whens the next track day skid pan day
fatz
 Share
Originally posted by franks
duh! who reads sticky's anyways!!! :)
sounds good, $120 bucks is ok, but i dont wanna scare those little honda's :(
Don't knock'em too quick. These guys know their stuff as they've been doing it for some time and the type r on wakefield is a quick weapon. Wakefield is a short and tight circuit where suspension and drivers are the more important factor rather than hp.
Next Track day is Monday 9th June... tis a public holiday so all should be able to attend. Full day. $190 approx cost at Eastern Creek.
Other wise it is as discussed the HCC trackday.
If anyone's after a cheap day at Wakefield I've done a few of their open practice days and I reckon they're pretty good value.
Costs involved are:
$80.00 for the day
$30.00 for a Wakefield Clubcomp Licence valid for 12 months (not needed if you have a CAMS L2S or higher license and also valid for Supersprints held at Wakefield)
Helmet hire available for $20 per day with a $50 Deposit
To keep the dickhead factor down and track time up it's better to attend earlier in the week and on "cars only" days. A few options are:
Mon 19th May
Thurs 22nd May
Mon 2nd June
I'm thinking one of the Mondays would be better so then we can go down on Sunday sometime and do some boozin (in moderation, naturally).
:D
Anyone interested? Fatz? Maj? Bonkers? Duncan? You know you want to.
Cheers,
Ben
Costs involved are:
$80.00 for the day
Mon 19th May
Thurs 22nd May
Mon 2nd June
I'm thinking one of the Mondays would be better so then we can go down on Sunday sometime and do some boozin (in moderation, naturally). :O
Cheers,
Ben
 Share
    • Harness update time have had great fun and learnt so much already so far with this project. I started off making both the ignition and injector sub harnesses in the hope any mistakes i made here aren't as hard to undo and learn from as the main harness.  A cool comparison of the old harness using presumably TXL wire and the new which is using Tezel. Also opted to use DTM plugs to keep the whole setup as neat and tidy as possible and tucked the wiring under the coil bracket to try and keep it all from sticking out too much. Although the injector harness, I'm not overly happy with as I'm still using the rubber boots that are supplied with the type of plugs it just looks ugly and sticks out like a sore thumb with the white identifiers so a slight redesign may be done.   Then it was main harness time and most importantly trying to route it nice and away from the heat it will use the OEM heater hose routing which is no longer present to keep the harness up high and secure. it's amazing how much smaller this harness is able to be compared to the old one. plugged everything into the emtron and with the help of the tuner again attempted to start it up and instantly fired up and running smoothly on all 6 which was a big shock to myself. So still some routing and adjusting to be done for the final fit up and installing a knock sensor harness plug which is in the post all has gone surprisingly well.     The old harness for shits and giggles.
    • They do that at random every now and then, with almost no detectable cause. Mine has done it a couple of times (over 25 years!!). Never worked out why.
    • I don't post on here and have been lurking for some time now. Many of the topics have helped me out more times than i can count. I was racing yesterday (11/9) and blew a front right CV shaft. I have spares so I popped a new one in. A thread i read previously said to check the engine mounts if you blow a front CV. Upon inspection, the front right mount was completely separated from the upper plate. This discovery saved me time and money, because i would have blown another CV if i went back out. Just wanted to thank you guys and wish everyone luck with with their builds. (Now if we could only come up with a solution for my power steering belt flying off after hitting the rev limiter, lol)
    • Either way he still need those style of spacer to go into the manifold because the photo he currently has is not going to work
    • You can just get the injector bosses, which allows top feeds to fit. He can use the same injectors without issue, like these (another option): https://rocketindustries.com.au/af59-2210-rb25-fuel-injector-inserts     The Racework ones look a bit better: https://www.nzefi.com/product/raceworks-lower-injector-mounting-boss-kit-for-r33-rb25det-s14-s15-sr20det/   You could also just get a similar kit like the Radium one by Plazmaman: https://plazmaman.com/product/nissan-rb25det-r33-billet-fuel-rail/?srsltid=AfmBOoogfYq49X0fu2Wdbf8yOf6zt9egyPAif_gn3Qr3G8hzAphhTgOkO70
