cars > women?
Yeaaah.
*hides*
*glares at you*
lol have fun explaining that to steph ian, i'll say goodbye to you now :yes:
Well well well im sure ive gotten the promise to god lecure from him before, that he would sell his car for me :P........hahaha probably wouldnt forgive me tho....muuuhahaha
*still hiding*
*whispers from behind hiding place*
going off topic guys... careful...
Yeah thats right you shoosh
I think I should get some new wheels for my skyline.
I dont like the look of the current ones. But then again, there genuine blitz racing wheels, worth a fair bit apparently.
yay, i told you they need more bling, the stockies look solid but dull im afraid
  • Replies 67
Well well well im sure ive gotten the promise to god lecure from him before, that he would sell his car for me :O........hahaha probably wouldnt forgive me tho....muuuhahaha
:huh: thats evil! your evil :yes: still, i've been asked to promise worse things, like choosing between my friends and her..............i chose my friends :P and apparently so did she afterwards. they now live together :O
we digress, this is supposed to be about new years resolutions
yeah i agree but change that to my car is more important than guys.
My resolution hey
1. Get fitter, might get into those classes at the gym.
2. Spend a f**kload of money on my car
3. Move out of home ...not sure if number 2 and 3 can happen at the same time though
4. Keep my 1 point till next year otherwise i am licenseless
5. Have as much fun as possible
6. Buy more snap on tools.
7. Try not to f**k up at work....
Thats about it so far
My resolution hey
Oh Yeah tools is never enough ! cept i might go for Sydchrome ;)
Not much planned,
1. Render my house
2. Get new rims; at least 18's
3. By new bike, got to be a 600 and up! Last one was a Fireblade 250, not fast enough
4. Get car painted; booked in late Jan! Whooohoh
5. Get more bling for me.......
Plus get my Logistics Management course finished and come cruising.... ;)
1. Finish my car so that I am finally happy with it and can stop spending money upgrading.
i.e.
-rebuild engine with a very safe 300+ rwkw
-fix all of the little cosmetic bits that I am always going to "get around to" like fixing the side skirts.
I just want to have the car to a stage where I am satisfied. When will I be able to stop?
2. Finish my degree THIS IS THE LAST YEAR!!!
3. Get a good job, make lots of $$$$$$
4. Lose 5kg then put on 10
5. Cut down on my road rage
:D thats evil! your evil :) still, i've been asked to promise worse things, like choosing between my friends and her..............i chose my friends :) and apparently so did she afterwards. they now live together :down:
HEY i didnt ask for his promis......he did it all i tells you
he just can admit it
and yes sorry for the spamage
ahhhm
Number 8? MOVE OUT
*still hiding - stubournly refusing to come out*
I see you mother...............*sings innocent tune*
if u bought a mansion why would u bother going to the gym, wouldnt u already have one in your mansion, i know i would....
good point, But sum of them girls at the gym r hot , and if u go gym, u are more disiplined to work out more and harder. than if ur by urself aye...
Edited by silverbulletR33
Very true. No one works out hard by themselves and at home. Gym makes you work harder as you don't want to waste your money and you don't want to look like a weak-sauce in front of the lovely ladies at the gym.
    • hey OP can you remind me what the actual question was, I got sidetracked at V12. Do you have an turbo oil return leak and an unidentified coolant leak? The factory oil returns are terrible design; short, rubber and expensive to replace. They are very common to fail and a pain to replace because they are so short. Still, they are available new if you want to replace both last time I checked. For the coolant leak, any competent mechanic should be able to do a pressure test; that should show up where the leak is. It is almost certainly one of the billion 30 year old rubber lines which are now brittle as hell, you engine will be fine.
    • From the OP's description, sounds to me like the TCU is in 'limp home' mode --- that is, no actuation power to shift solenoids, and the EPC valve is shut (full line pressure). This effectively sticks the box in 3rd gear, with as much line pressure as possible, to try hold the high clutch clamped shut....and so you get woeful acceleration and don't feel any shifts (because they're not happening). If you don't have Consult or some other scanner to interrogate the TCU itself, you can test with a multimeter to see if it's in limp home mode....ie; stick it in D with engine at idle (hold vehicle with hand/foot brake), and measure the voltage at the TCU feeding shift solenoids A & B -- both should be ON (battery voltage). If they are energized at the TCU, you can unplug the harness from the TCU, and check resistance down through the wiring to the solenoids themselves -- you should see about 20ohms on each coil --- if you do, you can presume the wiring to shift solenoids is OK -- if both measure open circuit, you have to check intermediate connectors in the loom down to the gearbox (and the gearbox connector itself), and check the shift solenoid resistance at the gearbox connector itself --- if the shift solenoids test open circuit here, problem is in the box (ether the solenoids or wiring to them is bad). If you get no voltage at TCU connector for the shift solenoids (and the solenoids/wiring test OK), check powers/grounds to the TCU itself --- if they're ok, it suggests the TCU is the culprit (and you'd need to interrogate it if possible, to find out why it's behaving badly)...
    • Hey mate give Autotechnica a go, I recently got some Comfort PUs and rails from them, they're comfy and look great highly recommended! https://www.autotecnica.com.au/part-finder/nissan/skyline/r32/
    • Honestly, for a daily I would gladly rock a Camry. The more disposable the better. People drive horribly out here and road conditions are awful.
    • Verify it's going into each of the 4 gears in normal acceleration, make sure the torque converter locks up over ~65-70 kph or so at low throttle opening. If you ease into the throttle at those speeds eventually you should get a "gear" between 3rd unlocked and 4th locked. It should downshift eventually if you floor it at 65 kph too. Get some Matic D ATF and drain the pan, check for signs of sadness in fluid and drain plug magnet. Top off to the correct level afterwards. If the transmission is worth saving you can drop the pan on a second drain and change the filter while you're at it. These are not complicated transmissions, at least compared to modern stuff.
