  • Replies 89
Posted Images
Now someone give me some f#$king good coil packs as mine are all roasted and need some new ones I think. Havent heard back from the tester place so not expecting good news.
Rip them out and shove silicon all around them... Worked on mine. :spank:
  • 2 months later...
What size rims can u fit on the rear?
I recently had a set of 18 x 9's on the rear and they hung out slightly, the front 18 x 8's they sat just right, I tried them on the rear and they too sat perfect.
So 8" wide rim +35 tends to fit just nice. :)
lol looks nice, I have the same prob with my new rims, they stick out too much :teehee:
They fit perfectly.
The tyre wall is flush with my gaurds. On the rear anyway.
The rims are 18 x 9 +10 both front and rear.
I will need to get camber arms asap for the front.
Thanks SHowza.
Lol i was the freak at AIR yesterday waiting for huddy's tyres to be fitted yelling abuse at ya. HAHAHAHAH
Yeah but the rim itself looks to be sticking out.
Yes that is correct.
I am under the impression that if the tread is under the gaurd its A OK!
So yeh the rim sticks out of the gaurd but the treadis still under the gaurd.
I dont care it looks fat.
  • 5 months later...
Yeh I havent replied in this for a while.
But the broom broom has changed alot since i last posted.
It also now has a roof spolier on the rear window and will be getting a supermade boot spoiler on it soon aswell.
YAY.
Brenton
  • 3 weeks later...
    • C34 Stagea RS4S Standard RB25DET Neo with ARP Headstuds and MLSR Gasket. Bosch 1000cc injectors Walbro 460 Standard neo inlet plenum w/rb25 s2 throttle body 6 Boost Low Mount Manifold Turbosmart Gen V 45mm wastegate (recirculated) Pulsar g30-770 (0.72 rear housing) 3.5"intake pipe to clear mounts, 3.5" dump to 3" exhaust Link G4X Ecu 380 hp on 98 octane, 478 HP on e85 (mainline hub dyno) Video of Earlier Run VID_300701109_043404_458.mp4 Final Dyno Sheet:
    • Meh. Every single gear in my gearbox will crunch. I've been treating it nicely for >12 years now.
    • How fast are you doing the downshift? 4th gear was revised multiple times until 1998 to fix this issue. Synchro clips can fall out, synchros can wear. Most likely you're looking at a new transmission unfortunately. If you need to limp it until then double clutch downshifts into 4th.
    • Sorry I was being harsh there, but am I wrong? You can buy a M340i easily, and there's loads available second hand. A lot more workshops modifying them as well. How about getting parts for them? Don't get me wrong, I'd love a 400R, even a 4cyl (I looked at a few V36s before buying my shitbox BMW). Sadly Infiniti died in Aus and we're stuck with importing them as niche vehicles. Supply and demand
    • Probably straight swap for an R32 GT-R? lol
