Hi all , as usual trying to make things easy if I can ...
For all you people who have HKS's GT2835 Pro S or GT3037 Pro S , I need to know a couple of things about clearance between the compressor housing and the std RB20/25 exhaust manifold . From specs I have both these turbos use TO4E .50 A/R compressor housings and I'd like to think they clear the std manifold by a reasonable margin .
I have always liked HKS's turbine housings because they are biased a bit more towards performance that Garrett's offerings ie the volute passage and nozzle is a better shape . There is a chance that using a real GT3076R (the one that looks like a GT3037S but without the trumpet mouth inlet insert) with Garretts IW GT30 housing that the comp housing may be where the exhaust manifold lives . I'm wondering how I would go with the Pro S turbine housing on this GT3076R 52 trim turbo thats in the wings next year . If I can luck out with a better housing design and clear the manifold it makes life easy .
Just on the Pro S housings , the waste gate vent path looks like it had some serious thought put into it (flat valve not small either) and the dump pipe should not be difficult to re create if its expensive/impossible to get .
Another thought was trying this combination out on HKS's cast low mount exhaust manifold though I have a feeling that the engine mount may get in the way .
Thoughts - particularly from that fella with the 3037 Pro S on the RB25 .
Cheers Adrian .
Cheers Adrian .
http://www.skylinesaustralia.com/forums/in...st&id=12339
http://www.skylinesaustralia.com/forums/in...st&id=12340
Not the best pictures but from what I can remember the 2835 comp housing was pretty close to the manifold - I could get my dad to measure for you if you want.
Th compressor housing clearance of the 3037 pro S with the 56T and also .68 rear clears the manifold with ease, i am still able to mount the factory exhaust heat sheild on there as well on the manifold, no clearance problems at all, only fun is just jiggling around to get the perfect fit (as in jiggling the housings and turning them to properly fit it. but no clearance problems what so ever, as well as the INTWASTE well the actuator just needs some modifying to fit and hold properly, Have no fotos at the moment as am away from normal computer, but if your happy to wait i can get them off to you when i get back, hope that helps.
As well as dump/front pipe fabrication, most good exhaust shops should be able to custom one as the funny 5 bolt flange on them. so far so good.
Hope that helps out disco, as for proper measure of housing to manifold heat shield space ummm a good centermeter id say but would have to measure
Cheers
Adam
Thanks fellas , I guess its a case of a trial fit in the end . I remember asking ages ago for pics of the 3037 Pro S exhausting because the turbine size difference (compared to 2835 version) would not have worked . From the pics I'd say the people who machined these housings off set the turbo slightly and it shows when you compare the two turbine outlets in relation to the sealing groove .
Adam how do you find the power characteristics of that 3037 56T with the .68 A/R housing ? Depending on how much off boost urge I can find I was thinking of using the .87 .
Cheers Adrian .
I find the power characteristics as follows, due to that my engine has been fresh rebuilt so im still running on a lighted tune of 244 rwkw's until i am able to dyno after the first couple of thousand km's. In comparision as am unable to take past 3.5 K rpm for first thousand can only really report on findings so far, I have found that with the .68 housing that the boost will start making from about 2600 rpm, there is plenty of torque with the new turbo and i cannot really post much else until i am able to open it out further.
Although i will keep you guys updated when i do with dyno graph and also will update further on power characteristics when this happens,
But in the mean time, AAA+++ in my books, also on another note the .68 housing wasnt a by choice option, although my opinion i would have gone the .87 housing as well, or .82, but as im not chasing too larger numbers at the moment i have settled with the .68 housing
Hope that helps
Cheers Adam
    • yeah i agree paint match stops it from standing out so much, oh that's actually really good to know i was wondering if it would help with air flow now actually having an outlet in the bonnet. Will have to focus on ducting into and out of the radiator now to make the most of it.
    • I would paint match the whole thing to avoid unwanted attention  I had a similar bonnet, paint matched, on my old R33 GTST, but mine was a fibreglass jobbie made by Blitz in QLD, they work extremely well for radiator efficiency and under bonnet temps
    • Does anyone run this kit with factory plenum? Does the adapter and bosch tb fit under factory strut brace? I wanted to get this setup before going forward facing manifold. Thanks
    • small update time, after always wanting a "cool" looking bonnet for my car and always struggling to find one for the series 2 that i liked and wasn't an insane amount of money. Saw one i liked on RHDjapan from D-speed in Japan the price was very good for a carbon bonnet so good infact i was a little unsure how much i trusted it, decided to bite the bullet and with the help of jesse streeter in not long at all it was at my door. Once it was delivered i ran in from work and quickly unboxed it and to my surprise the quality was actually pretty good i quickly removed the old bonnet and placed on the new one to test it out and even the fitment wasnt too bad at all. Then decided to paint the little grille in the bonnet black to stop it sticking out so much.   I decided to not mess around with the hood latch and just install some aero catch hood pins, having never installed them before did some YouTube university classes and i was good to go. fair to say it is not a fun job at all from making brackets so the pins sit nicely and actually cutting through the bonnet but also being very scared of cutting the holes too big it took wayyyy longer than i would like to admit but finally got it there. Then it was time for a quick test drive to ensure the latches actually worked and thankfully the bonnet looked very stable. I still think paint matching the bonnet and leaving just the part that sticks up as carbon would help make it all look alot neater as im not sure how i feel about all that carbon on a very fridge white car but will leave it as is and see how i feel with time.
    • I think it's bound to happen, you finally get it all perfect, and bam, something will happen. I took a while to get a Commodore rear quarter repaired where a P Plater clipped it. Two days after getting it back, Sarah wiped it out on a concrete pillar in an underground car park... This is why I take forever to repair them, it stretches how long until it gets bent again... 😛
