I installed a apexi pod last nigh and i noticed a drop in torque slow spool and a general flatness in performance.Why so? My guess is that its sucking hot air. I have a Unique alloy CAI but when i tried to fit it,it seemed like i needed a FMIC cause the holes in it didnt line up.
CHEERS
Dave
also check all you vac hoses i had the same problem crappy performance etc and one of my lines were split but it seems like a bit of a coincidence that it happnd after the pod filter install dude
i didnt notice much or any difference in power after i shielded my pod compared to before it was shielded.. I wouldnt imagine that it would cause that large a difference.
Did you run a cold air feed to it?
Put the airbox back in
if that fixes it up, you know its the problem
otherwise you might have bumped the AFM connection or something
I put the stock airbox in with a panel KnN.Performance returned.
Hmmmm i thought a pod would provide more performance?
No.
Hot air is powers worst enemy mate
Airbox is the way to go anyhow IMO.
Unless you do some good CAI, there isnt any point... A stock airbox with a good panel filter is pretty good.
GTR airboxes + 350rwkw is no issue
No.
x2
Besides that, I doubt the ability of the apexi pods, as they are substantially smaller than the comparative K&N items and are still an oil-based filter. I think they would more suit an sr, ca etc.
actually....the apexi is the best out there..and no it isn't oil based...
there is a test made by some supra guy iirc based on most pods out there
and the apexi came out on top...cleanest and gave the most power...
if you are getting less performance then you are definitely sucking in hot air..
http://www.mkiv.com/techarticles/filters_test/1/index.html
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 😃
    • You're just describing how type certification works. Personally I would be shocked to discover that catalytic converter is not in the stock mounting position. Is there a bracket on the transfer case holding the catalytic converter and front pipe together? If so, it should be in stock position.
    • You talking about the ones in the photo above? I guess that could make sense. Fixed (but flexible) line from the point up above down to the hubcap thingo, with a rotating air seal thingo. Then fixed (but also still likely flexible) line from the "other side" of the transfer in the hub cap thingo up to the valve stem on the rim. A horrible cludge, but something that could be done. I'd bet on the Unimog version being fed through from the back, as part of the axle assembly, without the need for the vulnerable lines out to the sides. It's amazing what you can do when you have an idea that is not quite impossible. Nearly impossible, but not quite.
