My 32 4 Door Drifter - Stadium Drift Pics And 3071r Pics * Check Last Page*
cant find one cheap tho... thats the prob, i dont want a genuine one but rather a copy will do, but i cant seem to find any copies that acctually have the full sized GTR intercooler opening... a few that ive seen lately only have stock GTST bar sized hole.
  • Replies 156
  • 3 weeks later...
Im not a fan of them but hey each to there own. And Simon is an excelelnt driver so if i dont look at the rear lights when he does a solid run out at Mallala it will be ok.
PS.
I have a perfect Accident finish white front bar here for you if you need it. LOL
Free of charge if u come and collect it now hehehehe
Edited by R32_4door_drifting
haha cheers man but i've got a bar on the way now :)
Took the turbo off and sent it back to Slide from sliding performance to change the rear housing and wheel to that of a smaller one. want to try and get it to come on earlier and harder, while still making same if not more top end grunt.
should be out at lala on feb 10th anyway
    • Isn't there a fitting on the back of the balance tube? That's what the OEM boost gauge uses.
    • Getting a decent signal from all 6 throats is a challenge. I don't know for sure, but I suspect that the stock balance tube is not ideal for it. I have done it on an ALFA 4 cylinder (about 35 years ago, so don't ask for too many details). We drilled 4x holes in the manifold runners, put in some fittings and ran hoses to a decent sized (I think it was about 20mm diameter) pipe that ran the length of the inlet manifold. So, it was quite a decent volume. There is a "tuning" balance to be found between the volume of the common plenum on such a thing and the diameter of the pipes running from it to the runners. You need the volume to be large enough to damp out the sharp spikes in pressure signal you get as each runner gets sucked on by its cylinder, but not so large that it becomes too slow to respond to actual changes in MAP. And you need the hoses to be small enough to transmit the signal quickly, but not so small that they delay the signal. You might have to have more than one go at it, if there isn't any actual success based wisdom to be had here. Hopefully there is. Anyway, I would not do it on only a couple of cylinders. I would also not care about "permanently modifying a part". Just bloody drill holes and make stuff better. There is nothing sacred about any GTR unless it is a genuine museum piece that you shouldn't be modifying at all anyway.
    • He's still joining you, he's just delayed it and won't have the fulleh sick ITBs...
    • The strange thing is this is a URAS front bumper (or clone of it). The bumper actually does not sit flush with the GTT hood - You need the addon to make the hood 'long' enough to reach the bumper. I have no idea why they didn't incorporate this piece into the bumper itself.. instead of sticking it to the hood instead.
    • Another thought on this OLD topic: When you paint your bonnet lip, leave a small unpainted back lip/line along the back of the lip, where it rests on the bumper. That way, the line in the back is much more prominent than the gaps in the front/under the lip - and it breaks the hood-to-bumper connection at the "correct" place, when comparing to a GTR. I'm gonna do this with mine this week, so stay tuned for pics!
