Hi Guys..
I'm looking at replacing the stock 6X9s in my R33 and am lookng for some advice regarding what to go for.
Not after anything flash (not big into steros) but basically something that will make the most out of the head deck (Pioneer 4X50watt).
advice regarding whether to go 2 / 3/ 4 way and how many watts (keeping in mind no plans for amps).
ie. using this head unit am i really going to benefit buying Pioneer 420w 3 way over 260w 3 way???
thanks!
https://www.sau.com.au/forums/topic/148423-recommend-6x9s/
if you want a top pair of 6x9's, get your hands on the phillips pro series speakers, they arent on the market any longer but they are great speakers to have if some1 will sell them to ya. i have them in mine, and they are clear as, before the amp got installed and even better after the amp.
https://www.sau.com.au/forums/topic/148423-recommend-6x9s/#findComment-2781422
I went for a new set of 6x9's and chose alpine type S. Can't remember the model number, but they were about $120 form JB's. Couldn't be happier. No need for a sub, as they have plenty of bass (no doubt a sub would have more, but I want to keep the boot space, and also I hate it when you see a skyline drive by and hear it thumping like a kidnap victim is trying to escape from the boot.)
I chose these speakers because I already had an alpine deck, and some alpine 5.25's in my doors.
Anyway, that's my .02
https://www.sau.com.au/forums/topic/148423-recommend-6x9s/#findComment-2782184
  • 6 months later...
Hi Guys..
thanks!
gosh btw does r33 comes with stock 6x9s??coz i planning to get 1....and i m nt sure if its fit....but the shape of the speaker cover at the rear of the car looks similar to the 6x9s??
https://www.sau.com.au/forums/topic/148423-recommend-6x9s/#findComment-3227496
god dammit...
they come stock with 6inch front and back... fitting 6x9s in the back is a bitch without the right gear, which you can get, but i dont know what to look for...
if you have a sub, or plan on getting one, please dont waste your time with 6x9s, they will never be as good as even a mediocre 6 inch...
if you dont have a sub, and dont want one, then i dont know, go to a store and listen to them... i suggest getting a small amp as well...
also, those power ratings are max power, they mean sweet f**k all... look for RMS power... if your headunit has 50 watts x 4, then get something with 50 wattsRMS...
https://www.sau.com.au/forums/topic/148423-recommend-6x9s/#findComment-3227508
    • The rain is the best time to push to the edge of the grip limit. Water lubrication reduces the consumption of rubber without reducing the fun. I take pleasure in driving around the outside of numpties in Audis, WRXs, BRZs, etc, because they get all worried in the wet. They warm up faster than the engine oil does.
    • When they're dead cold, and in the wet, they're not very fun. RE003 are alright, they do harden very quickly and turn into literally $50 Pace tyres.
    • Yeah, I thought that Reedy's video was quite good because he compared old and new (as in, well used and quite new) AD09s, with what is generally considered to be the fast Yokohama in this category (ie, sporty road/track tyres) and a tyre that people might be able to use to extend the comparo out into the space of more expensive European tyres, being the Cup 2. No-one would ever agree that the Cup 2 is a poor tyre - many would suggest that it is close to the very top of the category. And, for them all to come out so close to each other, and for the cheaper tyre in the test to do so well against the others, in some cases being even faster, shows that (good, non-linglong) tyres are reaching a plateau in terms of how good they can get, and they're all sitting on that same plateau. Anyway, on the AD08R, AD09, RS4 that I've had on the car in recent years, I've never had a problem in the cold and wet. SA gets down to 0-10°C in winter. Not so often, but it was only 4°C when I got in the car this morning. Once the tyres are warm (ie, after about 2km), you can start to lay into them. I've never aquaplaned or suffered serious off-corner understeer or anything like that in the wet, that I would not have expected to happen with a more normal tyre. I had some RE003s, and they were shit in the dry, shit in the wet, shit everywhere. I would rate the RS4 and AD0x as being more trustworthy in the wet, once the rubber is warm. Bridgestone should be ashamed of the RE003.
    • This is why I gave the disclaimer about how I drive in the wet which I feel is pretty important. I have heard people think RS4's are horrible in the rain, but I have this feeling they must be driving (or attempting to drive) anywhere close to the grip limit. I legitimately drive at the speed limit/below speed the limit 100% of the time in the rain. More than happy to just commute along at 50kmh behind a train of cars in 5th gear etc. I do agree with you with regards to the temp and the 'quality' of the tyre Dose. Most UHP tyres aren't even up to temperature on the road anyway, even when going mad initial D canyon carving. It would be interesting to see a not-up-to-temp UHP tyre compared against a mere... normal...HP tyre at these temperatures. I don't think you're (or me in this case) is actually picking up grip with an RS4/AD09 on the road relative to something like a RE003 because the RS4/AD09 is not up to temp and the RE003 is closer to it's optimal operating window.
    • Either the bearing has been installed backwards OR the gearbox input shaft bearing is loosey goosey.   When in doubt, just put in a Samsonas in.
