Well i was being an idiot in my car giving it a real workout on a pretty warm day. Since then my car has been making a weird hobering noise kind of like the sound ufo's make in movies. It's coming from the timing belt area. I was wondering if anyone would have any clue as to what it is. I took it to one place and they think maybe my timing belt is on too tight? Could this be right???
https://www.sau.com.au/forums/topic/147845-hobering-noise/
Yeh your right i have recently changed the timing belt. So you don't reckon anything has warped or bent or anything. One person tried telling me my cam shaft may be bent as my distributer moves alot when the car is turned on. Remember its a rb25det.
https://www.sau.com.au/forums/topic/147845-hobering-noise/#findComment-2759358
Mate, sounds like your timing belt is too tight... you had better loosen that sucker because if they are too tight, they can snap! then you'll be pulling your engine apart to replace bent valves, etc...
The heat makes the belt even tighter so be careful.
what are you talking about with the Distributer?? bent cam?? I don't think so... Are you talking about the CAS on the front of the exhuast cam??
https://www.sau.com.au/forums/topic/147845-hobering-noise/#findComment-2759377
I would check for some kind of weird green men that say;
"I come in peace" :P
or check your mechanic hasnt accidently put the ufos engine in your car and the Rb in the space ship, there could be some aliens out there goin whhoooooorrrrr PSHHHHHHHHHH, sick drift bro.......
https://www.sau.com.au/forums/topic/147845-hobering-noise/#findComment-2759602
    • I don't know for sure, but I'd expect them all to be interchangeable given the diff end and hub end don't move/change between any C34 series. Often Nissan will change part numbers and the aftermarket follows those year ranges; but the original part number change doesn't mean other parts won't fit. The change could be a change in material, internal parts or even just supplier. For example, all the RB gearbox to engine bolts are no longer available and there is a new part number instead. The only change is they went from cadmium plated bolts to zinc plated due to the issues manufacturing with Cadmium. They look different but work the same.
    • One year is a bit concerning. Did you try contacting GSP? It says 5 year warranty on the box if I remember correctly. I'm also running their driveshafts on my S2 Stagea.   You could check the part numbers on Amayama for your year. Here's the link for my 1998 which gives the 39100-23U60 part number. Well, that and 39100-23U70. https://www.amayama.com/en/genuine-catalogs/epc/nissan-japan/stagea/wgnc34/6649-rb25det/trans/391 What does it say for yours?
    • I ordered a GSP Front R/H Axle from here - https://justjap.com/products/gsp-premium-front-driveshaft-r-h-nissan-r32-r33-r34-skyline-gtr-stagea-4wd#description It lasted around a year before one of the boots blew out. I'm lowered, but I have GKTech roll center adjusters. One year seems a little premature. I think I'm going to spend the extra money on an OEM cv axle this time. This website - https://tfaspeed.com/collections/nissan-stagea-wgnc34-x-four-parts/products/nissan-stagea-awc34-260rs-rb26-right-front-axle-drive-assembly Makes it sound like the readily available OEM CV axle will only fit 11.1999 Stagea and up (mine is a 2.1997 S1). The JustJap listing didn't mention any years or anything for the GSP axle. Amayama shows '11.1999' and up as well for that part number. As well as 'plastic boot type'. See attached picture. So I guess my question is, does that axle (39100-23U60) really only fit S2 Stagea? It's the front driver side. If it does, I'd love to buy that instead of rolling the dice on another GSP. I've found that OEM one cheaper here: https://www.partsfornissans.com/oem-parts/nismo-jdm-r32-r33-r34-skyline-gtr-r32-gts4-right-front-axle-3910023u60 and here https://www.nissanparts.cc/oem-parts/nismo-shaft-ft-drive-3910023u60 Just a little confused because the JapSpeed listing for the GSP front driver axle doesn't mention any specific years or anything and it fit my S1 Stagea fine. So will 39100-23U60 fit my S1 Stagea even though technically it says '11.1999' and up? What would have changed? Thanks.
    • Thanks for the info. The only "Issue" I've had with the shifter is I always found the throw between 4th and 6th gear too close. I'm always worried to shift into 4th accidently and sending my motor to the moon. Adam LZ recently came out with a video and stated Serialnine revised their shifters to correct this and will change all the revised parts for 150$. Strangely enough, I contacted Serialnine right after and they denied it and said it's bullshit. I found that strange as he's a distributer. I'll keep this forum post updated on that saga.
    • Yep that is correct. It allows you to adjust the short throw range from what I can tell
