Hey guys,
Selling the rims that came with my car, as im happy to use my SSR's on the car and have no use for these wheels.
Front: 50% tread, 235/40/18 (Falken ziex) 18x7.5 rim. Uses 3mm spacer to clear calipers on my S15. Will throw in spacers. Rims also will fit 34gtt, 33gtst, 200sx etc
Rear: 95% read, 235/40/18 (Falken ziex) 18x7.5 rim. No spacers required.
Unsure of ofset both front and rear, but sits slightly inside the gaurd, so the front is probably a 37 or 38, and the rear is around 40
Price: $1100
Postage: Will post interstate. Postage cost is $170 to send interstate.
Contact: Jason 0423 324 906 / [email protected] / PM Me
https://www.sau.com.au/forums/topic/148144-18-dish-rims/
Hi Mate,
How about the PCD on the wheels, I knew they are 5x114.3 so, How about anther PCD?
I saw they have 10 holes so, they should have another fitment
Cheers
They do have another PCD but im not 100% sure what they could be, only cause they came with my S15 when i bought them. If it helps, these rims were manufactured by lenso
https://www.sau.com.au/forums/topic/148144-18-dish-rims/#findComment-2765293
mayb trade you for these if ya interested???
17 x 8s.. those look real dirty .. or are they shit condition? can you clean one up and post a pic...
i in cronulla area
brand new tread all 4s
https://www.sau.com.au/forums/topic/148144-18-dish-rims/#findComment-2765295
    • It's the same with many brands that find their way into promotion via Youtube channel sponsorships. Those stainless guys, e-mail cut shippit, various other service and product companies.... they try to make it so that the only name that comes to mind when you think of doing those things is them, and then you just go get their stuff because your favourite channels are using it, so it must be good AND good value. Notwithstanding that the YT'ers don't pay anything for it. But a lot of people are not that sophisticated.
    • Yeh vibrant looks a bit overpriced, but thats the US market in general, they pay $50k for a gtst...
    • It's surprising you say this because talking to someone who headed Toyota's CARB certification efforts and was now working for Mercedes doing similar things he said he never had a case where he found that it was necessary to reduce ignition timing for that reason. Knock limits yes, but never because of in-cylinder emissions profile. I'm guessing between EGR and the number of TWCs modern cars stack in series it's not really a problem. I really doubt the NEO is that big a difference. You get what, EV6 injectors, coil on plug, a cold start valve that works off coolant temp instead of basically fixed time constant valve, and... I really can't think of anything else. Not like Toyota where they shipped first gen GDI in the 2JZ-FSE.  Something I didn't realize is that Japan didn't revise their emissions standards for light duty passenger cars between 1978 and 2000. I'm guessing there's a bit of phase-in, but that explains why 2002 killed a bunch of JDM sports cars off all at once. FD3S, A80, S15, Z32, R34, Z15A GTO all died off for that reason. And explains how all these cars got away with no EGR or much of anything other than a TWC and charcoal canister for the longest time.
    • 100% agree. Best bet on an RB will be NEO, but even it will be a long way off. Emissions is one of the big reasons car manufacturers went to DBW and constantly variable cams. When cruising, open the throttle right up, but reduce dynamic compression so low, that it's basically an unrestricted air pump moving very little air.
    • I’m hosting a bunch of execs in the McLaren box on Saturday. If you’re around I’ll come say hi, and see if I can sneak out some freebies.
