Hey all. I found out recently that my ecu had been modified while it was in japan (yeah and whos hasen't). They put a "Central 20, SPL Computer Brain" ecu chip in it. My questionis does any one know anything about these ecu's. I would like to get it reprogrammed but don't know where to go for this. I hear that these ecu's are not that common and not many tuners do these units. Is there a reason for this. What makes them so much harder to reprogram. I amm starting to consider changing it back to stock or getting a new ecu such as PFC.
https://www.sau.com.au/forums/topic/148056-modified-ecu/
i have a remapped ecu in my 33 and a non remapped ecu that was in the car when i got it.
not many people remap the r33 ecu as it uses different chips to the r32. there are a few places doing it, but i'm not sure who. i think there is a place in brisbane who do it, as my mate apparently had his r33 ecu done down there.
https://www.sau.com.au/forums/topic/148056-modified-ecu/#findComment-2763066
Na it hasn't got a daughter board in it. I opened it up and the square computer chip on the board has been replaced for this "central 20" ecu chip. The chip is in a holder and is removable. I hope to connect up my comp to the ecu and try out a few programs to see what i can get out of it. I will take a picture of the ecu tomorrow if i get time.
https://www.sau.com.au/forums/topic/148056-modified-ecu/#findComment-2765208
I have an Central 20 ECU on mine, well about to, i have tested it, made hudge differance ofer stock, plus 14psi was no problem. My mate had it on his RB25DET powered VL and it made 230rwKws with same mods as mine with sheets to prove it.
https://www.sau.com.au/forums/topic/148056-modified-ecu/#findComment-2765466
I have a few central 20 .roms
Mainly for RB20det. YOu will be running richer past 4000rpm and TP limit is changed to 255 thus getting rid of what people call boost cut.
Also quite often timing is also around 18 deg in most of the high load parts of the map.
Get it checked on a dyno :)
https://www.sau.com.au/forums/topic/148056-modified-ecu/#findComment-2765476
Yeah i ran the car on the dyno and only managed to get 157rwkw and it showed that it runs very rich the second it revs up. The chip inside it looks to not be one of those eproms that you wipe clean with a UV light and re-burn. Any one have any places i can call about getting something done with it. i will post up some pics of the dyno run and the ecu itself.
https://www.sau.com.au/forums/topic/148056-modified-ecu/#findComment-2765496
i am mearly ready off the chart that was provided by the tuner form the car, i know the tuner, and the car had an r34 turbo on an 94 series r33 det motor. The motor was stock, FMIC etc etc, but that's what happended, I am yet to test it on my car, but i will let you know. Just what i know, i know that seams high, but that is what it did. It certainly made a big differance in my car when i had it in there for a test.
https://www.sau.com.au/forums/topic/148056-modified-ecu/#findComment-2765723
after i had my remapped ecu on i borrowed a mates wideband o2 sensor and tested out my afr's. at around 3000rpm it goes up to 12.5 for about 500rpm then drops to 12 till about 5000rpm where it slowly drops down to 11.4 at redline. that was at 11psi as the boost controller was playing up and wouldn't let me go higher. cruise is about 14.5-14.7
when i get a chance i am going to test it at 14psi and see what the afrs are like.
https://www.sau.com.au/forums/topic/148056-modified-ecu/#findComment-2766842
Sounds to me like the dyno or tuner may have been pulling your c0ck :P
https://www.sau.com.au/forums/topic/148056-modified-ecu/#findComment-2766865
Yeah I think something could be wrong with my oxy sensor. Here is my run on the dyno and as you can see the air fuel ratio jumps straight to 10. I am unsure if this is due to the ecu being modified or what.
dynoruntt3.th.jpg[/img]
Any one have any ideas on my crappy dyno run. :)
Edited by jrocket
https://www.sau.com.au/forums/topic/148056-modified-ecu/#findComment-2767604
    • A locally delivered Infiniti have remote start installed but don't come with the remote start key. You need a new remote start key and they just need it programed. And this is different to making/programing a new key that just starts the car.
    • Cheers, and cheers for sharing so much of the build and also sharing the glimpse of what turns out to bring a lot of us poor decision makers together haha.  I do recommend learning more about how to manage it, if not considering getting a  formal diagnosis.  The discussion with the psychiatrist I got my diagnosis through was quite eye opening, things I'd not even considered to be ADHD related and hadn't mentioned were things she asked about out of the blue and were common themes with people with my flavour of ADHD.   It's not a label for people who are hyperactive and ill-attentive, there's more to it than that and some of it can be much more challenging or damaging - though there are of course two sides to the thing, and a lot of the stuff we have to go through and work on to live with it make us effectively "better" at other things as well. Aside from the fact that there is some argument I could have a bit of ASD seasoning in there (came up during the diagnosis, and neurodiverse things seem to not stay as a cookie cut) I suspect you need to learn more about ADHD if you are puzzled about how hyperfocus could possibly apply.  I *do* personally use "superpower" with quotes deliberately, but it's 100% an ADHD thing due to the exact reason that lack of focus is also an ADHD thing... Loosely speaking the inattentive side of ADHD isn't the inability to focus, it's the inability to control where the focus goes.  Not being able to sleep because brain is more interested in thinking about a stupid thing I said to a girl I liked 30 years ago, not being able to focus on work because my brain is more keen on putting together the torque management strategy we're going to try out with a drag car next weekend, not being able to focus on a conversation with someone I WANT to listen to and respect because there is a flickering light in my peripheral vision.    If I could just stop work and build the torque management setup right there and then I'd not hear anything else until it was done.
    • Maybe you should do some more reading.  Google positive effects of ADHD and you'll get your answers.  One of my personal downsides of ADHD has been talking before I think.   Maybe you have it too?
    • Excuse me for butting in....but which part of ADHD can be considered a superpower? I would have though it far more likely that some ASD comorbidity is more likely to be contributing to an ability to hyperfocus on something. ADHD being aimed somewhat in the other direction. My shed looks like your shed. My whiteboard list of unfinished projects has entries going back 15 years. I know what you're talking about - I just struggle to connect ADHD to the results being discussed.
    • Thanks for reaching out!  It's a blessing and a curse at the same time.  I'm undiagnosed but it doesn't take a rocket scientist to see it in me... I have more half started projects laying around my house, shed, garden, etc taking up space and money, destroying aesthetics than if I added up all of my mates projects together. But, ADHD gives me the ability to hyper focus on things that no mere mortal could even  comprehend.  A recent pool build is an example of that....  I dont know anyone else that would be dumb enough and focused enough to take on then complete something of that magnitude. I call ADHD a superpower but it can equally be completely destructive if not controlled and focusedon the right places. Addiction is a major concern to ADHD people and thankfully my addictions have been no worse than projects, XBOX, chocolate and being an arsehole! It's often hereditary and my 13 year old son is currently learning how to drive it at the moment. Keep lurking! If i can finally finish this bloody thing at some point it will be a win for all of us ADHD'ers! 🤪
