Originally posted by franks
duh! who reads sticky's anyways!!! :)
sounds good, $120 bucks is ok, but i dont wanna scare those little honda's :(
Don't knock'em too quick. These guys know their stuff as they've been doing it for some time and the type r on wakefield is a quick weapon. Wakefield is a short and tight circuit where suspension and drivers are the more important factor rather than hp.
Next Track day is Monday 9th June... tis a public holiday so all should be able to attend. Full day. $190 approx cost at Eastern Creek.
Other wise it is as discussed the HCC trackday.
If anyone's after a cheap day at Wakefield I've done a few of their open practice days and I reckon they're pretty good value.
Costs involved are:
$80.00 for the day
$30.00 for a Wakefield Clubcomp Licence valid for 12 months (not needed if you have a CAMS L2S or higher license and also valid for Supersprints held at Wakefield)
Helmet hire available for $20 per day with a $50 Deposit
To keep the dickhead factor down and track time up it's better to attend earlier in the week and on "cars only" days. A few options are:
Mon 19th May
Thurs 22nd May
Mon 2nd June
I'm thinking one of the Mondays would be better so then we can go down on Sunday sometime and do some boozin (in moderation, naturally).
:D
Anyone interested? Fatz? Maj? Bonkers? Duncan? You know you want to.
Cheers,
Ben
Costs involved are:
$80.00 for the day
Mon 19th May
Thurs 22nd May
Mon 2nd June
I'm thinking one of the Mondays would be better so then we can go down on Sunday sometime and do some boozin (in moderation, naturally). :O
Cheers,
Ben
    • What can't be done with a little bit of decking board or similar timber bolted to a hub flange via 2 wheel nuts is not worth talking about.
    • I noticed something. On the tps sensor and the sensor behind the adjustment screw is adjusted towards the far left. Are these screws supposed to be centered? (this sensor was in the same position before the tune as well)  Also attached a photo of where my car usually idles at when warm (sometimes a tiny bit above that). I think I might have screwed up the calculation and it might have better than I thought lol at 750rpm still not 650rpm though.
    • So for both general interest of engine health, and to rule out any coolant/oil issues, I organised an oil analysis done on the 125,000klm oil Results below, all good, just a bit of fuel dilution which I'm not too worried about
    • This is actually a really good way of measuring what wheels fit. If only there was a similar measurement between hub face and suspension :p That said, it's probably pretty simple to actually measure it all with the wheel off the car for the rear. The front is a bit more complex but..
    • Being the top Google search result for R34 wheel-related inquiries, lemme throw down my experience. I calculated that 100mm from hub face to wheel face is about the perfect fitment for my ENR34 sedan.  I've been running 18x8.5s, ET35, with a 1" spacer. So, 8.5in to mm = 216mm. 216/2 = 108mm. 108-35 = 73mm. 73+ 25 (1" to mm) = 98mm.  If you wanna get close to this on dif widths, here are the offsets you'll want: 9" - ET around 15mm 9.5" - ET around 20mm 10" - you're crazy, but ET around 30mm All these should fit perfectly on a non-widebody, non-GTR Skyline. Note that it's probably the absolute max, and you're probably better off running a couple degrees of camber in this config, but it looks great, super flush.
