Make sure there are no reducers/step downs in the piping from the rocker covers to the can.
You want all the piping to be the same diameter as the hoses coming off the rocker covers.
i dont htink step downs are bad as long as they are sealed properly and not letting out air.
do not block the pcv valves on the rocker, they vent so there isnt a build up of pressurised air in the rocker.
absolutely wrong - you can block the pcv on a turbo car, as the gasses just pass through to the catch can and then vent to atmo, or are plumbed back to the turbo>afm pipe
If you block the pcv, you may need to adjust the AAC valve so the car will idle correcltly though
RB engines breathe a fair bit, using reducers on the pipes to the catch can, or after the catch can, can cause crank case pressurising problems - but will probably depend on the degree of blockage, how fresh the engine is, and how much power you are making
best not to have any reducers.
does the catch can plumbing still have the pipe that goes to just after the afm? i have seen this pipe removed when people have installed catch cans so the motor is getting unmetered air.
if the new setup has a filter on the side that is sucking atmo air, not air from after the afm, then i'd say that is the problem.
    • Interesting, I haven't read about the issue with oil getting into the speedo in the cluster before. I'll have to take more notice with mine. The speedo on my R32's when I've run factory diff and tyre size have never been accurate as far as I can remember. The non Type-M GTS-t did come with 15" 5 stud wheels and smaller brakes, but that's less than 5% of them.
    • Good to hear the condenser you picked up off my brother worked all good. Do you think there could be an issue with your AC compressor itself or the clutch on it then? I don't know a lot about them so I can't really help but keen to hear what it ends up being. Keep the build thread going man, it's nice to look back on over time.
    • This is a story of my life things, I learned eventually (thanks to someone calling me out) that my enthusiasm for discussing and sharing ideas that it came across as arrogance and I'm like... WTF?!    One thing I'm pretty sure I justifiably pride myself on is knowing that everyone will have things they can teach you, and you're always going to find out that something you think you know turns out wrong - you just don't know what it is until you get there.   Just the bursting enthusiasm that comes with ADHD when you hit something that gives you dopamine dumps can come across like you think everyone else is wrong or don't matter. But yeah, I'm a software engineer by trade and also do tuning in weekends and 100% have long had a reputation for  quickly making connections when resolving problems or forming solutions that I've sometimes had to take people form a long walk from start to end to explain how I ended up where I did when it's seemed "too simple" when I've stated my initial case, and had the "WTF" type reaction when they've realised how much was actually considered haha.   My reward is that I get all the curly problems thrown at me.
    • Wives never seem to find things funny. Especially when they're trying to sleep, and you've found the new funniest thing ever. I've never seen someone be able to get try and be cranky with me, while they're holding back fits of laughter... 😛   Also, I tell mine it's payback anyway. She has BiPolar. So the household can get quite emotionally wild at times 😛
    • I'm not up to date on the latest, but for basic modifications like pod filter, lower springs etc you can get a modification permit at the time of inspection.  For more serious modifications you will need engineering.  Intercoolers used to fall into the mod permit rule but its been a long while since i looked it up.   Either way you will be able to get it registered, just a case of $300 vs $3k .
