My daily driver is an 11/01 Nissan Maxima S A33 with a VQ30DE 3 litre motor.
I purchased it S/H when it had 85,000 km on it. Overall it is a satisfactory unit.
However at 118,000 km the idle speed assembly windings burnt out, along with the idle speed controller on the ECU. When this happened the motor idled at around 1800 rpm with a lot of surging. After a lot of searching the trouble was found and the damaged parts replaced.
Now at 125,000 it has done the same thing again! Anyone have any ideas on what could be the cause? I run it partly on 92RON fuel and also on 95RON. My mechanic says the lower grade fuel should not be making any difference. What do you guys think?
__________________ :)
sounds like something is earthing that shouldnt, id suggest taking it to a sparkie :)
Thanks for that- I will follow up that lead. In the meantime if any other members have had the same experience and details of how they solved the problem I would be pleased to hear from them.
Maybe I'm biassed, but I think it is a cut above the usual Falcodore.
Sure maybe the first one failed due to old age- but the second 7,000 km later? That's the challenge to diagnose the trouble.
Edited by nswnotill
    • Connected to plenum towards the rear end. Yes, absolutely required for the ECU. Even Nistune can't save you if you don't have it.
    • Can confirm solenoid makes no difference. I finally removed the solenoid and the wire off my engine loom and there is no issue with boost. Keep in mind, this is the solenoid, and I've got a Nistune. After the boost controller, I ran the car for a day with the solenoid unplugged - no issue. So then I just ripped the whole thing out. Like @GTSBoy mentioned before, the ECU just sends an earth signal for the 2-stage boost. And looking at the wire going into the solenoid, that just had 2 standard wires and did not look important 🤣 As for boost sensor: I saw somewhere that the vacuum line the gauge uses is at the back of the engine on the driver side. I never touched that but assume ECU uses that??? (maybe? Just assuming)
    • I still remember it trying to rip the steering wheel out of my hand when I put it into a 4wd power slide lol
    • Im also amazed how well Attessa holds up to all of the abuse. Especially with the burnouts and crap you guys used to do at Texi!
    • True! I think I'm closer to 06 with the cameras in phones being out there more. And the nearly impossible to use internet web browsers. Or paying for ring tones... Man I hated when we couldn't just compose a ringtone on a Nokia anymore! These days I just hate it if my phone rings, beeps, boops, or vibrates!
