Hey guys, im picking up my GTR on friday. I dont want to have to rebuild the engine any time soon so:
I know they tend to have a problem with the oil pump. What exactly is the problem? Would it be a worthy investment to upgrade it straight away?
Turbo's, the ceramic turbines seem to be a big problem, but if they go would they tend to do engine damage at the same time, or will it just kill the turbo/s then its as simple as upgrading? If they do damage the engine, im thinking i should upgrade them quite soon...
Are there any other known problems that is recommended to fix or upgrade in order to save me from damaging the car?
Cheers
Jon
https://www.sau.com.au/forums/topic/148053-r32-gtr-93/
The late model R32's, ie yours do not really have any problems with the oil pump. Leave it alone if it is working, ie providing the required pressure. Fill the sump with about 5 litres of oil (Assuming there is no oil cooler fitred)
The ceramic turbos are fine also. The only tend to self destruct when people put too much boost through them. Too much is generally regarded as more than 14 pounds. So don't do that & they will be fine.
Change the fluids (if not done already) Check the timing belt & change it if necessary. Look after it & don't drive like a dickhead.
Lastly, try the search function. Loads of useful information to be found there.
https://www.sau.com.au/forums/topic/148053-r32-gtr-93/#findComment-2763145
    • Which manifold mate? Meanwhile......Mark is wondering how bonnet vents would look on the NC 🤣
    • Actually,  just remembered there should be info in the threads (somewhere) about swapping to a manual steering rack and deleting power steering all together.
    • Also had a look at the Nissan JP website looks like the 400r has a slightly shorter ratio than than the regular V37 3.133 VS 2.937 which from a guy who has driven both 3.69 vs 4.11 ratios in the S15 is bugger all. Seems that the AUTO Z runs the same ratio as the 400R but can't find any info as to if its an open or LSD? More often than not the auto LSD is open
    • Do not replace the power steering lines with this stuff. If it's anything like the Chase Bays stuff it will leak and be worse than stock. The reason why the reservoir is on the LH/passenger side of the car is because that's just where the reservoir was most convenient to fit. Don't overthink this stuff. The intake/cold side of the engine is pretty busy on these cars. And again, the hardpipe is designed to be a janky power steering cooler. In theory you can replace it with a real power steering cooler but that's really only for track use where boiling the fluid is a distinct possibility. Start with the low pressure lines feeding the pump from the reservoir. Make sure there isn't a bunch of junk in the reservoir filter. Be careful to not get ATF all over the engine bay. I hate dealing with ATF spills, you can clean it up and the slightest crevice will still release more oil that can still drip over time. You also want to inspect for leaks before you make a mess and can't tell what happened. Most likely you have a leak somewhere that is allowing fluid out and air in. Failing that it's allowing air in but not fluid out. Only place I can really see that happening is on the low pressure side because the pump will pull a slight vacuum to draw fluid in. Everything after the pump is high pressure or lower pressure, approaching atmospheric by the time it returns to the reservoir.
    • I did a skidpan night at SMSP this week, it was much cheaper than $350. But yeah, you need to slap an LSD in that thing.  I put an OS Giken in the 370Z and it's f**king MARVELOUS even compared to Nissan's viscous LSD. So you're saying it's free now that it's a housing estate? 😂
