Im pretty sure that with NSW law, the air filter needs to be secured and shielded... in other words, the AFM needs to be bracketed onto the body of the car and the POD needs to be almost completely enclosed... If the CAI box has the top half opened then it will still be classed as a defect...
Cheers
Edited by QRI05E
Cheers
I have a bracket for the pod and the CAI is completly enclosed so i think ill be ok.
CHEERS mate.
in nsw ur NOT allowed to have ANY pod filter UNLESS it has been and got a drive by and stationary noise test for induction noise!!!!!!! and it ain't cheap!!!! i've been done a few times and there is noway out of it!!!!,yeh some coppers might not give a sh*t but when it comes down to the law u can't have a pod filter unless it's been approved by nsw rta.
Bloody hell why dont we all just drive hyundais then!
RTA really do suck the fun out of everything.
In victoria you can only have 1 intake mod...so a pod is ok, and a front mount is ok, but a pod AND a front mount is a defect.
Thats the thing.. If it's due to the "emmisions" crap then why isnt it standard all over the country?
Does that mean NSW has "better" air/low noise than VIC due to NSW using box'ed emmision'ed tested PODs, while VIC doesnt?
It's double standards and rediculous! (sp).
:D
it's because nsw rta are a bunch of assholes!!!from memory i think it's about $550 for the drive by test and if you don't pass there goes your $550,i've found having the k&n pannel fillter in the box works just aswell anyway+alot less sh*t from coppers
:laugh:
well, i think it all evens out in the end, i mean we have 100000000000 x 50 more speed cameras in Vic, just look at the new set up they got goin on the western ring rd, a speed camera over every over pass pretty much....(ok so im a little over the top but u get the drift) while we get to keep 'fully sik' induction noise, we cant really go anywhere with it without being dicked by the 'Bracks' gold mine.
Hi folks,
The information about the NSW noise test isn't quite correct. Yes, you need to "pass" a noise test - as described in ADR 28 -
but that noise test need not cost you anything. All you need is access to a dB meter. It doesn't need to be conducted
by an authorised tester.
The thing that costs is the engineering Signatory's say-so that the vehicle complies with ADR 28 - this is your
engineering papers - and they only _really_ need to do this particular test if you make modifications that are likely to affect
ADR 28. A cold-air intake pipe probably won't need to be tested; a pod will (in NSW).
Of course, usually the Signatory will want to conduct the test themselves - so the cost is built-in to your paperwork.
But you can do it yourself, quite easily. All the information on how to do it is on the DOTARS website.
Regards,
Saliya
Hey Dave, another skyline in Leumeah ! Got to be a good thing. Just a thought, getting the car tuned the other day at the Hitmans and took the lid off the airbox, well guess what, a whole 2kws. No thanks. The standard airbox flows heaps til around 240kw.The sucking noise from a pod, enclosed or not will drive you nuts.
Hi mate hope to see you around,its been a pain in the arse lately defected twice in two weeks.I hope you are luckier.
Hi folks,
Regards,
Saliya
when i got defected i had the option of returning it to standed or specificly take it to penrith rta and get a drive by and standing still noise test done,which i had to book in for and they quoted me approx $550 for the drive by and the standing still test DOES HAVE TO BE PASSED by a approved tester.(whats stopping you from buying a proper exhaust db test machine and doing it urself???)which only cost about $800,i don't think the rta are going to pass that now are they you could of tested any car!!!and the signatory only charges from memory about $18.00 to pass the defect after you have returned to standed or got it passed by nsw RTA.i've been defected 3 times for a pod fillter and had to go down this road many times. Edited by mjones
    • Coming home late at night and driving past the police is the only reason i need one haha And yeh, definitley needs a switch to quickly enable it, dont have time to be getting my phone, opening an app, waiting for it to update etc before being able to make the change
    • Because it is financially convenient for them lol. Why wouldn't they want to give you the lowest possible valuation for your car?
    • Yep. @Duncan also shannons they will rip you dry and will be probably limited on how much you can drive. Also keep in mind that you always have to have it garaged with Shannons, with enthusiasts as per their PDS you can have it 2 times per week on the driveway for example.
    • I had a generic 4" Varex rear box on my old V8, worked a treat for sneaking home late at night, it was as quite as stock when closed The car was "fairly" loud when open as it consisted of 1" 7/8 headers to 3" catted Y pipe, to 4" single, it did have a resonator in the mid pipe and only the Varex out the back I also hard wired in a Varex dash mount switch, as the key fob thing is a pain to use when driving I wouldn't recommend giving the beans when it is closed though as it creates a large restriction in the exhaust  It also can in very handy when pulled over for "random" breath tests or just cruising past the constabulary
    • Here is the before and after of the scraping/sanding of the IC pads on the tachometer board for the fix mentioned in this thread. And yes it worked fine after. Just a note if you change any components on the board the tach calibration can be wrong showing the wrong idle etc...only problem is once it is installed back in the cluster you can't get to it to adjust...ouch! My fix was to cut out the calibration pot (the blue one) from the board and run it with two wires to the fuse panel under the dash where I could adjust the idle calibration once everything was installed. And yes I soldered everything up again including the half soldered components either side of the IC in my photos
