  • Replies 79
put me down for a set of fronts...1 LH and 1 RH. For R32 GTST 5 stud. Slotted only..not crossdrilled.
I do live in Melbourne...dont care if it takes a couple of weeks to get them here...ie slowest freight...
How do I pay etc....
Cheers,
Russ
OK guys go for it :)
The numbers so far...
R33 GTS25t
me front (2)
sciby front (2)
carlo front (2)
jlnewton front and rear (4)
Ginkgo Biloba ????? front (2)
R32 GTS-T
russcb007 front (2)
brody ????? front (2) 3 or 4 weeks
Freight for Brisbane or Melbourne will be about $25 for 2 or 4 discs.
Kevin from Gavsport has agreed to keep this open for another few weeks.
Please call him on 02 9673 0988or [email protected] and tell him you would like to be part of the Skylines Australia group buy that Dino set up.
***Order and pay direct through Gavsport. I don't want to see any money.***
Could you then please post here or PM me so I can get an idea of the numbers.
Thanks,
Dino
:D
man who knows... when calling DBA a few weeks ago the person on the other end didnt seem to have a clue, and had all the part numbers mixed up... so you could be right, but she gave me a price for x-drilled and slotted, so i assumed they made them!
Originally posted by jlnewton
Come on guys lets get those numbers.  Do we order now or do we wait until the numbers are up?
Originally posted by red900ss
OK guys go for it :D
blah blah blah...
:D
:D
Ok guys im in, gonna hold off on my tyres for another month or 4 and get these rotors. Not entirely sure I need them but I do eventually want to attend regular track days and these will come in handy for then.
R33 GTS-T Front + Rear please.
Edit: the sooner these arrive the better, otherwise i'll end up with something else i don't need.
Guest
    • Yep, the plan is to do some work in Japan, as I mentioned above possibly keeping it there longer than November 2025. Frankly, I'm not dealing with TopRank ever again and, because my car is no longer with them, I could work with BBL/GY directly👍 But alas, I'm not looking at major bodywork just yet.
    • Yeah I had the probes on the battery terminals.  Sounds good. What reading should I expect to see in a car that runs well?
    • I went for the scissor lift option, gives a 3ft lift at full lift. I wanted a 2 post but my concrete wasn't deep enough to secure it properly
    • Depending on exactly where that voltage is being measured, that is most likely the battery is f**ked. If the multimeter probes are on the battery's own terminals, then it is f**ked. If they are on the car's terminals, then there is a bad connection. Either are fatal to the attempt to start it. Literally just put it on the 20VDC range, put one probe on the battery's -ve terminal (ideally not the car's terminal) and the other on the block somewhere exposed/metal, like an engine mount bolt head. You can also test the earth lead is steps, so from battery to body earth, body earth to engine connection point, engine connection point to some other spot on the engine, to see if you can isolate where a shit connection actually is.
    • I meant to write 50 originally and then double checked the price and found it was ¥12m (125k) and came to edit it and realized I had accidentally added and extra 0 in the first place lol
