OK well i just got my car dynoed and here is the result. the mods are front mount intercooler, hks air filter, turbo back exaust with gutted cat, boost controller set to 10psi, SAFC, and a bosch 910 fuel pump,
also as u can see the car was dynoed at RE CUSTOMS and i cannot thank ray enough i recommend anyone wanting a tune or work done to head down there. i know ill be going back when i get a power fc which will hopefully be soon post-14524-1166431184.jpg
https://www.sau.com.au/forums/topic/147832-dyno-result-im-happy/
nice man. nar mine is black i was there on friday aswell and he chucked my car on the dyno and then i got the bad news my fuel pump shit itself so i brought a new 910 and O what a difference and he didnt really need to change my air/fuel somehow it was running great but he used the safc just to make it a bit richer up high end car goes great im so pleased. calder on wednesday should be fun
fantastic - let us know how your car goes on wednesday..... yeah u might have seen my car there on friday (white s2 r33). welsh plugs gave way when they were doing hte service, so had to change all that - now its running great. Gonna get more mods done through them (the exhaust was done thru them)
That is a very high result for a fairly stock car. especially for only 10psi. I think the dyno is being a bit optamistic. Also your power curve is quite wonky in a couple of places. it might have been slipping on the dyno :P
this was mine with only a couple of mods - done at RE as well
http://www.skylinesaustralia.com/forums/in...t&p=2753467
i could be wrong, but wouldnt the intercooler and the fuel pump increase the power output significantly?
That dyno reading is a joke, my car has the exact same mods and it sure as hell does NOT have 210kw at the wheels.
Somthing is wrong there.
With those mods id expect about 170rwkw.
cheers
your engine might be getting rather tired, or the dyno you went on under read to some extent (170kw is pretty low for those mods) and his over read to some extent.
for those mods i'd say about 190kw would be pretty accurate. remember that he does have a gutted cat.
ahh 170rwkw was just an estimate.
I havnt had my car dynod as yet but i hav those mods and im also putting on a batmbl front/drump pipe soon with a 5" body cat.
Haha pretty sure after i do that my clutch is sure to die a horrible death.
The only reason i didnt think i had that much power because i raced a mates stock 180 running 10 psi and he beat me by 1/2 a car length.
NOTE: race was conducted at appropriate race track
only way to find out if the power is correct is take the car down to the drags and compare the times/terminal(trap) speeds with others car of that power range.
no point comparing dynos.
my 2cents
My understanding behind shootout mode dynos, was to apply a correction so that most dynos could be compared. Now there is nothing wrong with the figures, as the correct mode was used and the air temps look right.
I am puting my money on either it running too lean, or you have a non-stock turbo in it (hi-flow / aftermarket).
Forget the figure, look at the power curve. something not right.
9 psi by 6h km/ph in 4th? looks like the operator held it on load untill he started the run. This is not really and indication on what the car will do on the street and will F96k up the peak torque figure.
Then there is a taper off and then an full 10 rwkw more at redline.
as long as the car holds boost correctly and the AFR's are safe the figure does not matter really. Still I have NEVER seen a car wth this level of mods produce more 190rwkw.
Glad you are happy with the result :(
Cheers!
yeah I have the same bs figure as well, 199rwkw before tune and 211rwkw after tune with a SAFC2. I must have gotten on a happy dyno as well, must get myself to a more moderate one to test out again, coz there's no way I'm gonna believe that. Although its fun bragging to people about it hahahahah
the only accurate way to compare timeslips from the track is to have the same person drive both cars. in a way they are like dyno readouts. 1 person may be a crap driver, but have more power and better tyres, suspension, etc, but still run a slower time at a slower speed than someone who can driver really well.
it should already be waaay rich with the new pump and stock ecu... he would have been leaning it out with the SAFC not making it richer
and no point running with a gutted cat unless you have a section of pipe put in there... just creates turbulance otherwise and no power gain
    • It only looks tidy, as most of the stuff that was on the whole back wall, is now in the trailer to go to the tip, or has been shoved in my 2.2x2.4m "Spare parts room", and now I can't get to anything in there Ha ha ha I could definitely do with a bit more space, but I'd just end up with your problems I'm going to enclose the car port beside the garage, and move a lot of stuff into it I think. OR... It will be setup as a fabrication area, and the main garage will have parts storage in it. I'm not sure yet... Need some pictures of that big shed you've got with the bikes and Skyline in
    • No. I think it's gone. 😭 I think you can get body coloured ones on eBay so I think I'll get one of those... Or just hang a red ribbon from the hole and whack a TOW sticker next to it.
    • Can't say I've had a bad experience with one on my car, then again it only gets washed once or twice a year... The wheels on the other hand, get a good spray often due to my shitty dusty pads.
    • @MBS206 thats pretty neat and tidy to me!  I'll get a photo of mine when I'm out there next. It might require multiple photos to understand the scale of the atrocities though... In total I have 4 sheds of varying sizes and layouts. Main shed is 14x8, second shed is 3x8, third shed is 11x2.5, fourth shed is around 6x4.  All are pretty much full.   The main goal of my cleaning tsunami is to make the main shed predominantly car and motorbikes only. Second shed is my metal fab room (2 x bench grinders, drill press, bench belt sander, metal band saw, scrap metal storage and some of my garden tools.  3rd shed is more bigger garden stuff, storage for engine crane, jack stands, concrete grinder, concrete mixer, air compressor lives there, and it now has two 2mx2m pallet racking shelves with itemised boxes holding building stuff, electrical stuff, plumbing stuff, etc, etc.  The 4th shed is Ryobi electric ride on mower, mini boom sprayer, ancient Kubota tractor, more garden stuff!  I have got a lot of shit....  Then there's the pool house (8mx4m) and the pool pump shed (4mx4m).  I built all of the sheds over the 11 years we've been here.  The main shed was a Ranbuild kit, the rest are all custom made to fit the areas available. Building the main shed taught me a LOT as I had no idea about building anything prior to that!  I've still got one more in me. It will be my man cave which I poured the extra concrete for way back when I poured the concrete for the main shed. The idea is the Skyline will be a centre piece of the main cave once (if...) it's finished.  I told my now 14 year old son yesterday that I will 100% drive him to his year 10 formal in 2 years. Still a long way off but at least I now have a date to work towards! 🤣
    • Modern oils are amazing. Add tyres to that as well.
