Just heard on the Tv over here that Possum is being taken off life support...the injuries were worse than initially thought.
Thoughts to his family.
Messages to : http://www.possumpwrc.co.nz/ReadyUpdate/celebrate.asp
RIP. If there is a heaven, it will have a gravel road.
/me cries
G
http://onesport.nzoom.com/sport_detail/0,1...79-2-21,00.html
http://www.nzherald.co.nz/storydisplay.cfm...section=general
http://xtramsn.co.nz/news/0,,3882-2322501,00.html
-snip---
Bourne's Injures Worse Than Thought
28/04/2003 07:29 PM
IRN
New Zealand rally ace Possum Bourne was more severely injured in Good Friday's crash than was first thought.
His family made a special announcement at 7pm this evening.
The rally driver has been in a medically induced coma in Dunedin Hospital since April 18th.
Bourne was injured in a serious car crash when he was checking out the course for the Race to the Sky mountain climb near Wanaka.
Subaru spokesman John Coker says he suffered a severe brain injury at the initial incident, and doctors have managed his treatment very actively until now.
However, the full extent and severity of the injury has only become clear over the last weekend, when medical staff decreased ventilation support.
Mr Coker says Bourne's condition deteriorated and doctors had to put him back on full life support.
The family says his condition has been re-evaluated today, and a brain scan carried out.
They say that confirms the original injury was very severe.
The family says continuing full life support is no longer in the driver's best interests.
Bulletin supplied by IRN Limited Copyright 2001 IRN Limited. All copyright in this bulletin remains the property of IRN Limited. Terms and Conditions.
---snip---
https://www.sau.com.au/forums/topic/14813-possum/
  • Replies 44
Originally posted by GraemeWi
/me cries
/me joins Graeme :(
so so sad....I thought he would improve...and then this happens :)
"It was a very difficult decision for everyone, but in the end it is in the interests of Possum," said a close friend of the driver, Murray Brown.
"He hasn't been alone the whole time he's been in hospital and he certainly won't be now. We're all just numb. His chance of survival is virtually nil."
story here
I don't think there's any point in delaying the inevitable...
RIP Possum
https://www.sau.com.au/forums/topic/14813-possum/#findComment-301084
Possum clings to life
29 April 2003
UPDATED REPORT
New Zealand's finest rally driver, Possum Bourne, is clinging to life today as friends and family gather at his Dunedin bedside while his life support is gradually decreased.
Possum Bourne Motor Sport general manager Murray Brown told the Waikato Times today he was on his way to Dunedin Hospital and would remain there for "as long as it takes".
http://www.stuff.co.nz/stuff/0,2106,2437135a11,00.html
https://www.sau.com.au/forums/topic/14813-possum/#findComment-301852
    • I think you're really missing the point. The spec is just the minimum spec that the fuel has to meet. The additive packages can, and do, go above that minimum if the fuel brand feels they need/want to. And so you get BP Ultimate or Shell Ultra (or whatever they call it) making promises to clean your engine better than the standard stuff....simply because they do actually put better additive packages in there. They do not waste special sauce on the plebian fuel if they can avoid it. I didn't say "energy density". I just said "density". That's right, the specific gravity (if you want to use a really shit old imperial description for mass per unit volume). The density being higher indicates a number of things, from reduces oxygen content, to increased numbers of double bonds or cyclic components. That then just happens to flow on to the calorific value on a volume basis being correspondingly higher. The calorific value on a mass basis barely changes, because almost all hydrocarbon materials have a very similar CV per kg. But whatever - the end result is that you do get a bit more energy per litre, which helps to offset some of the sting of the massive price bump over 91. I can go you one better than "I used to work at a fuel station". I had uni lecturers who worked at the Pt Stanvac refinery (at the time they were lecturing, as industry specialist lecturers) who were quite candid about the business. And granted, that was 30+ years ago, and you might note that I have stated above that I think the industry has since collected together near the bottom (quite like ISPs, when you think about it). Oh, did I mention that I am quite literally a combustion engineer? I'm designing (well, actually, trying to avoid designing and trying to make the junior engineer do it) a heavy fuel oil firing system for a cement plant in fricking Iraq, this week. Last week it was natural gas fired this-that. The week before it was LPG fired anode furnaces for a copper smelter (well, the burners for them, not the actual furnaces, which are just big dumb steel). I'm kinda all over fuels.
    • Well my freshly rebuilt RB25DET Neo went bang 1000kms in, completely fried big end bearing in cylinder 1 so bad my engine seized. No knocking or oil pressure issue prior to this happening, all happened within less than a second. Had Nitto oil pump, 8L baffled sump, head drain, oil restrictors, the lot put in to prevent me spinning a bearing like i did to need the rebuild. Mechanic that looked after the works has no idea what caused it. Reckoned it may have been bearing clearance wrong in cylinder 1 we have no idea. Machinist who did the work reckoned it was something on the mechanic. Anyway thats between them, i had no part in it, just paid the money Curiosity question, does the oil system on RB’s go sump > oil pump > filter > around engine? If so, if you had a leak on an oil filter relocation plate, say sump > oil pump > filter > LEAK > around engine would this cause a low oil pressure reading if the sensors was before the filter?   TIA
    • But I think you missed mine.. there is also nothing about the 98 spec that supports your claim..  according to the fuel standards, it can be identical to 95, just very slightly higher octane number. But the ulp vs pulp fuel regulations go show 95 (or 98), is not just 91 with some additives. any claim of ‘refined by the better refineries’ or ‘higher quality fuel’ is just hearsay.  I have never seen anything to back up such claims other than ‘my mate used to work for a fuel station’, or ‘drove a fuel delivery truck’, or ‘my mechanic says’.. the actual energy densities do slightly vary between the 3 grades of fuel, but the difference is very minor. That said, I am very happy to be proven wrong if anyone has some hard evidence..
    • Hey guys I’m chasing a Rb20det complete or bare block need a good running engine as mine has low comp
    • You're making my point for me. 95 is not "premium". It is a "slightly higher octane" version of the basic 91 product. The premium product that they want people to buy (for all the venal corporate reasons of making more profit, and all the possibly specious reasons of it being a "better" fuel with nicer additive packages) is the 98 octane stuff. 95 is the classic middle child. No-one wants it. No-one cares about it. It is just there, occupying a space in the product hierarchy.
