my 33 came with the factory lsd as standard.
now this 'problem' has happened to me twice in the time i've owned it (read: 3 years) so i doubt it'll be a common issue.
anyway first time it happened i was reversing up my driveway. it is relatively steep (about a good 30-45º). anyway while reversing i reached a point where the weight of the car was pulling the car down much more than the rear tyres could get traction of. i was pretty much riding the clutch out, and only the rear right tyre would slowly rotate on the spot and eventually the car would gradually slide down hill. i ended up getting my other car tow hooked it and pretty much had my brother assist tow me up the driveway.
second time happened today, we are building a new carport and one section of our front yard is now just dirt. the incline isnt as steep as the driveway (about a 10-20º incline) . and this time while reversing only the rear left tyre was slowly rotating in the dirt. i had to throw a solid plank of wood under to get back onto the driveway.
now i know the problem lies partly with my tyre:surface traction and camber. i am running yokohama c.drive (nice, not cheap and quite grippy tyres) and -1.5º camber at the rear. i think the camber is the issue here.
BUT, what i'm getting at is if it is normal for an LSD to rotate one wheel when in reverse at low speeds?
does it only engage when going forward? does it need a fair bit of speed to engage?
cheers
eug
https://www.sau.com.au/forums/topic/148426-is-this-normal-for-an-lsd/
more stick just fries that one tyre even more, and no the other wheel just stays still and the car wont move.
will a newer viscous lsd spin both wheels in reverse? i was under the impression (from a friend) that an lsd wouldnt engage under reverse load.
under forward load, both rear wheels spin - so no problems there.
just seems to be in reverse. obviously its not something i encounter day in day out - so its not a hassle, but is this a sign that my diff is on its way out?
Oh, I didn't read it carefully enough. I don't know about the lsds in the reverse situation.
Does the same thing happen if you're trying to go up a wonky driveway forward and one wheel almost lifts off the ground? like do you get beached?
My friend's skyline with the viscous lsd will get beached when going forward because of the worn lsd. He has to just reverse back and take a different angle.
yip, i'm primarily asking about in a reversing situation.
when the car is balancing on two wheels (see-sawing) on a driveway it normally just teeters there until the rear wheel touches the ground and it gets some more forward thrust.
i thought that the "beaching" was normal, since there is no actual load on the air borne wheel? and that the only case both wheels would spin 100% of the time is with a locker.
Beaching is only normal for single spinners and torsen LSDs. Open diffs effectively send all torque to the wheel with the least grip. Torsens act as a torque multiplier so if you have zero grip on one wheel you'll actually spin it up - if however you put your foot on the brake slightly the LSD will function.
Viscous LSDs (standard in skylines) act based on speed differential - ie the faster one wheel is spinning the more torque will be applied to the other. Clutch type LSDs do the same thing but in a more effective way.
My (healthy) VLSD will never beach, but I frequently spin wheels slightly getting up our steep and curvy driveway. However, even though one wheel is spinning the other is still pulling me up the driveway - if I put my foot down harder it'll still launch itself.
I can confirm that diffs do work the same in reverse. Got into a situation in my Pulsar where I had to reverse off some wet grass / mud. One tyre kept spinning and the other dragged me out. I know you can't really compare it to rwd, but the basic concept is the same.
does a pulsar even have an lsd? I thought fwd cars were just open wheelers?
Gun, it's a bit different for you, because you have a gaytR. Even if both of your back wheels were off the ground (dunno how that'd happen, but anyways), you still wouldn't be beached. Torque would just kick in at the front.
I think they're more talking about beaching of rwd cars with stiff suspensions.
so this is typical with cars with stiff suspension yeh.. i just gerk clutch abit and it shoots forward and is no longer beached...
i gather its gaytr cause u dont have one yeh????
and yeh ur right as front talk kicks it pull it off....
I was only joking about the gaytr bit. i used to call the one we had a gaytr.
But yeah, that's the difference i noticed between the gtr and the gts. I've put the gtr into a mega beach before, so much so that you'd think it was stuck, and it still managed to move.
with the gts, in a similar situation, there'd be a fair bit of wheelspin.
i was wondering about this a bit as well.
33 gtst, one wheel spins a bit when it lifts mostly off the ground going into my driveway.
altho the other still pulls me along fine, and more gas will still send me forward fine.
it seems to be a pretty common problem.
But, the thing I wasn't sure about, is how eug was asking about reverse. That is, whether the lsd works the same way in reverse. I'm not sure about that.
Some diffs do only act in one direction - they are called "1-way LSDs". You can also get 2-way which act on accel and decel (decel is the same force as reverse). Also there's 1.5 way which has a harder LSD action on accel and mild LSD action on decel.
the standard viscous LSD is basically a bunch of plates sandwiched together, half connected to one axle half connected to the other, and filled with sticky goo. So it doesn't care which way the wheels are spinning, but because the LSD action is provided by a liquid it'll never bite as hard as a mechanical diff.
Ok so what can be done with people that have worn viscous LSD's,
is replacing them with a new VLSD or a mechanical one the only option?
I would have thought you would ba able to shim them up a little to make them tighter?
Cheers
Josh
what kinda costs are we looking at re-shiming? is the effort of taking the diff out and bring it somewhere worth it?
or should i be looking into aftermarket 1 or 1.5 ways? (kaaz diffs are ~$1050 delivered)
    • I did read your post, a few times actually.    Done. Followed this step. [Negative probe should be on the cars chassis. Positive on the wire.]   Did this partially.. now that im reading this over, i only unplugged the LED lights. [Start as said above by unplugging everything (unplug the lights, and switches.] When you are talking about the switch, you're talking about the knob thing on the right side in the drivers seat right? If so, i need to take that apart?  [Now at the switch, there is a wire from the fuse, to the switch, so out your positive on that terminal. It should read open circuit. If it reads something, especially a stupid low value, the short is somewhere between the fuse and the switch.] At this point are you referring to the connector by the headlights?  [If that's fine, now put the positive probe on the wire that goes to the headlight (at the switch plug). If it reads stupid low, the fault is from the switch, to the headlight.] Did this. I can confirm that the LED lights aren't the issue [Another quick test, is take the whole LED light setup from the left, and plug it into the right side, does it still blow the fuse? If you put the right hand side led light setup on the left hand side wiring, does the left hand side wiring now blow?  If the blowing fuse swaps from right to left doing this, your LED lights are the issue.]
    • Hey was wondering if you ended up installing the R33 GTR speed sensor - I found one too and wanted to confirm it's a direct swap into the R34 6 speed?
    • After 23 years of owning a Skyline, finally had the latch go.  Followed this guide,  works like a dream again. Great Guide 👍
    • Hi all,   I’ve got the biggest lot of problems with my R33 GTS-T   It was a freshly rebuilt 25th anniversary RB25DET (plastic cas, neo cams) probably 6 years ago now   The engine was running so well but I fkd up badly and trusted someone I’d known for 10 years that was well known around Plazmaman for his welding and fab work. I added a lovely photo of some of his previous work. Not sure why my car was worked on by whoever did this shit     I’m normally someone who would never open myself up to something like this, I still can’t believe I did it. Trusting him literally fkd it all up for me. Everything has been a struggle, like it’s almost been 6 years that’s how much I’ve just on and off been trying to work it all out.    All I wanted was a car that danced down low, like full boost from around 3~3500rpm to redline, don’t really care what power it puts down (if it ever does) but I just wanted it to be quick to get on it.    He recommended the turbo to get, I picked Hypergear but he told me to get the front 4” with a T4 and 0.68 rear housing.    I was expecting all these beautiful welds, tidy fab work and paid for it to be ready to go to a tuner when I got it back.    I got a car back that was an absolute mess, I actually couldn’t believe it was my car anymore. I don’t think you could even call what he did welds, they’re disgusting.    So I stripped everything he touched off it and with every bolt I loosened it just got worse and worse.    I covered it and literally built and finished another car in the meantime but now it’s getting to the point where I really want my Skyline back.   Its a struggle because I paid him to do all this shit because I didn’t know how to and now I’ve had to try and figure it all out omg    Please excuse the bird shit horrible welds, I’ve got my show pony car and am so beyond dealing with this car I don’t even really care at this point.    If someone told me about what he did to my car I wouldn’t have believed them but it happened to me. It was unbelievable. He went missing, my car went missing, it came back missing parts, the straight af chassis rails bore the scars of being dragged up a trailer backwards, even the sandwich plate was bent. Everything was leaking and open to whatever fell into it, rounded off/ missing bolts, power steering oil and coolant everywhere, no gaskets, parts stolen off it, even managed to damage the sump pan.   Promised me he’d finish the car, knew what it meant to me, I paid him thousands and thousands just for him to trash it. He told me he was fully licensed and insured, come to find out he’d cancelled his ABN, so obviously no insurance. I had laid up insurance on the car and would’ve been covered but I was scared they would’ve written it off or because the business was no longer trading I’d still be liable.    He was supposed to:  New fully custom mild steam pipe exhaust manifold with turbo location moved from factory position to high forward mount. (I don’t know if it is a mild steam pipe, I’ve got a funny feeling the waste gate isn’t in a very good position and I don’t think the outlets off each cylinder are equal) 4” custom stainless steel dump with external gate (he re-plumbed it) Cut and shut OEM intake manifold with throttle reposition (I ended up doing the throttle reposition) Box in pod filter (left out) New 100cel catalytic converter (pretty sure it’s there but unsure if it’s 100cel) Front mount intercooler piping fabricated to suit (all smashed up and rusty holes where he was supposed to make it look standard where fmic piping passes through. I don’t even think my front bar is going to fit 🙄) Custom 5” intake pipe from pod to turbo (didn’t come with it so had to do something to make it work with the Z32 afm)   Engine: Full cylinder head service & machining  Brand new valves Precision upgraded spring kit Engine block honed New bearings  New piston rings  New ARP conrod bolt kit New ARP head studs Cometic head gasket VRS kit   ATR43SS2 ball bearing turbo 0.68 rear housing  Turbosmart 45mm external wastegate (got delivered to the fab bloke, I’ve got no idea what spring is in it, I’m assuming the one that came pre installed) Walbro 260 fuel pump  Nismo 740cc injectors (tested to 880) Spitfire coil packs GCG FMIC RB25DET manual 5 speed 4:11 rear diff   I’ve got an Apexi Power FC in it atm, I was hoping to just get it to operating temp to make sure everything was okay before towing to a tuner but it’s over-fuelling too much. I don’t think that’s going to happen so i think I’m going to get either a Link G4 or Haltech for it. What do you guys recommend? I can’t work out the power FC so just gonna give up on that one     It’s got an exhaust leak coming from somewhere I can’t see 🙄    The fuel pressure was steady but now it like drops from 40 to 20psi randomly (noticed this yesterday)    I’ll attach pics of the shit he put on my car and the engine bay now as it sits    I really just need some help, I need a tuner in Sydney I can trust, I’d like to be with the car while it’s being tuned if possible, I know it looks terrible but unfortunately I’ve just got to put up with it for now and fix the cosmetic stuff later   Do you guys think the manifolds are going to be okay? Or do I throw the exhaust manifold and try again?   I don’t even think these combinations are going to work tbh   I know everything I fitted was rated to be able to take at least 400kW but most rated higher    If you’ve gotten this far I really really appreciate it 🙏 I don’t mind if you trash me or the car, I made a rookie error and f**k I’ve paid for it. As you’ll see 🙄
    • From everything I’ve heard you’ll be waiting a long time for  the parts to arrive
