hey all i have a 33 series 1
hicas light comes on after aout 10min of driving. i have the standard steering wheel and the fluid is full
is it possible that the steering wheel has been changed and than changed back to an original one when coming to australia, and doing so has caused the light to come on (ie it has beed put on crooked or it doesnt work like that?)
its annoying having it light up so any suggestions appreciated
thanks
https://www.sau.com.au/forums/topic/148165-yet-another-hicas-thread/
Does it come on after 10 km of driving consistantly??
First of all check if you can get it into diagnostic mode (there's a guide somewhere on this forum). If you can get it into diagnostic mode then you can at least read the error codes if there are any. If you can't even do that then you might just need a new steering angle sensor.
In the case of a faulty steering angle sensor, what happens is that the HICAS controller looks for a steering angle signal once the car is started, if it does not recieve the signal within 10km of driving then it assumes there is an fault somewhere in the system and gives you a warning light. The light will only go off after you turn off the ignition.
If you can lay your hands on another sensor cheaply then give it a try, just need to take off the steering wheel and unplug it, then fit the new one.
ok mechanic checked it on his computer, came up with 2 errors about there being no signal sent from sensor
now how would i check if the sensor is connected or oven there for that matter? i assume its in the steering column or just behind the wheel ??
btw i have a standard steering wheel on there but it could have been changed before
    • Yes, well, mine were 31 years old last year when they finally got done. Started to leak a bit.
    • I've ordered a new fuel pump and plan to do all the fuel tank hoses at the same time. Those are the hoses I would rather not go on the road.
    • As a general rule removing rubber fuel hose is so difficult I would replace it if it hasn't been done in the last 5 years. The risk you damage the liner or one of the inner layers is pretty high if it's not almost brand new. BMW's recommendations around coolant hoses is similar. My R33's fuel hoses at the fuel tank were so perished that they were ready to burst FYI.
    • Ah yep, will do. Cheers!
    • Yes. It's either "2 wires", or 1 wire, depending on how you look at it. It is the connection that ties the battery -ve to both the chassis and the engine. Every electron that goes in or out of the battery goes through those 2 small spots (on the inner guard and on the engine block). If those are not clean and tight, then shit starts to suffer. Yeah, but measure it again cold in the morning, after it has had hours to rest. You can't usefully test the charge state of a battery immediately after it has been running because the alternator puts a surface charge onto the plates that takes a while to soak in and balance out. It will always read higher, and potentially look properly healthy, when fresh off of charge. But hours later it can look a lot less healthy. It's also worth measuring the battery voltage while cranking, although this can be difficult with a typical DMM because the screem update rate is so slow on most of them. An analogue voltmeter is actually a better tool for that. If the voltage drops too far while cranking, it is a sign of a poor battery. Although I don't think we're necessarily looking for a weak battery here - just wanting to exclude it.
