I urgently need a Indicator/Wiper/Headligh switch assembly for my R30 as my one cracked when taking my old steering wheel off to replace it with a boss kit & aftermarket wheel.
The crack is ausing the highbeams to stay on ALL the time.
I hope someone can help me. I'm willing to pay whatever is costs to get it sent here. I jsut really need this part ASAP!
Thanks to Everyone!
You have to be kidding George.
You stuck it to us all over your pinched fuel line and now you want our help.
You referred to us all as dopes and that SAU aren't worth talking to and SDU is by far a better group and much more helpful.
You made me offers and then didn't back them up with anything else but hot air, yet you still come on here seeking our help.
I probably have about 10 of what your looking for, but I don't know your worthy of my help, as you! so far, haven't shown any interest in reciprocating.
Why don't you go ask your so fantasticly helpful SDU members for help instead of annoying us here on SAU.
In my humble opinion I think you're an arrogant arse and you should take a long walk off a short pier until at some time in the future you can show you have had a change in attitude, and then you might get a different attitude on this forum. Maybe a Lobotomy might help.
Cheers, D
Cheers, D
I have asked on SDU.
Sorry I was so rude in my post about the broken stud, it was rather frustrating waiting so long for a reply on something I wanted minor assistance on.
Is it really nessecary to talk to me like this on the forums?
Cheers/
GEORGE, IF YOU TELL US HOW YOU FIXED THE BROKEN STUD, DENNIS MAY HELP YOU.
I'm going upto the vehicle now to do some work. I'll look at the switch immediately, and then i'll wirte up a broken stuf tutorial :-)
go to ya local wreckers get that assembly outta a nissan patrol its exactly the same....and alot cheaper then repco
He is in NZ and can't get the part there, that's why he is asking here and the patrol unit IS NOT EXACTLY the same. Depends on the model, year etc etc etc.
I have Aust R30, Imported R30, ET Pulsar and Patrol headlight switch assemblies and they can be all different and that's why I asked for the plug & pins connections.
Cheers, D
  • 5 weeks later...
George,
What the f@#k are you doing about this
You must wonder why we're so critical of you, you ask for help then dissappear into the dust and we don't know or hear from you for weeks & months.
DO YOU WANT OUR HELP OR NOT
Cheers, D
George,
Cheers, D
I Do want everyones help!!
I've just sent you a personal message regarding the switches plug.
Cheers, G
Cheers, G
What about the stud, George?
How did you fix it, or is still busted?
Removed anything in the way of the manifolds.
Removed manifolds.
Attempted to remove stud with an easy out but it wouldnt bit.
Drilled out stud with a drill (I dont recommend using a cordless drill, it took at leat 45 minutes)
Purchased new stud and bolt
Tapped new thread into head
Applied loctite to stud and wound in.
Ghostrider: Did you happen to find that swtich?
1. Red/Blue Stripe
2. Black/White Stripe
3. Red/White Stripe
4. Green/Red Stripe
5. Red/Green Stripe
6. Red/Yellow Stripe
7. Green/ Yellow (could be White I cant read my writing...)
8. Red/Black Stripe
1. Red/Blue Stripe
3. Red/White Stripe
4. Green/Red Stripe
5. Red/Green Stripe
8. Red/Black Stripe
OK George,
I have no idea what your talking about, as I have a few here and they're all the same.
The picture below shows the plug arrangements and none have 8 pins in any arrangement.
Do you think we could get a bit more specific.
Cheers, D
OK George,
Cheers, D
i think he was just counting the indicator plug itself. As that is removable. :)
i think he was just counting the indicator plug itself. As that is removable. :(
Spot on Nick.
I'll remove the assembly and get some photos of it asap.
Thanks
Spot on Nick.
Thanks
George,
If you just want the indicater stalk I can take that off, but I thought you wanted the entire assembly.
Cheers, D
    • A lot of what you said there are fair observations and part of why I made that list, to make some of these things (like no advantage between the GSeries and GSeries II at PR2.4 in a lot of cases) however I'm not fully convinced by other comments.  One thing to bare in mind is that compressor flow maps are talking about MASS flow, in terms of the compressor side you shouldn't end up running more or less airflow vs another compressor map for the same advertised flow if all external environmental conditions are equivalent if the compressor efficiency is lower as that advertised mass flow takes that into consideration.   Once the intercooler becomes involved the in-plenum air temperature shouldn't be that different, either... the main thing that is likely to affect the end power is the final exhaust manifold pressure - which *WILL* go up when you run out of compressor efficiency when you run off the map earlier on the original G-Series versus G-Series II as you need to keep the gate shut to achieve similar airflow.    Also, how do you figure response based off surge line?  I've seen people claim that as an absolute fact before but am pretty sure I've seen compressors with worse surge lines actually "stand up" faster (and ironically be more likely to surge), I'm not super convinced - it's really a thing we won't easily be able to determine until people start using them.     There are some things on the maps that actually make me wonder if there is a chance that they may respond no worse... if not BETTER?!  which brings me to your next point... Why G2 have lower max rpm?  Really good question and I've been wondering about this too.  The maximum speed *AND* the compressor maps both look like what I'd normally expect if Garrett had extended the exducers out, but they claim the same inducer and exducer size for the whole range.   If you compare the speed lines between any G and G2 version the G2 speed lines support higher flow for the same compressor speed, kinda giving a pretty clear "better at pumping more air for the same speed" impression. Presumably the exducer includes any extended tip design instead of just the backplate, but nonetheless I'd love to see good pics/measurements of the G2 compressors as everything kinda points to something different about the exducer - specifically that it must be further out from the centerline, which means a lower rpm for the same max tip speed and often also results in higher pressure ratio efficiency, narrower maps, and often actually can result in better spool vs a smaller exducer for the same inducer size... no doubt partly due to the above phenomenon of needing less turbine speed to achieve the same airflow when using a smaller trim. Not sure if this is just camera angle or what, but this kinda looks interesting on the G35 990 compressor tips: Very interested to see what happens when people start testing these, and if we start getting more details about what's different.
    • I know right. It baffled me. There's no way when the engine is off, key is in ignition, (coils are dissconnected aswell), also my sound system was dissconnected (I don't run any audio capacitors), battery reads 12.2v and with the 10amp fuse blown I was measuring 24 to 30v. The reading would move a bit from 30v to 24v which was weird. I took a pic of the multi meter reading 🤣: (This is a brand new single channel digital oscilloscope that also has a multi meter mode).   Before when the fuse was blown, I had one lead on the 12v supply (green/white wires) of that brown relay and the other lead on the negative battery terminal. When I turned the key on ignition (engine off), it would read 30v. Then when I removed that relay from it's plug and tried putting ignition on again, it would read 12v, but I think it's because it can't turn on the ecu now that I removed it. I asked Chatgpt and this is what it had to say:   Not sure if those theories would be possible but, any auto sparkies here? welcome to confirm. 🤷‍♂️  No idea, but if it happens again, atleast I know what type of issue it is, unlike last few months where I didn't know what was causing all my issues and I was just taking stabs in the dark to figure out what type of problem it was. If it does happen again I'm going to investigate futher and trace back the source even more and inspect more circuits. I drove it to work this morning and the car drove and boosted fine. Yeah I was thinking the same, so I've imported my back up saved map (which is the map that I saved when it got done tuning) back onto my haltech with the base fuel pressure set to 43.5psi.
    • Yeh nice, if your in melbourne could you recommend any exhaust shops in the east that do a good job?
    • Sorry yes, this is what im after Also, that jpjdm site appears to be offline
