I've got a warning light that only comes on when i use the brakes. It's the electrical warning light i think( it turned up when the alternator died, and when a tail light was out).
I've checked and replaced the bulbs, brake lights still work.
Any Idea's?
Here is a pic of it.
Edited by Traditimeour
https://www.sau.com.au/forums/topic/147867-electrical-warning-light/
dude i have had this problem i haven't read what everyone else has said but the light globe in your brake light is having a dodgy connection, obviously the connector on the globe itself has got a bit of rust or somehting, get someone to check which light it is take the globe out and scratch the rust off the entire experience takes all of 5 mins
thanks toffy :)
problem fixed. had a real close look at all the bulbs. one of the filaments was looking dodgey so replaced it. all good.
now if that same one blows again i'll be back. :P
lol i love cefiro owners how we are so worried about little quivels in our cars we seem to be quick to forget that the cars are getting towards 20 years old, we should be thankful they run!
...could you imagine lowrider communities?
"ey es'e! ey holmes my motor has gone bang eh puta, 30000 000 00 000 kms! what do i do?"
"ey es loco!!!"
"tacos"
    • I didnt present too many conclusions because I wanted your opinions and feedback based on your own experiences. I don't know the exact material, but it is similar to concrete and therfor only has valuable strength in compression. The forces on the set material once the head is removed would mostly be in compression since the grout wants to retain its shape and the block wants to return to its relaxed state since it's still within the elastic region. The grout would theoretically make the block more rigid. The exact amount would take a better setup on my end. Thought experiment: Instead of aliens, twist your favorite fleshlite. Now fill it with grout and allow it to sit for a week. Now try to twist it again. Observe what you see. Now get your other one and blow into it. Observe what you see. Now put it into a can and fill the space between your fleshlite and the can. After it sets blow into it. Less movement in torsion and less expansion i hope.
    • Hi. Yeah i think that DIS-008 should be ok too but i rather asked. The R8 coils are "sadly" no go for me cuz every solution is for forward plenum. The coils are too tall and one of the(4/5 DK) would not fit under stock J-pipe. And being this NA RB20 i dont even know where to get some forward plenum.(and of course i would need other stuff like custom AFM/ECU etc) and that is kinda non sense for NA without boost. I just looking for solutions for my case 🙂  I try look into those Yaris/Corolla ones.
    • Damn it, no, I topped up before I got to yours I really should look at Costco locations more when I'm out and about burning through fuel
    • Did you hit the one 5 minutes down the road from my place before heading back south? 😛
