My 32 4 Door Drifter - Stadium Drift Pics And 3071r Pics * Check Last Page*
  • Replies 156
gonna be in primer for the prac on Sat?
haha nah, i'll have a few laps of someone elses car tho :P
Colour isnt huge change, just a slightly lighter shade of red, with a coarse metallic flake in it. I just wanted to tidy the car up, get a kit on and make it look nice.
Sliding Performance has jumped on board as a sponsor.. so Massive thanks to Aaron at Slide for his help so far.. should have some wicked looking stickers on the car soon and for SD at lala.
well cars all painted. thank god its over thats all i can say, im seriously sick of sanding, prepping and then the stress of painting in your backyard while bugs and shit land in your paint...
anyway it came out ok, couple of runs in the clear coat, and a few dust specs.. but looks ok for a back yard job.
Never mind the stock bumpers.. they havent been painted, hence the difference in colours. Ive got a roadworthy inspection tomorrow so its stock as a rock atm... After that on goes the stickers, kit, wheels, susp etc etc al;l ready for DA/SD at mallala!
  • 1 month later...
Hey kids, bit of an Update.. i bit the bullet and sold the RB20 package to a local and bought an RB25 front cut! So very soon it will be residing in the car with some performance goodies to go with it.
Got a clutch to go in straight away before the motor goes in the car, then a Sliding Performance turbo, ecu and a few other goodies... Once ive finished with it it should make around 250-270 rwkw. is niiiiiice :)
crazzy Simon, best looking 32 going around!
No offense to simon intended, it is a very nice car.. but this statement is kind of offensive there are several cars in this section which could arguably be as good looking?
Edited by Sarumatix
    • Yes, but it's not as easy as pulling a fuse on anything other than an R32. There's a routine you have to do, involving disconnecting a loom plug and bleeding down the preload.
    • A question for tuning awd, is it possible to disable the AWD? The stagea is an EA/T AWD, Toshi had said on a GTR, he was able to disable it and make it 2wd. Just wanted to double check if this was possible
    • Whoa, that's a name I've not see for a long time! Sorry to hear about the engine / turbo damage.  Fwiw with any engine problems it often really a case of just seeing what happens when it's apart, ymmv - I wouldn't rule out the possibility that the damage isn't even from the turbo failure, or possibly from a combination.  The airflow between cylinders isn't dead even, injectors can go off over time as well, with the turbos overboosting if you didn't have upgraded fuel system there could have possibly been a bit of leaning out - stock triggering is often a bit unreliable by this age too.  Basically its an old engine and a few things could have been going on, and you won't know how much work is needed until the engine is apart.
    • I'm just shocked there's a euro driver on our roads who is thinking of other road users and not attempting to blind everyone. I wonder if Prank uses his indicator too...
    • Its hard to tell really. The Q50 owner's forum talks about it a lot and has quite a few people directly affected, but no idea what % of cars sold actually had the block replaced. Also, there seem to be 2 distinct issues which both get diagnosed by Infiniti as requiring a block replacement (no wonder they are going broke) 1. "Porous block" where coolant mixes with oil through thin or poorly cast parts of the block 2. Head coolant gallery plugs not sealing. If I was noticing engine coolant loss I'd start with cooling system pressure test (as always) and then I'd pull the cam covers and reseal the coolant gallery plugs on both side before worrying about a potentially porous block.  If neither of those did the trick it would be put in a second hand engine out of japan; I haven't checked pricing but I'm sure there are plenty around by now as they've been in production 10+ years
