I've got a single Gull Sports reclinable seat (a lot like Recaro), its got a few small holes as per the picture but 1/2 of it has been recovered. Mounts up to Recaro rails and some Bride rails. Very very comfy as most of these seats are. $230 neg.
post-4038-1166437630.jpgpost-4038-1166437680.jpgpost-4038-1166437722.jpgpost-4038-1166437759.jpg
Also a pair of RB HKS Cam Gears, only done dyno time on two.06l. These are the older style so as long as you run with the cover fitted and timing belt tightened to factory specs they'll be fine. $270 neg.
post-4038-1166437801.jpgpost-4038-1166437839.jpgpost-4038-1166437880.jpgpost-4038-1166437928.jpg
PM me or email [email protected]
https://www.sau.com.au/forums/topic/147847-gull-sports-seat-hks-cam-gears/
No it doesn't come with rail and its a single seat.
I'm in Toowoomba or Gold Coast depending on the day. If you're serious i could put it in my car when i come down that way next (will be driving to GC on Wed morning and back on Fri night or Sat morning).
My bad. Thought you had 2 for sale. It seems I need some sleep. Thanks anyway.
Depends how wide i spose :teehee: I'm fairly tall and skinny and i've got room to move, i just got my brother who about 3" shorter and 20kg heavier to try and he found it snug, but not uncomfortable.
  • 3 weeks later...
    • Only needed to pull out the seats, center console and gear shifter surround, took a weekend and a fair few beers. You get to look forward to finding all sorts of weird shit under the seats and carpet, I pulled out a Chinese dudes passport from 2003, 220 yen and a condom wrapper 😆
    • Well, turns out not a lot happened from back then to now, between life again, and working on 3 separate other cars (only one of which was mine, and will now be departing the household soon).   So I decided with the whole "don't go outside, it's a cyclone!" Turning in to being not a whole lot, I ventured down to the garage, found a couple of water leaks in the shed (the main one I've already fixed), and then ended up "stuck" as it started pouring rain, and I didn't want to walk back inside in the pouring rain. This meant I ended up taking a look at the Skyline, and trying to work out what past Matt had been upto. I retraced a few things out from scratch, added the rest of the power feeds in that I needed for the indicators, and headlights. Double checked I'd wired a few things up correctly (and worked out how I wired a few things to begin with), updated my sparse notes. Added one of the ground points. Oh, and got really really dusty, as the car is quite dirty. Wrote up quickly what should be left for me to do with the wiring too. Adding the below photos more for my records than anything else. I need to make myself a proper book for the car that details everything, and how I've done it, but for now, this is my records... The third image is my most important one for me, and I need to draw it out into a proper schematic eventually. The last photo is my re-written list, I'd have put it on the white board, except I had to take the white board down to fix one of the water leaks.
    • Can try Maxima. Or random Infiniti models from the same era. Good luck with your hunt, let us know what you find!
    • Shall we... wake you up when September ends?
    • I got the Repco video recommended on YouTube.
