hi guys ive bought a greddy plenum from a[ trusted] seller....no not ebay either
and ive been told its a fake
how do i tell if it is the real item there is no stamping on the plenum of any sort and im just trying to find out how i can decifer an orige from a fake?
https://www.sau.com.au/forums/topic/148152-greddy-plenum-question/
somone must know something about the plenum that decifers it from the fakes
and yes glenn ive seen the gtr ones and they are stamped but the rb25 ones are quit difrent
Edited by spirosky33
PICS tell a thousand words.....who sold it to you?
If its a trust one it should have come with a red greddy sticker, and the plastic packaging inside the box should have blue trust / greddy writing on it, forget what it says
id rather not say who sold it to me
it wouldnt be fair and its against forum rules as im pretty sure it is the real deal it came with the box and red sticker too but id like to prove somone wrong also with proof that it is the real deal
so what your saying is that there is no greddy marked on the plenum.....
Ok, so the kit come with a packet full of bits and pieces of vacume line stuff IIRC, and you would of needed a TB adapter unless you are using a Q45, the adapter comes in a small box with greddy / trust all over its plastic packaging too....
and the stuff filling the rest of the box is that annoying polystyrene stuff.....it was a funny colour IIRC, blue or something (yeah blue semi circlies Im sure of it)......if thats how yours has come its genuine
You should be able to pic the cheap fake from the actual Greddy product a mile away. The copy Greddy intake plenums have a terrible terrible finish.
If your was genuine it should have included Greddy documentation in the box to certify its authenticity and should have included the red Greddy badge as mentioned that is usually attached to the top of the plenum itself after you fit it.
Mine came in a TRUST box, all the vacuum lines have TRUST printed on them, all documentation is PLASTERED with TRUST/GReddy, there is a GReddy badge which sticks on, the TB adaptor has GReddy embossed on it..
I got it from nengun, no probs there.. however 6 months later autobarn sell them for the same price it cost me.
    • FWIW the depth of the groove in the rubber pad is not super essential, the blocks are rubber and squish a bit. If you are worried an angle grinder will make a deeper groove quick smart
    • I mean, if you were to move the jacking points away from the original location, that is, away from the wheels and closer to the centreline of the car, then it will be more likely to overbalance and tip off the supports. Same as we talked about before. I was talking about moving for-aft. If the sill is bent outward or inward, then the car would obviously look unstraight from the outside. Hopefully that hasn't happened either. Again, you can do comparative measurements from the chassis rails to see if there is much deflection.
    • Can you elaborate what you mean with your first sentence? I meant move as in the bulge kinda seemed like it got pulled "outward" meaning it got pulled down and to the side with the jacking rail itself, so the load bearing bulge now sits lower than usual and is not level with the sill on the other side of the jack point. Either that or the jacking rail just got pushed in a good bit.
    • As well as being risky WRT tipping off anyway. Yeah, I wouldn't expect it to move. Just measure from the rear one to the front one on the good side, then measure that same length on the wrecked side. You will find the notches in the pinchweld, and the jacking pad. Just spray a spot of marker paint or something there.
    • but any other area than the bulge you are talking about will just cave in then? The front driver side is pretty bent so I don't know if that will work the way it is now. I can still kinda make out where that bulge is/was but it looks like the position of it also changed due to all the mistreatment? Hard to tell
