Hi all , as usual trying to make things easy if I can ...
For all you people who have HKS's GT2835 Pro S or GT3037 Pro S , I need to know a couple of things about clearance between the compressor housing and the std RB20/25 exhaust manifold . From specs I have both these turbos use TO4E .50 A/R compressor housings and I'd like to think they clear the std manifold by a reasonable margin .
I have always liked HKS's turbine housings because they are biased a bit more towards performance that Garrett's offerings ie the volute passage and nozzle is a better shape . There is a chance that using a real GT3076R (the one that looks like a GT3037S but without the trumpet mouth inlet insert) with Garretts IW GT30 housing that the comp housing may be where the exhaust manifold lives . I'm wondering how I would go with the Pro S turbine housing on this GT3076R 52 trim turbo thats in the wings next year . If I can luck out with a better housing design and clear the manifold it makes life easy .
Just on the Pro S housings , the waste gate vent path looks like it had some serious thought put into it (flat valve not small either) and the dump pipe should not be difficult to re create if its expensive/impossible to get .
Another thought was trying this combination out on HKS's cast low mount exhaust manifold though I have a feeling that the engine mount may get in the way .
Thoughts - particularly from that fella with the 3037 Pro S on the RB25 .
Cheers Adrian .
Cheers Adrian .
http://www.skylinesaustralia.com/forums/in...st&id=12339
http://www.skylinesaustralia.com/forums/in...st&id=12340
Not the best pictures but from what I can remember the 2835 comp housing was pretty close to the manifold - I could get my dad to measure for you if you want.
Th compressor housing clearance of the 3037 pro S with the 56T and also .68 rear clears the manifold with ease, i am still able to mount the factory exhaust heat sheild on there as well on the manifold, no clearance problems at all, only fun is just jiggling around to get the perfect fit (as in jiggling the housings and turning them to properly fit it. but no clearance problems what so ever, as well as the INTWASTE well the actuator just needs some modifying to fit and hold properly, Have no fotos at the moment as am away from normal computer, but if your happy to wait i can get them off to you when i get back, hope that helps.
As well as dump/front pipe fabrication, most good exhaust shops should be able to custom one as the funny 5 bolt flange on them. so far so good.
Hope that helps out disco, as for proper measure of housing to manifold heat shield space ummm a good centermeter id say but would have to measure
Cheers
Adam
Thanks fellas , I guess its a case of a trial fit in the end . I remember asking ages ago for pics of the 3037 Pro S exhausting because the turbine size difference (compared to 2835 version) would not have worked . From the pics I'd say the people who machined these housings off set the turbo slightly and it shows when you compare the two turbine outlets in relation to the sealing groove .
Adam how do you find the power characteristics of that 3037 56T with the .68 A/R housing ? Depending on how much off boost urge I can find I was thinking of using the .87 .
Cheers Adrian .
I find the power characteristics as follows, due to that my engine has been fresh rebuilt so im still running on a lighted tune of 244 rwkw's until i am able to dyno after the first couple of thousand km's. In comparision as am unable to take past 3.5 K rpm for first thousand can only really report on findings so far, I have found that with the .68 housing that the boost will start making from about 2600 rpm, there is plenty of torque with the new turbo and i cannot really post much else until i am able to open it out further.
Although i will keep you guys updated when i do with dyno graph and also will update further on power characteristics when this happens,
But in the mean time, AAA+++ in my books, also on another note the .68 housing wasnt a by choice option, although my opinion i would have gone the .87 housing as well, or .82, but as im not chasing too larger numbers at the moment i have settled with the .68 housing
Hope that helps
Cheers Adam
    • Took it for a drive to do some logs, I’m pretty sure my voltage issues and electrical noise issues are gone, I’ve sent a log to Adam and am waiting to hear back with confirmation  att.K23U9eHyiEJxixH6y1__GQfuqK0EgIoDgQFTs9G8x_w.mp4   idle video from that day just because
    • Went looking at mine, reading off the tyre, presumably these are 1st week of 2003. Still hold air (I haven't had to pump them up in over 12 months!)     I couldn't quickly find the date on the front tyres, they were fitted around 2008 to the rims, so probably not quite as old, but they have a lot more dry rot cracks in them. Still hold air.
    • I am now intrigued to go check the dates on the tyres on my Skyline... We need a game of who has the oldest tyre still holding a car up, and successfully holding air (for longer than a 2 weeks I feel is successful air holding).   I feel your tyres may be beating mine
    • Ok, still waiting for a date to get the cams installed on the MX5, why so long, because MX5 Mania has received a few new sets of different cams with different specs for the MZR and are currently trialling them, and working out what is best for 2.5 "powers" with stock internals, in the end if I go bigger than the Kelford stage 1 cams I'll need to look at the valve springs  Hopefully I'll get the news on them next week As for the boot of the car getting fixed, I hopefully pick it up early next week, I was sweating on picking it up yesterday but, meh, it was not to be, so ne weekend cruising for me
    • Ok got some old tyres for you guys...my car has been sitting around un-driven for about 6 years now. I had it on the original rims with the shitty compliance tyres it got it with back in 2006, which were manufactured in 2004... Sidewalls eventually rotted and split open, obviously no air in them and the rims were holding the car up. Just swapped them with some 17" Work rims and tyres which are probably 10+ years old too but at least holding air
