support for all major languages in Europe and Asia-Pacific
•Instant Messaging
Call Management
•Contacts: advanced contacts database with support for multiple phone and email details per entry, also supports thumbnail pictures and groups
•Speed dialing
•Logs: keeps lists of your dialed, received, and missed calls
•Automatic redial
•Automatic answer (works with compatible headset or car kit only)
•Supports Fixed Dialing Number, which allows calls only to predefined numbers
•Conference call
Java Applications
•Java™ MIDP 2.0, CLDC 1.1 (Connected Limited Device Configuration (J2ME)), JTWI 1.0
•Over-the-air download of Java-based applications and games
Voice Features
•Voice dialing
•Voice commands
•Voice recorder
•Integrated handsfree speaker
Package Contents
•Nokia N91
•Nokia Music Headset HS-28 (with remote control)
•Nokia Stereo Audio Cable (CA-63U)
•Nokia Battery BL-5C
•Nokia Travel Charger AC-4
•Nokia Connectivity Cable (USB) DKE-2
•Nokia Charger Adapter Cable CA-44
•Nokia Desk Stand DT-10
•CD-ROM containing software (PC Suite and other applications)
•User guide, Quick Start guide, and Add-on Application guide
Power Management
Standby time: GSM up to 190 hours*
Talk time: GSM up to 3 - 4 hours*
Music Playback: up to 10 hours*
RRP: $1149
GB Price:
10 Buyers Minimum = $850 + Postage
10 – 20 Buyers = $800 + Postage
20+ Buyers = $750 + Postage
GB Start/End Date:
18/12/06 – 9/01/2007
Postage: Will vary where you live or Pick-up in Sydney
Payment Method: C.O.D
How to order:
PM me with your full details and I will add you to the GB list and once I have at least 10 confirmations I will arrange for the phones to be posted out. Once I have 20 people on the list, ALL buyers will get the discounted price and then again with 20+ buyers.
Regards,
Sarkis
GROUP BUY LIST
1.
2.
3.
4.
5.
6.
7.
8.
9.
10.
https://www.sau.com.au/forums/topic/147788-group-nokia-n91-buy/
Hey Guys, if you have other phones or carkits in intrest feel free to PM me and let me know and ill see what i can do.. but for these prices, the Nokia N91 is unbeatable.. 4GB memory + 2MP Camera + WiFi!
Cheers
Edited by QRI05E
Awesome phone... I have one!
*edited, wasn't trashing your group buy. Just stated that was the price I paid for mine a week before the GB started - all legit through a normal retailer*
$700 sounds too cheap... i have called a few places and the cheapest cash price i got was $990... and please as the rules states, dont trash a GB if you can get it cheaper then good luck and dont post your comments...
Thank you
Edited by QRI05E
    • I haven’t taken them out of the cases yet    inside the box is this packaging which is pretty much like a massive blister pack
    • Purchased a NC MX5 a while ago Basic suspension mods done, BC coils and Whiteline sway bars  New DBA calipers, discs and pads Added some 17 x 8 Konig Decagrams with 215/45 17 PS5's Added some typical NA bolt on's, i.e. full exhaust and intake  Added 0.5ltrs with a MZR2.5 swap, nice bump in torques  Found a detachable hard top which is locked in for a colour match with my local paint shop in Feb 25, this also includes some PDR as it has received a few love taps from parking in the local shops when in the hands of my Minister for War and Finances, me, I park nowhere near other cars and typically park on the street The little thing is awesome, I drive it everywhere, it handles like a dream whether I'm up it or just cruising  But now,  because I'm a idiot, I keep looking at turbo kits....... did I mention I'm a idiot Why is dose so appealing  All of the NA 2.5 glory, well.......until sometime in 2025 anyway....🤪
    • I would not be surprised if you are the only person on earth that has the interest/desire to do that lol.  The Haltech base map is a really good starting point, the car will fire easily and drive very well, even on mild boost levels. To me, following your advice sounds like some sort of ancient Chinese water torcher lol (this is not an insult Josh, never change <3)
    • Those car show concepts from the 2000's and 2010's like the Floria and IDx were brilliant and should've gone ahead, at least one of them. But neither Honda nor Nissan are thinking about affordable performance any more, which is truly sad.  Even if Toyota's liquid hydrogen ICE development reaches the point where it's commercially viable and the infrastructure to support it, Honda/Nissan would have to wait until Toyota allow fee access to their patents to offer it with any smaller performance models they released to take advantage of it.
    • A sporty manual RWD coupe with a IL4 Honda engine would only be a good thing I assume we won't see anything released for a few years though, unless informal talks and designs have been going on for a few years,  and due to the current, and future, emmisions and safety requirements, I assume anything "sporty" they would do would be at least some hybrid thingie And hopefully anything they are thinking of has nice lines, without lots of plastic and fake bits hanging off it like that horrendous FK8 that looked like it was designed by a 13 year old The other issue of course in the current market is cost, currently the type R is around $70k, a twin is around $50k Meh, I'm old and grumpy and would rather buy a older model car and waste my coin on that than buying anything currently available new
