Hey guys,
I have for sale one set of 6 factory conrods for RB26DETT.
Perfect for an RB24 project in a GTS-T, or ready for shotpeening and strengthening for use in your RB26 rebuild!
These are of no use to me now, and as such I am selling them off cheaply for a quick sale.
Chasing $150 for the set of 6 - Pickup available in Sydney
Happy to post at the buyers expense.
Thanks
Hey guys,
Chasing $185 for the set of 6 - Pickup available in Sydney
Thanks
will these fit an RB30,if so how much stornger (hp)are they and does it result in the same compression ratio
There is an RB25T engine at my work at the moment. I measured up the crank for size and it has rb30 mains and sr20 bigend sizes as standard. The RB25 be's are smaller than std. rb30 be's. I can quote std sizes if needed. For an RB30 you can use Chev 2" bigend rods (eagle/ carillo) and grind to suit (-.030'), or just buy a set of good rods to suit your application! I can't quote compression because I don't know the rod lengths. My 2 cents.
Hi, how much to send these babies to Brisbane?
PS. im still deciding either to mod (forged internals) my car or to sell it.
Edited by Blitz_R33
Well that decision is easy - mod it :yes:
Pm sent
  • 1 month later...
got an rb 20 looking at the rb24 woundering how much stronger are these hosepower wise
if u know give me a price 4 these sent to brisbane
RB26 rods are very strong and can handle 350-400kw without a problem.
Postage to Brisbane would be around $15
whre in syd are you? RB24 time me thinks -_-
North Ryde.
I know your at Sutherland - I may be heading to Just Jap tommorrow - Could meet you there.
Pm me.
Nick
    • They usually get made by hand as part of any such swap.
    • Was planning on getting an R35 MAF and the adapter, should this be okay? Also any idea where I could get my hands on an intake pipe?
    • I mean yes, if you're starting from scratch on an unknown engine yes you don't need to be doing all kinds of math in the background but if you're doing relatively minor changes like AFM + injectors + boost up with some aftermarket turbos it takes quite a bit of math if you want to do something like maintain OEM fuel + timing tables but compressed and then a bit more load scale up top. I think I've spent too much time working on big engineering nightmares though so I'm a big fan of trying to constrain the scope of whatever work I'm doing as much as possible and trying to get it right before moving on. For example, a local owner just did the usual E85 + single turbo conversion to his R32 GTR and nearly burned his car to the ground doing some spirited driving up the local mountains. Turbine is unshielded and too close to the hood insulation. It's tough to balance "just get the project done" and "seemingly small details can cause massive setbacks I'm not willing to deal with".
    • No idea about Neil's steering wheel, but I have the same behaviour in the Stagea. I doubt it has ever been messed with so might be normal. Indicating to turn right at a roundabout and correcting even a little bit to the left to go around will cancel the indicator. Never considered it an issue other than it being a bit odd.
    • Does anyone know if this is off centered? Looks like it, when I indicate to go right, but turn my steering wheel slightly left it cancels (was always like that even before I started messing around with it) was wondering if anyone else has the same issue?
