Hey!
I’ve just got a quick question about PPQ.com.au – I’m not sure if anyone will know but someone might have done what I am trying to do. If not, I’ll just give them a call in the morning.
Anyways, I put some personalized plates on layby a couple of days ago I’m still waiting on the letter to arrive around two weeks they said.
However, I’ve had a change of heart and would like to change the plates to something else, is there a fee to this?
Thanks :P
https://www.sau.com.au/forums/topic/148027-ppq/
Did they ring you and confirm your plates?....if not then ring them up and change the type of plate to what you want. I'd say that if you have already put money down then it may be hard for them to change it.....I put my plates on layby but have not paid any deposit yet. They rang me a day later confirming the combination only.
https://www.sau.com.au/forums/topic/148027-ppq/#findComment-2762619
    • How much have you lowered?  I had 350Z springs in the rear and was able to pull the camber into factory spec with the factory arms on the rear, obviously the front ran negative camber as it isn't adjustable, but rotating the wheels regularly evened out the wear.
    • Either the installer needs to come back, you need an auto electrician, or you need to learn automotive electricals yourself.   First step Id look at is where that big thing came out of, is there still things unplugged at that location? Maybe they just forgot to put a relay in or something?
    • Well, this is probably where a wiring diagram and a multimeter come into play.
    • I can say to anyone thats doing this; having done a number of R clusters; just be careful if its an unknown cluster.  It takes a bit of force to pull up; but if it feels excessive then its probably stuck. I've had this and pulled the entire hair spring out; and I can tell you; its not easy getting the correct spring replacement with the correct inner diameter and winding. In my case someone had used some sort of adhesive to stick it to the spindle and it pulled the whole spindle out; which the force seperated the hairspring from the spindal and caused it to deform.  You may have to clean it (IPA); or in my case if i'd known i should have used some sort of solvent on it.  Also check out Cruizin Central on eBay. He does all sorts of dials; and you can email him with any custom designs you want. So if you want like certain logos etc...he'll send you a mock of what it will look like then you accept the order and he'll take care of the rest. Fantastic dials and he can do basically any design you want.
    • Have you confirmed its the actual axles? Also the wheel bearings that mount on the hubs to hold the axles wear out. I replaced mine as they got play in them. It sorted my play issue.
