Can we have stockest looking OMGWTF power making car?
I have a sneaking suspicion I know which car will take that one out,but feel free to better the effort! So far,from a local car,549 AWKW is the mark to beat from something v. neat,v. tidy and v. streetable IMHO. Go stealth!
If your talking about JUN I wouldn't call that a street car.
Define street car.Anything turn key reliable,able to make such a figure on pump fuel,can run to the shops and back without fouling plugs or overheating,of reasonably legal ride height,able to contain more than one person...dunno;missed anything else?
Yes but does it actually do all those things I wouldn't think so.
Street car in theory, yeah ok - but in reality I doubt it sees the street that much.
It's a beautiful car I would probably do the same.
It does do those things,and then some. At some stages it's daily driven to work and parked outside with the nasty weather and all ;) ...so,in my eyes,it's open to that particular award of 'normal looking,BIG power'. Although,in fairness,CEF11E said even standard looking when you pop the bonnet,so the cars I've been thinking of would lose out on that count.
There's a few other cars with slightly less(and one with more)power that could be nominated,but they'd either be too showy from either the outside or under the bonnet for the stealth idea,but there's many other suggested brackets they could be placed in...
I'm more ticked off that my car is not further down the build process to be able to be seen... :) Then again,those that know it already know where I'm heading :) !
Here's what 460+ AWKW looks like without high mount twins or a big single...Unfortunately,it's not an ACT SAU'er,but from the outside is a very(VERY) neat 32 without the bling most people put on their rides.
Just thought I'd post up a nice piccie for some inspiration... :)
I know where yours is heading Jayce, but I dont know if you'll have it all done by the end of this year...
But incase you do, we'll have a 32 V-spec2 with pearl paint and big power category just for you. :teehee:
Well anywho, thanks for the enthusiasm guys, I hope we'll get this off the ground for next year cos I'll definatly be entering the best 32 Gtst category!
I know who gets my vote for the biggest power in the non skyline bracket. And it is a true ACT built and tuned car and thats ESP with their WRX 515kw and BMW with a supra engine 530kw. Maybe you could have price brackets aswell as most people don't have an open cheque book for what it takes to pay someone to build them a 500kw plus car with all the goodies.
Thanks for the pics of Paul and Staceys car Jayce. Still reckon you can't beat the twins for the street.
Edited by widebody32
In agreeance there;massive performance from Dan' and Glenn's stable! And yes,P + S's 32 is one of my all time faves! Hence why I'm sticking with twins!
The unlimited vs limited budget idea is taken on board,too!
Cheers,J;have a top New Years!
    • Rotisserie is fully assembled apart from centre connector which obviously isn't required until the car is on it. It packs away fairly neatly and doesn't take up too much room. (Now that I actually have some room after my clean up!) Overall very happy with the quality of it.  Assembly was a piece of piss.  The only thing I didn't like was that the pins that lock the rotation lock wheels in place were a bit of a dick in a bucket scenario. It allowed the arms to rotate a significant amount even when locked in place.  To fix that i measured up the hole and went and grabbed a couple of 18mm fully threaded bolts and a thread tap to suit. I ran the tap through top and bottom so it was threaded both ends.  Then just threaded the bolt through both sides.  It has made a massive difference which hopefully you can tell in the before and after video how much difference it made. 20250207_161431.mp4   20250207_161431.mp4 Hopefully back working on the car over the next few weeks.   20250207_162801.mp4
    • I think my main complaint with your idea is that there is a veneer of idealism spread across it. You want the simple numbers to make it easier, but all they will do is make it easier for someone to come to the wrong conclusion because the fine details will kick them in the nuts. As it is right now, the tiny bit of arithmetic is NOT the obstacle to understanding what will fit and what will not fit. The reality of trying it is what determines whether it will fit. If you had a "standard rule" that R34 GTT guards have that magic 100mm space from the hub face to whichever side you were worried about, and someone said "excellent, this wheel is only 98mm in that direction, I'll just go spend $4k on them and jam them on my sick ride".....they would just as likely find out that the "standard rule" is not true because the rear subframe is offset to one side by a fairly typical (but variable) 8mm on their car and they only have 92mm on one side and 108 on the other.
    • It still combines inches with mm, especially when you have .5 inches involved, and mm and inches that can go in either direction. This would give a clear idea on both sides of the rim, right away, with no arithmetic. Even better if somebody gives you the dimensions of the arch of multiple cars. i.e GTR may be 125mm, a A80 Supra may be 117mm, or something along those lines. Yes, you can 'know' that going from a 10in rim to a 10.5in rim with the same offset moves both sides about 6mm, but you still have to 'know' that and do the math. Often it's combined. People are going from 9.5 +27 to 10.5 +15. You may do the math to know it, but if it was going from (I had to go look it up to be sure) 241mm/2 - 27 - 93.5mm from the center line to (more math) 266/2 - 15 (118mm) from the center line. Versus 93mm vs 118mm. It's right there. If you know you have a GTT with 100mm guards you can see right away that one is close to flush and the other absolutely won't work. And when someone says "Oh the GTR is 120mm" suddenly you see that the 10.5 +15 is about perfect. (or you go and buy rims with approximately 118mm outward guard space) I think it's safe to say that given one of the most common questions in all modified cars is "How do offsets work" and "How do I know if wheels will fit on my car" that this would be much simpler... Of course, nothing will really change and nobody is going to remanufacture wheels and ditch inches and offset based on this conversation :p We'll all go "18x9+30 will line up pretty close to the guards for a R34 GTT (84mm)" but 'pretty close' is still not really defined (it is now!) and if you really care you still have go measure. Yes it depends on camber and height and dynamic movement, but so do all wheels no matter what you measure it for.
    • But offsets are simple numbers. 8" wheel? Call it 200mm, near enough. +35 offset? OK, so that means the hub face is that far out from the wheel centreline. Which is 2s of mental arithmetic to get to 65mm to outer edge and 135mm to inner. It's hardly any more effort for any other wheel width or offset. As I said, I just close my eyes and can see a picture of the wheel when given the width and offset. That wouldn't help me trust that a marginal fitment would actually go in and clear everything, any more than the supposedly simple numbers you're talking about. I dunno. Maybe I just automatically do numbers.
