Yeah, I know. I think the gtr boys were saying the full set for theirs inc doors or something is over $2k... But mine are stuffed, and leaking water at times. I've made the decission to fix the car up properly, so that means rubbers, re-do the dash... Repaint wheels, etc etc.
But yeah, the rubbers are high on the list.
https://www.sau.com.au/forums/topic/148424-rubbers/#findComment-2770852
im more interested in the aesthetical rubbers... chrome strips have rubbers going along with them also
and the door seal ontop of the door trim on the inside of the window... i retrimmed my interior in camo and made the mistake of even touching those seals... soon as you touch them they bend and never go back to shape...
https://www.sau.com.au/forums/topic/148424-rubbers/#findComment-2772208
Yeah, thats the ones I need.
Group buy?! haha!
https://www.sau.com.au/forums/topic/148424-rubbers/#findComment-2772296
    • Connected to plenum towards the rear end. Yes, absolutely required for the ECU. Even Nistune can't save you if you don't have it.
    • Can confirm solenoid makes no difference. I finally removed the solenoid and the wire off my engine loom and there is no issue with boost. Keep in mind, this is the solenoid, and I've got a Nistune. After the boost controller, I ran the car for a day with the solenoid unplugged - no issue. So then I just ripped the whole thing out. Like @GTSBoy mentioned before, the ECU just sends an earth signal for the 2-stage boost. And looking at the wire going into the solenoid, that just had 2 standard wires and did not look important 🤣 As for boost sensor: I saw somewhere that the vacuum line the gauge uses is at the back of the engine on the driver side. I never touched that but assume ECU uses that??? (maybe? Just assuming)
    • I still remember it trying to rip the steering wheel out of my hand when I put it into a 4wd power slide lol
    • Im also amazed how well Attessa holds up to all of the abuse. Especially with the burnouts and crap you guys used to do at Texi!
    • True! I think I'm closer to 06 with the cameras in phones being out there more. And the nearly impossible to use internet web browsers. Or paying for ring tones... Man I hated when we couldn't just compose a ringtone on a Nokia anymore! These days I just hate it if my phone rings, beeps, boops, or vibrates!
