  • Replies 67
Get a HAWT personal trainer...then use teh gym at home :D
New years resolutions are a waste of time...when it comes to December and you all look back over 12 months and realise you achieved none or very little of what you intended, you will then beat yourselves up for weeks over being an underachiever.
Instead set a mid year goal for yourself ie have saved 3K by June or have lost 10 kgs by May...that kind of thing.
Then if you don't get there by June you still have until December to get your act together :P
New Years resolution.....
1. Make loads of money.....everything else follows or can be bought with money.
2. Reduce time spent with other half so more mountainrunning can be done.
3. Find cure for PMS.
Let me know how you get on please.
Gee ben, there wouldnt be an underlieing dislike of aunt flow in there would there?
Why spend less time with other half to allow for mountaineering? Bring her with you!
lol are you saying something mister?
:happy:
good point, But sum of them girls at the gym r hot , and if u go gym, u are more disiplined to work out more and harder. than if ur by urself aye...
yeah, girls sweating = hot
guys sweating over girls = even hotter :D
I know the trick :D if your really desperate ill pm you......*whispers* i dont want to give it out to Ian :(
heh heh eeevil
:D
guys sweating over girls = even hotter :P
I know the trick :P if your really desperate ill pm you......*whispers* i dont want to give it out to Ian :(
heh heh eeevil
this is the best new years resolution topic eva!!!!
guy sweating over 2 girls = *something not to be discussed on here*
I thought i would add
- get my car looking fkn'good as well.
- and win lotto
- actually play lotto
- try to be nice to silly people.....
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
