this might be breaking the rules but ,
its the 3rd time ive tried to get a quote for some work and they NEVER call back
does anyone else have this problem ? are they usually like this ?
not trying break the rules and slander them or anything but just trying to find out if this is usual for them and I should just give up.......
Edited by arkon
https://www.sau.com.au/forums/topic/148043-speedworks/
They have changed hands and Matt is running it now.
I believe they are still setting up staff/tuners/mechanics etc atm so you may have to be a little patient.
Cheers
Ken
https://www.sau.com.au/forums/topic/148043-speedworks/#findComment-2762832
  • 3 weeks later...
hey dude i work at speedworks and as ken pointed out the place has changed hands and one of the office members has been in europe over the xmas break so we have been flat out trying to sort out new computer systems and of course get all the work done. It is sometimes easier to drop in and see us. Our work load is a little easier now so give us a call if u still need a quote done and we will jump straight onto it. I appolagise for any inconvenience this may have caused you.
Cheers froggah
https://www.sau.com.au/forums/topic/148043-speedworks/#findComment-2807622
Hey arkon
had no problems with them have on order a ssqv and they've contacted me tellin me it's all godo for pick up n stuff just depends think they are real busy this time of year though everyones rushin back from holidays n wantin to spend more money on the new year :PBJ:
https://www.sau.com.au/forums/topic/148043-speedworks/#findComment-2808499
    • btw... here's a fun quote I got back in the day (using a NEO head and going shimless): a bit different initial requirement
    • You can definitely do 450kW on the RB25 non-NEO head, plenty have. The $600 to $800 conversion will end up costing you much more I suspect, I believe you will require machining. NEO head has the lowest barrier to entry.   My 2c?  buy a BMW 😆
    • No more 90s JDMs for me, just want 4 door cars that won't attract cops. Wouldn't mind a Hako or a 240Z all motor but modernised (big comp, big cams, ABS, DBW, dis dat).
    • The reason I made this thread was to try to get some useful info as all of the older threads only have tidbits here and there, while I do appreciate banter and suggestions of shoe horning V8s into cars, for the sake of someone trying to make a decision on this topic - is the general consensus that you really don't need to convert to solid lifters unless you're chasing wild above average power and rpms? options -  Stick with hydro lifters possibly make 450kw at 7500rpms assuming all the right supporting mods for that goal Spend the $600-800 for the Solid lifters and find out how hard it is to set the clearances and what else needs replacing around them Neo head - possibly will cost more depending on the head prices at the time Throw away RB or buy a BMW 😆 There's a lot of the solid kits getting around from different manufacturers so someone must be doing the conversion
