Just wondering what aftermarket ecu i can get for my skyline r33 gtst as i have no idea what to get ?? what ecus are good for the rb25det and how much does it cost ? do i have to get bigger injectors or can i stay with my normal ones ?? cheers
pfc, motec. microtec, autronic, linc, wolf, ems: $800 - 2000...piggyback, ie safc, emanage $200-500. i got pfc, easiest to use and value for money
4 standard turbo, standard injectors r fine
:P
Edited by moonus
    • It is an absolute lottery. They can and have died at stock boost with low usage at all. The turbos are now anywhere up to 36 years old!
    • Huh, wonder why it blew then. I never really beat on the car THAT hard lol I dailyed it and the turbo blew after 6 months
