does anyone know what Monsta brand products are like, i havent heard much about them, i've been looking at getting some stuff of theirs, just would like to know if anyone has used or has any info on what they r like. cheers
I wouldn't buy a cooler from them as
its most likely a truck core.
However, for my Silvia I bought headers
and a split dump from them and never had
any issues.
In regards to intercoolers, Flying Performance on
ebay do genuine Hybrid kits for $650 delivered Aus. wide.
Cheers,
Bill
i have seen one of the coolers up close. not that good, and they don't flow that well. they are a bit restrictive once you start to raise the boost.
also the bovs are absolute crap. i know a few guys that have them fitted to their cars (not by them) and they are very slow releasing.
monsta coolers are crap, mate fitted 1 and like in previous replies, struggled to maintain when we raised the boost.
if you want a quality intercooler, 1 i have fitted to my 33, call GK technologies on 0401 554 476, speak to greg krusse. he sells the kits complete with piping for 400 plus 20 postage or pick up from melb.
cheers
ps. not genuine greddy. sprayed on during car re-spray
Edited by cheez
I had a manifold from them on my 180sx, needed a bit of tidying up around the ports and turbo flange to clear up some rough edges and rough welds. Also needed to elongate the stud holes on the turbo to make it fit onto the studs in the manifold as they were not tapped straight. Even thou I had to do all this still was good for the price (even after with the extra $$$ having to get it fixed up).
cheers
I fitted a GK tech and its still going well...I will probably upgrade soon but for the bucks its a good cooler that seesm to get results. I had not issues up to 260-270rwkw...for aorund $500 its a damn good product,
    • Boot is going to be replaced eventually. I just wire brushed what I could and rust converted. Then painted in rust kill primer. the spoiler also got repainted and plugs replaced on the ends. The under side of the bonnet is going to be black also, currently white. But red on the top side, same colour code as the silo to begin.
    • Hi guys, has anyone either purchased or built themselves a rotisserie for their car before? I can only just justify the need for one hence why I should just make one but at the same time, if I make one I can kiss another 4 weeks of potentially productive car working time goodbye because I'm building a bloody rotisserie....  I mainly want it for the application of the body deadener.  Cleaning the old stuff off, priming and then colour over the deadener doesn't worry me, it's just the application using the Schutz Gun that I feel would achieve a significantly better finish painting it side on and keeping the Schutz Gun upright.  I don't think they would work well on the side let alone almost upside down for some areas.  If the product I use (Terosun, etc) could work through a HVLP ok then it might be ok to apply without the rotisserie.   I can get one of these style ones for about $1200 which is pretty good value-     I reckon if I made one it would cost around $500 but it's more the time that it would take is more of a killer than the cost.  They look to hold their value pretty well second hand so I could always sell it after using it and realistically only lose $200-$300 at worst.  Or keep it and buy another project when this one finally sees the light of day... Anyone selling one...? Cheers!
    • While it is a very nice idea to put card style AFMs into the charge pipe (post intercooler, obviously), the position of the AFM and the recirc valve relative to each other starts to become something that you really have to consider. The situation: The stock AFM is located upstream the turbo, and the recirc valve return is located between the AFM and the turbo inlet, aimed at the turbo inlet, so that it flows away from and not through the AFM. Thus, once metered air is not metered again, neither flowing forwards, or backwards, when vented out of the charge pipe. When you put the AFM between the turbo outlet and the TB, there is a volume of pressurised charge pipe upstream of the AFM and there is a volume of pressurised pipe downstream of the AFM. When the recirc valve opens and vents the charge pipe, air is going to flow from both ends of the charge pipe towards the recirc valve. If the recirc valve is in the stock location, then the section between it and the TB doesn't really matter here - you're not going to try to put the AFM in that piece of pipe. But the AFM will likely be somewhere between the intercooler and the recirc valve, So the entire charge pipe volume from that position (upstream of the AFM, back through the intercooler, to the turbo outlet) is going to flow through the AFM, get registered as combustion air, cause the ECU to fuel for it, but get dumped out of the recirc valve and you will end up with a typical BOV related rich spike. So ideally you want to put the AFM as close to the TB as possible (so, just upstream of the crossover pipe, assuming that the stock crossover is still in use, or, just before the TB if an FFP is being used) and locate the recirc valve at the turbo outlet. Recirc valve at the turbo outlet is the new normal for things like EFRs anyway. In the even of a recirc valve opening dumping all the air in the charge pipe, pretty much all of it is going to go backwards, from the TB to the recirc valve near the turbo outlet. But only a small portion of it (that between the TB and the AFM) will pass through the AFM, and it will pass through going backwards. The card style AFMs are somewhat more immune to reading flow that passes through them in reverse than older AFMs are, so you should absolutely minimise the rich pulse behaviour associated with the unavoidable outcome of having both a recirc valve and an AFM in the charge pipe.
    • Yep, in my case as soon as I started hearing weird noises I backed off the tension until it sounded normal again. Delicate balance between enough tension to avoid that cold start slip and too much damaging things.
