Hmm so i got done a while ago by the EPA (was on the way back from a workshop and my split dump was missing a few bolts, thats why i got done) I took it up to the testing place, and got 3 readings of 105db. I was sorta shocked, people always saying how quit rb20's are, i've never been pulled over before, personally think it's quiet and have had a few friends and a mechanic or two tell me it'll be fine.
So now i gotta quiet it down (for 2 weeks, then i can go back to old zorst) Now i'm trying to figure out what is the most cost affective/easiest way to do it. So far i've come up with borowing a stock cat back from some one/buying one, and running that.
If the rest of the system is still 3" do you guys reckon the stock cat back will quieten things down nuff or am i gona have to get some baffles or something?
The exhaust is 3" split dump - CAT then 3" back to 5" hks super dragger muffla
https://www.sau.com.au/forums/topic/147840-exhaust-to-loud-on-a-rb20-o/
I have a stock zorst from the turbo back if you need it, but I'm going to Brasil in early january, so if possible, I'd prefer someone to buy it, for SAU members, I think $50 is fair. It includes a compliance cat, front pipe, dump pipe and cat back. No gaskets though, but they come cheap.
Let me know if you want it.
-Josh
I have a RB20 non turbo too, it is very loud, the rest of my system is 4inch through from the muffler to the other end of the car, so im pretty sure that has something to do with it
u have what on an n/a :|
it all depends on mufflers size and design ... i dont think you have a resonator (middle muffler) or if u do, its almost non exhiistant, throw a stock system on, and have trouble hearing the car ...
im used of my car, its damn loud, and ppl tell me how loud it is, i dont realise it, but i know it :(
although when i yell what at them, tis a bit of an indication :|
chuck a stock compliance cat and cat back on, and u will have no problems passing emmisions and noise :O
The exhaust guy quoted, 300 for cat back with 2 1/4 inch piping (which they'd take off for me 2 weeks later)
I'm thinking buy that dudes zorst from cat back, take it to midas where hourly is only $40 and it'll be 2 hours max, i spose. So yeh Josh i'm interested in it (cat back), preferably tonight if possible
Edited by 123456
i just got rid of my epa last week. all you need is to replace your hks muffler with the stock one. i run a 3" turbo back - 3" hiflow cat - 3.5" cat back - 4.5" cannon. took out the cannon, use my stockie and read 84db.
ohh thats cool, even less to replace, the muffler will just be bolted on i assume, was it easy to yank off and replace (How did you adapt 3.5" piping to fit the stock muffler, which takes 2/ 2 1/4"?, Did it fit on original mounting bracket thingoes)? Would be good if i could do it myself (rego $500, insurance 1900, speeding fine 400, the resulting broken window 400, wtf is with everything happening at xmas time)
Edited by 123456
my stockie has been cut and welded a 3" flange to suit the rest of system which goes down to a 3" at the flanges. pretty much a bolt-on bolt-off job and yeh it fit the original mounting brackets.
grab mine. The flange should be the same. If you have a set of ramps or wheel stands, it whould be a hour or two's work at most. You only need a 14mm ratchet and away you go.
I PMed you my number, let me know what you decide.
Was gona buy that guy aboves system and get it installed but my dad had already told the zorst guy that he can go ahead and make one up, zzzz. Ended up getting new cat back system, my old one was chopped and had pieces of 3" and 2 1/2" piping anyway, guys gona put a cheap muffler on for the moment and will put my old one back on later, he's also putting a 3" resonator in it. Am i likely to lose much sound from a resonator? I liked the way the car sounded and how loud it was.
Edited by 123456
K so the guy actually did it pretty cool it's got 3" pipe down to the join (3"-2") with 2" pipe near the end, which has bolts so i can change mufflers over myself
Now (and for the next 2 weeks) it looks freaking gay though -_-
Car spools at the same RPM as before which is a worry
(sry bout quality my fone is crap and can't display the proper car colour)
Btw, I'm still wondering if a resonator is likely to drop sound much, he put what looks like a 3.2" resonator/pipe thing in
(my mate just worked out it's now 1/10th of it's previous sound)
Edited by 123456
you are lost.
Just go get a stock exhaust from a wrecker/person on here and you will be right.
The stock exhaust for the ceffy is a joke. With all the mods on and stock exhaust, its so restricted that it sounds like its got a screamer pipe on it!!!
Nah that doesn't need sorting out it's all done, just wanted to know whether a resonator will drop noise levels alot or only a little or just change the noise, as i had one installed. Mine sounds the same actually (screamer) sounds like when my dump wasn't bolted on properly, soon as it hits about 5krpm, can tell the Edit: muffler, is flowing like a piece of crap, need 2 weeks to end already hehe
Edited by 123456
    • I mean it's probably likely that people overestimate their skills in dialling in a setup and noticing the changes. I had SK shocks and springs, and added heavier springs and got them revalved by Sydney Shocks to suit based upon what I told them I wanted the car to handle like. I got back a completely different feeling set of shocks, which probably (?) feel great on track but holy hell are they rough on tram tracks and the like. The shock dyno actually looks pretty similar to Shockworks (from what I can surmise from a screenshot of a youtube video - and my dyno printout...) Truth be told I doubt I'd be any faster or slower with either setup, or camber/castor combination. I also had whiteline eccentric castor bushes up front of my R34. I removed them and put in poly non-adjustable ones to soothe my OCD (nobody ever set the castor the same side to side, and it'd be near impossible to do) and be happy the wheel is centered in the well now for clearance reasons. Yes I wanted it to move 1mm 'back' :p I've effectively set my castor back to stock, negating all the benefits of that which is supposedly massive. I've probably also altered toe and camber in a negative (detrimental) way. I can't tell any difference steering the car.
    • You reckon? I have to disagree. Notwithstanding that at some point we may all be forced to do this to our cars if we want to keep driving them, there is absolutely nothing about an electric-converted-previously-IC-car that is ever good. EVs that are built by OEMs on platforms that were originally IC already suck, let alone the shitty outcomes that result from doing it as a retro to something that was actually built as an IC car. This is because the platform really needs to be designed to house the battery in a useful place (ie, down as low as possible) and the motors are properly located relative to the wheels that they have to drive. Converted platforms already suck at this. But when you try to shove sufficient battery capacity into a previously IC car, you can't put it down on/in the floor, because that space doesn't exist. You can't find enough space where the fuel tank used to be (if it is an inboard fuel tank) and you don't want to hang it out behind the rear axle line if you had a rear fuel tank. And there's not enough space in the tunnel if you still want to use it for anything remotely like what it was originally used for. The engine bay is too big for a motor, and you'd really prefer that the motor for the rear wheels wasn't in the front engine bay anyway. And there's not enough room where the diff was for a proper man-sized E motor. And then.... there is the complete lack of soul and emotion that is provided by EVs. There are some cracking restomods out there. Like the Alfaholics GTA thingo. But it is petrol powered. Look at the alternative EV version of a GTA restomod by Totem. it is jaw droppingly beautiful. But by all reports is is objectively awful to drive, despite having 600 HP or something, simply because there is nothing there. It sounds like a sewing machine or a leaf blower. It should scream and wail and make the hairs on your neck stand up. Oh, and it's 1500 bloody kg in a car that was <900kg when new. GTRs are heavy enough as it is without pushing them up to 2tonnes worth of pork.
    • https://www.dezeen.com/2025/01/06/nissan-electric-r32-skyline-gt-r-godzilla-sports-car/   I reckon this is pretty cool. Lots of other Resto mods have turned to ev power.
    • hahaha @joshuaho96 the most action it gets is when I have to drive from West to SE VIC to meet the fam. Even then, it;s on highway cruising speeds
    • don't know anyone in this thread, but i just found it, read the entire thing in a few hours, realized greg is still posting progress, and just have to say, this is awesome. it looks awesome. 100% right about the Uras kit making it a pain to get on hoists...have the same kit on my 34 and it takes six 2x4s and race ramps to do it without taking parts off. this reminds me exactly of this thread. https://grassrootsmotorsports.com/forum/build-projects-and-project-cars/r63-amg-the-unicorn-of-my-destruction/110824/page8/
