Dell Gx280 / P4 3ghz / 1gb Ddr2 / Sata / Dvd / Vista
Item: DELL GX280 / P4 3GHZ / 1GB DDR2 / SATA / DVD / VISTA
Website:
Item Condition: like new very good cond
Reason for Selling: dont need it
Price and Payment Conditions: $450
Extra Info: will post
Pictures: yes
Contact Details:PM me
P4-3GHz HT/ 1G DDR2 RAM/ 80GB/ Gigabit LAN/ DVD /Win XP Pro/ Vista Capable)
Hi All,
I have for sale a Dell GX280, this computer is super fast!
Don’t buy a slow computer buy this one! The item is working 100% and looks like new condition! This computer will run all your needs with huge 1GB of DDR2 Ram - Media centre, Vista, Video editing, DVD Movies, Games, Online etc…
Quick Specification:
Model (GX280 Desktop Computer) Link below for more information
http://support.dell.com/support/edocs/syst.../ug/sdindex.htm
* Pentium 4 - 3GHz processor with 1M cache and Hyper-Threading LGA 775
* Preloaded MS Window XP Professional (with Microsoft® Windows® License Label on side and Installation CD is included)
* 80gig SATA Hard Drive (SATA: 1.5 Gbps)
* 1G DDR2 RAM Installed (Maximum 4G)
* DVD Drive
* Floppy Disk Drive
* Integrated Sound AC97, Sound Blaster emulation
* Integrated Video integrated Intel Extreme Graphics
* Integrated Gigabit Network (Broadcom NetXtreme Gigabit 570X)
* PCI-E (PCI Express X16) (For all your graphics needs!!!)
* Two PCI slots
* 8 x USB2 Ports (6 @ back, 2 @ front), 1 x printer port and 1 com port
* Support Serial ATA Hard Disk
* Windows Vista Capable
* Local Pickup is Welcome
What you get:
· 1 x Dell GX280 Desktop Computer
· 1 x Power Cable
· 1 x Window XP Professional Installation CD with Product key
· 1 x New looking Dell Keyboard and Optical Mouse with scroll wheel
Monitor not included
    • Hows your intake piping? Are you still running stock? Having in the stock AFM position would mean, if the BOV was shut/venting out, it'd create the almost stalling kind of effect right // "the rich pulse behaviour" due to MAF thinking air is flowing ? But this would be better than having the bov in the stock position + MAF on/just before cross over piping right?
    • Essentially, yes. Although I wouldn't put the AFM on the crossover pipe. I'd want to put it into what amounts to the correct size tube, which is more easily done in the intercooler pipework. I bought a mount tube for card stile AFM that replaces the stock AFM - although being a cheap AliExpress knockoff, it had not flange and I had to make and weld my own. But it is the same length and diameter as the stock RB AFM, goes on my airbox, etc etc. I don't have a sick enough rig to warrant anything different, and the swap will take 5 minutes (when I finally get around to it and the injectors & the dyno tune).
    • So to summarise, the best thing to do is to move recirc to between turbo and IC, and maf on the crossover pipe. Meaning I'd need a recirc flange, drill a hole in the piping on turbo outlet area. And drill hole on crossover to fit/weld maf sensor? Either that or put the MAF on the turbo inlet right?  Is an aftermarket recirc/blowoff valve recommended? Do currently have family in Japan so could probably bring something back with maybe a cheeky lil SuperAutobacs run?
    • Yep, so far most have said that it looks like corrosion on the wall from piston not moving. Which then has probably damaged the oil rings and caused those vertical marks. The longest the engine was still after the rebuild, was the winter of 2018 - 2019, plus the boat trip to Japan. When I shipped the car, it had normal gas in the tank but before that winter pause, it had E85 in tank.  In any case, even if either one of those was the cause, it happened close to 6 years ago and the car has been driven something like 30 000kms after the fact. Again, apart from the plugs and the dip stick, there is nothing in the way the car runs that would indicate what has been going on in the engine. I am going to consult a shop and ask their opinion, what would be the best approach. I do have some access to a garage I could use to diagnose further myself, but time is very restrictive. Might end up buying another engine that could be used while this one is being remedied. Without pulling the head, it will be impossible to find out if it needs another bore, but here's to hoping a hone would suffice.  Goddamnit, I would really have preferred this not happening.
