Burghandy gts-t doors, bare, $80 each
Left Window $80
Front Seats $80 each
Rear Quarter Panels, Come and cut what you want, Call for price
Stock BOV $40
Glen Waverley, Melbourne
0413 934 330
cheers
Edited by Chef_32
Hi Mate,
Do you have the passenger side, power window button (circular one)
Cheers,
Dan
Windows L+R $80 each
0413 934 330
cheers
u got front cut just chassis only???? also any front end parts??? get back to me cheers
0413 934 330
cheers
  • 4 weeks later...
