My 32 4 Door Drifter - Stadium Drift Pics And 3071r Pics * Check Last Page*
Simon-S14
 Share
  • Replies 156
that pic looks tuff.
so what mods are you running to get the 200 at the wheels?
and what brand tyres are you running to produce all that smoke as i belive it is mainly to do with tyre choice as far as smoke goes? maybe?
too bad about the acedent as you have only recently painted it.
thoes vids are tops mate you must be happy with the car now. id love to come and drive on lala. i am taking my car to sa early next year to visit family and id love to go for a run on there but id be a bit conserned about breaking somthing.
I bought the clutch off slide, he didnt give it to me as a sponsored item, and it didnt work from day one! Asked him to send me another or refund it, he said he would send another... weeks went by and now he wont reply any of my emails/calls ect ect...
sounds like him, i only know of him but he sounds like a cockhead hey, ill get sum boys 2 rock up at his workshop if u want haha
  • 1 month later...
another update:
Just dropped my car off to All type crash to get work started on it... getting all dents and panels fixed up and a respray of the whole car, prob going a brighter red with some diamond flake in it which looks awesome in the sun! I started stripping the car this morning and decided, stuff it, im sick of the rear tyres always rubbing the guards (which are already flared) so i went all out with an assortment of big hammers and dollys and spent quite some time modifying the guards, both on the inside and the outside. got them out an extra 20mm i reckon!! looks pretty pumped now
Ive been invited to compete in the upcoming drift fest 2007 at calder park in dec... so all focus on the car and its prep will be going towards that comp, Its got a massive prize pool also!
 Share
    • That's the most absurd thing I've ever heard. I would go cut bellhousing over that monstrosity of a flywheel all day, every day. It puts a lot more mass further from the last main bearing. I've had nothing but problems with Collins in the past and refuse to ever buy their products again. I would not trust anything they tell you. He's playing his salesman card.  I'm currently at 640whp on a mustang dyno (~770bhp) with the intentions of running E85 and a lot more power this upcoming spring. Cheers,
    • Nah, it's not the reduced knock margin. It is a direct mechanical effect of having to initiate the combustion earlier, while the piston is still rising, which starts to exert combustion pressure on the rising piston earlier, making the rest of the engine work harder to finish driving the piston up to TDC where the combustion pressure stops being a negative and starts being a positive. Your modern engine that only needs ~10° to make MBT doesn't waste the other 10 or so degrees of crank rotation. That's almost all of it. The difference in knock margin might go either way. Remember that modern engines to which you are currently comparing the long tractor engine (the RB) are now running super high compression, direct injection, tricky cam control and maybe even cylinder pressure sensors. You're not comparing apples with other fruit. It's apples and sea weed, or some other evolutionarily primitive vegetation. And remember, squish only really comes into play at the very end of the stroke. It certainly does good things, but it is not the biggest contributor to what's going on. It is quite possibly much less important in 4 valve head than 2 valvers also, because there is so much less squish available to a 4 valve anyway.
    • Food for thought, a longer stroke motor would need less ignition timing vs. a shorter stroke motor requiring more ignition timing.
    • Thanks Duncan, HART is only 10 mins from me (I did my bike license there), it'd be awesome if it ran these types of things.  Sutton Road does look good and they take fewer cars than SMSP which is good.  Surely you have enough land to lay a few million tonnes of concrete and some sprinklers D?
    • I thought an engine that needs more ignition timing to make power is going to result in less power due to reduced knock margin? More time for the combustion to propagate -> more time for it to heat up the rest of the mix to detonation.
