There isn't anything carbon looking from factory..
But try ebay anyway, there's rolls of that carbon lookalike stuff on there for cheap.
incorrect, sedans did come out as a factory option the carbon fibre look side panels...ive got them and they're in good nick :)
There are coupe ones from Nismo but they are dear!
I bought some CF look film from overseas a few years ago and did my silvia up...looked pretty good IMO...
hmm, weird..
Would've thought since the coupes didn't get it why would the sedan? :)
hey don't copy my nick!! hehehhe
the nengun link above is original item. Although don't you think i'd be better to get sheet cf cut the shape ourself and stuck it on? I think it's only AU$40-$50 12" x 24" (30cm x 60cm)
still plenty to cover your dash and stuff
search for carbon fibre sheet in www.ebay.com...
won't come up if you search in the Australian one
