hey guys some dickhead backed his car in2 mine yesterday and his towball dented my front bumper
hav a look at the pic its teken like a chunk out of it
neway the guy actually prolly soccer mum in a f*kn 4wd left without a note
so any ideas on what i can do, me being short of cash and cant afford 2 replace the whole thing
you reckon i can make it look half decent again myself
if not where would be the best place to go and how much am i looking at?
thanks guys
Edited by desmond
https://www.sau.com.au/forums/topic/148350-help-some-one-hit-me-in-carpark/
hey bud thats pretty shit... but what goes around comes around, you can try and do it yourself, just sand it back and fill it then take it somewhere to get it sprayed cos you dont wana just do touch up spray it'll stand out alot but you can fix the dent yourself dude...
all the best man
you could get away with yourself if you've got access to some decent tools.
spraying it is going to be the hard part, if you want it to match you'll need to sand back all of the clear, primer the damaged section, paint and trying to blend with the rest of the paint, then re-clear the whole bar.
you could get away without rubbing back the clear, but the new paint might not match the rest of the bar.
ok and if i was to get it done professionally
would i just go to a panel beater or would they not be able to fix this
any one know of good places in perth? and how much im looking at
cheers
Des look in the west australia section is best bet
or give damage control a ring if your south of river
Damage Control
-Body repairists
U 5/ 1848 Albany Hwy, Maddington
Ph: 9452 8933
if ya north look through the consolidated workshop thread for a list of auto body repair
workshops
    • It doesn't really answer your question...but is the head unit full android or just android auto, are you happy with how quickly it boots and responds, and do you have a link?  If we can identify good Android alternatives it will really help people stuck with Japanese screens. Did it have a separate reverse camera input so you would replace the factory one, or are you just going without now...that would be a pretty big steps back. And finally, do you have a picture of the "wire" that you can't plug in? Most likely it is some sort of aerial that is not too important eg japanese traffic or am radio or something if you haven't noticed a functionality issue
    • haha funny enough I did ask him wtf he had been up to with the electrics....but no answer
    • For a daily just run Akebono ceramic pads. That's what they're optimized for. Obviously don't try to run it on track or anything like that.
    • Hey all, I'm sorry if this has been discussed before.  I have a 2008 Japanese import V36 coupe with nav but without Bose. I bought one of those AliExpress android screens, which for the most part works really well.  The only thing that doesn't work is the air con controls (well sort of) and the factory reverse camera.  The AC can be controlled fine but it doesn't report the change in temp and mode to the screen, and the volume knob/other audio controls from the panel don't register on the learning app.  I am pretty certain that the problem is the difference in the head unit between base model (Nav but no Bose) 2007-2009 coupes and anything after 2009.  Mine is the one with the blue connector all the way to the right as seen in this forum post:  The reason I think this is there is one wire left over that doesn't fit anywhere on this head unit, or in the factory screen which also uses different connectors to more recent versions.  I've seen the upgrade from OWC, and have sent the guy a message on eBay but no response yet.  I also don't particularly need the whole kit, just *maybe* an adapter for this one cable.  Did anyone else here have the same problem, or have any insight about what I can do to get this working?  I have been in contact with the seller but all they seem to be able to do is ask for more pictures and videos. Minor edit to add:  I have been researching and found a screen on Aliexpress that actually specifies my head unit in the listing, so these things do exist.  I will contact the seller to see if the wiring adapters are interchangeable with other screens.   Thanks in advance!
