my 33 came with the factory lsd as standard.
now this 'problem' has happened to me twice in the time i've owned it (read: 3 years) so i doubt it'll be a common issue.
anyway first time it happened i was reversing up my driveway. it is relatively steep (about a good 30-45º). anyway while reversing i reached a point where the weight of the car was pulling the car down much more than the rear tyres could get traction of. i was pretty much riding the clutch out, and only the rear right tyre would slowly rotate on the spot and eventually the car would gradually slide down hill. i ended up getting my other car tow hooked it and pretty much had my brother assist tow me up the driveway.
second time happened today, we are building a new carport and one section of our front yard is now just dirt. the incline isnt as steep as the driveway (about a 10-20º incline) . and this time while reversing only the rear left tyre was slowly rotating in the dirt. i had to throw a solid plank of wood under to get back onto the driveway.
now i know the problem lies partly with my tyre:surface traction and camber. i am running yokohama c.drive (nice, not cheap and quite grippy tyres) and -1.5º camber at the rear. i think the camber is the issue here.
BUT, what i'm getting at is if it is normal for an LSD to rotate one wheel when in reverse at low speeds?
does it only engage when going forward? does it need a fair bit of speed to engage?
cheers
eug
https://www.sau.com.au/forums/topic/148426-is-this-normal-for-an-lsd/
more stick just fries that one tyre even more, and no the other wheel just stays still and the car wont move.
will a newer viscous lsd spin both wheels in reverse? i was under the impression (from a friend) that an lsd wouldnt engage under reverse load.
under forward load, both rear wheels spin - so no problems there.
just seems to be in reverse. obviously its not something i encounter day in day out - so its not a hassle, but is this a sign that my diff is on its way out?
Oh, I didn't read it carefully enough. I don't know about the lsds in the reverse situation.
Does the same thing happen if you're trying to go up a wonky driveway forward and one wheel almost lifts off the ground? like do you get beached?
My friend's skyline with the viscous lsd will get beached when going forward because of the worn lsd. He has to just reverse back and take a different angle.
yip, i'm primarily asking about in a reversing situation.
when the car is balancing on two wheels (see-sawing) on a driveway it normally just teeters there until the rear wheel touches the ground and it gets some more forward thrust.
i thought that the "beaching" was normal, since there is no actual load on the air borne wheel? and that the only case both wheels would spin 100% of the time is with a locker.
Beaching is only normal for single spinners and torsen LSDs. Open diffs effectively send all torque to the wheel with the least grip. Torsens act as a torque multiplier so if you have zero grip on one wheel you'll actually spin it up - if however you put your foot on the brake slightly the LSD will function.
Viscous LSDs (standard in skylines) act based on speed differential - ie the faster one wheel is spinning the more torque will be applied to the other. Clutch type LSDs do the same thing but in a more effective way.
My (healthy) VLSD will never beach, but I frequently spin wheels slightly getting up our steep and curvy driveway. However, even though one wheel is spinning the other is still pulling me up the driveway - if I put my foot down harder it'll still launch itself.
I can confirm that diffs do work the same in reverse. Got into a situation in my Pulsar where I had to reverse off some wet grass / mud. One tyre kept spinning and the other dragged me out. I know you can't really compare it to rwd, but the basic concept is the same.
does a pulsar even have an lsd? I thought fwd cars were just open wheelers?
Gun, it's a bit different for you, because you have a gaytR. Even if both of your back wheels were off the ground (dunno how that'd happen, but anyways), you still wouldn't be beached. Torque would just kick in at the front.
I think they're more talking about beaching of rwd cars with stiff suspensions.
so this is typical with cars with stiff suspension yeh.. i just gerk clutch abit and it shoots forward and is no longer beached...
i gather its gaytr cause u dont have one yeh????
and yeh ur right as front talk kicks it pull it off....
I was only joking about the gaytr bit. i used to call the one we had a gaytr.
But yeah, that's the difference i noticed between the gtr and the gts. I've put the gtr into a mega beach before, so much so that you'd think it was stuck, and it still managed to move.
with the gts, in a similar situation, there'd be a fair bit of wheelspin.
i was wondering about this a bit as well.
33 gtst, one wheel spins a bit when it lifts mostly off the ground going into my driveway.
altho the other still pulls me along fine, and more gas will still send me forward fine.
it seems to be a pretty common problem.
But, the thing I wasn't sure about, is how eug was asking about reverse. That is, whether the lsd works the same way in reverse. I'm not sure about that.
Some diffs do only act in one direction - they are called "1-way LSDs". You can also get 2-way which act on accel and decel (decel is the same force as reverse). Also there's 1.5 way which has a harder LSD action on accel and mild LSD action on decel.
the standard viscous LSD is basically a bunch of plates sandwiched together, half connected to one axle half connected to the other, and filled with sticky goo. So it doesn't care which way the wheels are spinning, but because the LSD action is provided by a liquid it'll never bite as hard as a mechanical diff.
Ok so what can be done with people that have worn viscous LSD's,
is replacing them with a new VLSD or a mechanical one the only option?
I would have thought you would ba able to shim them up a little to make them tighter?
Cheers
Josh
what kinda costs are we looking at re-shiming? is the effort of taking the diff out and bring it somewhere worth it?
or should i be looking into aftermarket 1 or 1.5 ways? (kaaz diffs are ~$1050 delivered)
    • You have just offended every teenage boy in America
    • Structured text and other high level PLC programing languages are not allowable in Functional Safety. They are very difficult to audit. My PLC stuff is almost exclusively oriented towards Burner Management Systems which are a particularly pernicious form of Safety Instrumented System, when implemented in an SPLC. Even the part of the code written to work in the non-safety logic part of the PLC, like with a Siemens S7-1500 series, still needs to be treated as if it was safety code, with access restrictions, code fingreprints and the like. And Allen Bradley can go EABODs. They ae full of shit. They have this whole lie going on where they say if you use a ControlLogix controller and its IO, and then just duplicate the IOs (ie, run in series or parallel depending on type, to try to make it "fail safe") and "use these programming styles and place these restrictions on what you do" that you can achieve SIL2. What a load of crap. They just get away with it because no-one in the US seems to understand the first thing about Functional Safety and carries on as if all they have to do is buy only SIL2 rated equipment and hey presto, it's a SIL2 system. Idiots. /rant
    • If you're really considering leaving it, a great question to ask is, is the magnet going to stick to the sump? The answer to the above is the same answer towards if I'd have any level of comfort leaving it... Personally, based on the cost of a motor if the magnet were to cause damage, I'd be fishing it out either way. Use the methods in here. It fit in through the plug hole, it'll come out.   PS, get a small actuatable claw for a bore scope. OR if you know a vet, they have really cool controllable scopes with hooks on the end. Supposedly they're like playing a video game. Ask if they can acquire you one of their scopes... Engine oil after all is just a different type of lube right? Will only make it easier on the next dog or cat...
    • All other (Boolean) logic functions though, are just built on those blocks above. Which does give you a lot of functionality in logic. It is basing that on using thresholds with analogue signals like GTS alluded to.   Not having things like timers will make it less useful for some of the ramp up logic you'd want, and again, on Haltecs capacity specifically, I'm not across anymore what you can / can't do with different tables.   I'm assuming, with your logic you want to implement, not only do you want your timing safeties, you're wanting to be able to derive the duty cycle for your solenoid, to maintain I'm assuming 175PSi? Or are you using a standalone WMI controller to maintain the DC correct, and you just want the Haltech working out which fuelling maps you should be on?
    • It doesn't seem to follow revs. Oddly it seems to follow TPS a little bit from what I can see, but with some delay a bit. IE end of the graph, when he lets off throttle fully, pressure drops a lot, then slowly builds back up, but rpm is on a nice cruisey drop off. I do agree though, it seems very electrically.
