Yea we had run-ins with the locals when i went to bundah college too. One night at a party on arunta st my mates immac. Pug 504 got smashed into and the seat belt buttons smashed ! it was the most random thing ever.....Too bad a few of us caught up to them towards gowrie court, and lets just say we had no mercy. (like the cops would care anyway)
https://www.sau.com.au/forums/topic/147852-rant/page/2/#findComment-2761618
What do we expect? Society has taken the power to discipline adolescents away from the parents and the schools. The little darlings have been taught that they are "special" and "unique", they can do no wrong. There are no moral absolutes being taught at home or in the schools. There is no reason for them to act decently, socially incorrect behaviour goes unpunished. They are fed a steady diet of anti-hero "violence is cool" message from the mass media. Where are they too learn decent standards of appropriate behaviour?
The blame lies on my generation for abolishing ethical standards, and teaching that individual "rights" are more important than a responsibilty to your fellow man and world. I could go on, at length, but I don't want to start another spanking/no spanking thread. Instead, my sympathies to the injured party, I hope the damage is less than it appears right now, (I know from personal experience that head wounds bleed profusely, but your brain box can sustain an amazing amount of damage and be alright), and you are, physically at least, quickly healed. The mental shock will probably take longer.
I just read this on another forum else where. The OP (in Scotland) had been hit over the face with a bottle and had a knife waved in his face by a bunch of young teenagers.
I think this response from another guy sums it all up.
It's also somewhat comforting to see that this isn't just a Canberra thing. So the next time some young punk puffs up I think I'll give him a piece of my mind.
https://www.sau.com.au/forums/topic/147852-rant/page/2/#findComment-2762284
Society these days is all about alleviating responsibility for your actions. You see it everywhere.
~ A Pub is responsible for you because you drank too much (till you walk in the door of another licensed establishment or your home.
~ Your employer is responsible for your massive accident simply because there was no sign saying "do not put your hands in the blender".
etc
the list goes on and on and on. Its stupid and its breeding a generation of people who simply will refuse to take responsibility for their actions and engage even a little bit of common sense - its ALWAYS someone elses fault.
https://www.sau.com.au/forums/topic/147852-rant/page/2/#findComment-2762652
    • Well, this is probably where a wiring diagram and a multimeter come into play.
    • I can say to anyone thats doing this; having done a number of R clusters; just be careful if its an unknown cluster.  It takes a bit of force to pull up; but if it feels excessive then its probably stuck. I've had this and pulled the entire hair spring out; and I can tell you; its not easy getting the correct spring replacement with the correct inner diameter and winding. In my case someone had used some sort of adhesive to stick it to the spindle and it pulled the whole spindle out; which the force seperated the hairspring from the spindal and caused it to deform.  You may have to clean it (IPA); or in my case if i'd known i should have used some sort of solvent on it.  Also check out Cruizin Central on eBay. He does all sorts of dials; and you can email him with any custom designs you want. So if you want like certain logos etc...he'll send you a mock of what it will look like then you accept the order and he'll take care of the rest. Fantastic dials and he can do basically any design you want.
    • Have you confirmed its the actual axles? Also the wheel bearings that mount on the hubs to hold the axles wear out. I replaced mine as they got play in them. It sorted my play issue.
    • Ive converted a few clusters for the R33 with 320km/h dials. On the back there are some pads which can be bridged or unbridged (using solder or wick braid) to calibrate it. There is one bridge which is for MPH <> KPH; and there are combinations of bridges to offset it. There is probably a diagram  For example; this is my conversion for a 180km/h dial to a 320km/h dial (I put custom GT-R dials on it with the GTS25t layout) If you have J2 soldered (assuming the S clusters have a similar config to the R clusters); you may need to remove that solder
    • Back on topic 😉, these are some of the notable pages from the booklets that are supplied with each weekly parts update. I never knew the BNR32 test mule car had an S13 Silvia front end... *Edit: On closer inspection the test car still had the R32 body, but only the front end had Silvia panels etc.
